Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Sun Feb 19, 2017 11:36 pm Post subject: Fuel pump replacement |
Well, prepping the wife's 72 superbeetle for the spring season and whilst running it, noticed some wetness near the fuel pump area. The hoses looked kinda old, so I replaced with some brand new hose. Didn't make a difference. That's when I noticed that fuel was actually seeping out from the join between the brass part and the aluminium stand...a lot!
I guess the winter storage of fuel in the pump must've done it in.
Took it out. Had to take out the distributor to take it off too, couldn't find any other way to access the rear nut. Is there a better way?
Searching the threads, I noticed people saying they used multiple gaskets. Mine only had the one...between the flange and the pump. There was nothing between the flange and the engine. Is this normal?
What's a good pump to get? I ordered one from the local lordco for the interim. The guy said it was called "spi". But I'd like to get a better one if possible. Anyone heard of Machine 7? I googled it and the pump looks robust.
Here are some pix of my existing pump.
_________________ ---------
Rubber Duck
1974 Westfalia |
wcfvw69 Samba Purist
Posted: Mon Feb 20, 2017 6:52 am Post subject: Re: Fuel pump replacement |
http://vwparts.aircooled.net/Mechanical-Fuel-Pump-Upright-Engine-w-Alternator-p/113-127-025g.htm
These are reported to be decent pumps. They are the "C" clips on the rocker pin so they don't fall out like many of the other new pumps sold today.
You'd still need to check the fuel pressure after installation to make sure it's in the 3psi range. _________________ Contact me at [email protected]
The Samba member since 2004.
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10797 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Feb 20, 2017 7:08 am Post subject: Re: Fuel pump replacement |
Rubber Duck wrote: |
-swivel socket on an extension.
-there should be a gasket below and above the spacer. how many you need to install to adjust to proper pump stroke length will depend on the travel of the rod, thickness of the base, etc.
-Brosol used to be good fuel pumps. I would presume they still are.
-you need to pack the base of the pump with grease.
your pic below is a
Cusser Samba Member
Joined: October 02, 2006 Posts: 33035 Location: Hot Arizona
Posted: Mon Feb 20, 2017 8:17 am Post subject: Re: Fuel pump replacement |
If my VW, I'd go with one just like Bill recommended in his earlier post, with the clips on the horizontal pivot rod.
I've used a 13mm socket with the universal extension built-in, and not needed to remove my distributor or distributor cap on mine. Some have used an S-shaped 13mm box wrench for this and for front carb nut.
And I would leave the plastic flange in place !!! They can break !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Feb 20, 2017 10:34 am Post subject: Re: Fuel pump replacement |
Guys, thanks for the replies. Bill, I was thinking of getting a rebuildable one, but maybe those are already few and far between. The one I currently have also ha the circlip on the pin, but I guess the seal or diaphragm inside just rotted out. Seems like a waste to change out the whole pump just because some seal gave way. But that's the way it is I guess.
Hazetguy, I did try a swivel socket, but my 13 mm socket is already too tall to fit on the outside nut, let alone the inside one. I tried, and I guess together with the height of the socket combined with the height of the swivel extension, it wouldn't fit. I think I'll pick up a 13 with built in swivel socket.
The distributor wasn't too hard to take out, but I was concerned that when I looked into the hole, there was a spring just standing there. Never seen this one in my 74 bus engine. Did I just break something?
Regarding the grease, yes, I will do that. The photo shows the pump as it looked when I removed it. I guess the PO did it that way. I'll make sure to pack it good with grease. As for gaskets, I hope the new one comes with them as the old one didn't!
Cusser, I wish I'd read the samba posts before taking the flange out. I was curious as to how long my rod was. Well, when I took out the flange, thankfully it didn't break, but the rod kind "fell" in. And I thought, oh Lord, what have I done. It was jammed tight to one side and nothing I did could pry it out.
Eventually, I put the distributor back in, took note of the position of the rotor and started moving the engine back and forth. There was a point where the rod loosened enough for me to take it out with a needle-nose plier. Phew!
Later, I read the Bentley and it specifically warned against taking the flange out before the rod. Yeah. Wish I'd read that BEFORE I did it. Lesson learned. Can't imagine what to do if the rod had fallen in somehow! _________________ ---------
Rubber Duck
1974 Westfalia |
Cusser Samba Member
Posted: Mon Feb 20, 2017 10:50 am Post subject: Re: Fuel pump replacement |
Hazetguy, I did try a swivel socket, but my 13 mm socket is already too tall to fit on the outside nut, let alone the inside one. I tried, and I guess together with the height of the socket combined with the height of the swivel extension, it wouldn't fit. I think I'll pick up a 13 with built in swivel socket. |
For a tinier bit more clearance, you could use JIS 8mm x 1.25mm nuts which use a 12mm socket, from Japanese vehicle place or even some Ace Hardware, and then use smaller 12mm swivel-socket.
The distributor wasn't too hard to take out, but I was concerned that when I looked into the hole, there was a spring just standing there. |
Correct, that spring just sits there in a recess in the distributor drive gear.
As for gaskets, I hope the new one comes with them as the old one didn't! |
It should.
Cusser, I wish I'd read the samba posts before taking the flange out. I was curious as to how long my rod was. Well, when I took out the flange, thankfully it didn't break, but the rod kind "fell" in. And I thought, oh Lord, what have I done. There was a point where the rod loosened enough for me to take it out with a needle-nose plier. Phew!
Later, I read the Bentley and it specifically warned against taking the flange out before the rod. Yeah. Wish I'd read that BEFORE I did it. Lesson learned. Can't imagine what to do if the rod had fallen in somehow! |
Good. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon Feb 20, 2017 10:52 pm Post subject: Re: Fuel pump replacement |
Hi.
Your current fuel pump is probably leaking from an o-ring between the two colored metal parts. This is a sealed assembly. Some of the pumps I used 25 years ago had a screw top where one could access an area of the pump.
Since you have a generator, as I see in the pics, you can utilize a fuel pump that offers you the ability to disassemble it. In the classifieds there are many people offering pumps that may suit your needs, as low as $5.
One nice thing about a pump that can be accessible is with all the junk in the gas, plus the age of the entire fuel system, this is one area someone can look into even when the gas filter is downstream.
Hope this helps, Bill. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11786 Location: Redding, CA
Posted: Mon Feb 20, 2017 11:07 pm Post subject: Re: Fuel pump replacement |
I bought a Brosol about a year ago. It had a nice "C clamp". I didn't need to stack gaskets. Just one on either side of the Bakelite flange, and I got between 2.5 and 3 lbs. pressure.
Do not pack the crap out of the bottom of the fuel pump. Just grease the bottom leg. I overpacked mine and noticed the grease squeezing out of the weep hole about a week later. You can overpack, but you'll just make a little grease-turd on your motor.
By the way, when I bought my pump, it didn't come with gaskets. I had to buy them separately. You might want to by a few each, just in case you have to stack a little.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Tue Feb 21, 2017 12:57 am Post subject: Re: Fuel pump replacement |
Hey Bill, mine is not a generator, it's an alternator as far as I can tell. Do you mean to say that only the generator model beetles could use the rebuildable pumps?
Tim, the store didn't have any gaskets. I guess I'll make my own. Thanks for the tip. _________________ ---------
Rubber Duck
1974 Westfalia |
Posted: Tue Feb 21, 2017 7:06 am Post subject: Re: Fuel pump replacement |
Tim Donahoe wrote: |
Do not pack the crap out of the bottom of the fuel pump. Just grease the bottom leg. |
I think you'll find that VW service manuals will disagree with this.
Posted: Tue Feb 21, 2017 7:19 am Post subject: Re: Fuel pump replacement |
Correct. VW went to the slanted fuel pumps when they installed alternators on the engines. I'd go with the pump from Aircooled.net then.
My VW's are all running generators so those rebuildable square top pumps fit. _________________ Contact me at [email protected]
Posted: Tue Feb 21, 2017 8:54 am Post subject: Re: Fuel pump replacement |
[quote="Rubber Duck"]Hey Bill, mine is not a generator, it's an alternator as far as I can tell. Do you mean to say that only the generator model beetles could use the rebuildable pumps?
Hi. The pics that I see appear to show the bottom of a generator. You can use either style of fuel pump. But as far as I know only rebuildable fuel pumps are/were available for the gen style.
A tip to pass along here. Many people are aware of the ease of R&R the distrib by removing the 13mm hex nut for the distrib hold down clamp. If a person does enough of these he will occasionally find the threads for this stud pull out of the engine case. It is an easy repair but, in my opinion, totally preventable. In every one that I have removed the stud was only using, maybe, 2/3 of the available thread depth. My solution is to remove that stud, via the double nut method, measure the holes thread depth and utilize a replacement stud that will bottom out and be long enough to allow the clamp, spring washer, and nut.
SBD Samba Member
Joined: October 24, 2012 Posts: 3294 Location: SOUTH DAKOTA
Posted: Tue Feb 21, 2017 1:38 pm Post subject: Re: Fuel pump replacement |
Save the shaft with circlips from your old pump! They could come in VERY handy someday.  _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3561 Location: 802 The Pointless Forrest
Posted: Tue Feb 21, 2017 2:16 pm Post subject: Re: Fuel pump replacement |
Great idea. _________________ "Albatross"! |
Cusser Samba Member
Posted: Tue Feb 21, 2017 6:05 pm Post subject: Re: Fuel pump replacement |
SBD wrote: |
Save the shaft with circlips from your old pump! They could come in VERY handy someday.  |
I did save mine from my old Pierburg pump when I rebuilt it for my 1970 - the WW rebuild kit came with a new pivot rod and circlips.
My 1835cc engine has a fuel pump without clips, over a decade old, and the pivot rod has never worked its way out. However, I didn't feel like monkeying with it - because of its history - so I did NOT install that saved pivot rod into it; instead, I made 2 physical retainer plates.
SBD Samba Member
Posted: Tue Feb 21, 2017 6:40 pm Post subject: Re: Fuel pump replacement |
I've been stranded TWICE by those stupid rods without clips. Finally learned my lesson!  _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7462 Location: Houston, Texas
Posted: Tue Feb 21, 2017 8:48 pm Post subject: Re: Fuel pump replacement |
What is this about clips? Is that alternator specific?
I put a new gas pump in mine. it consisted of a flange, gasket(s), rod, and pump. No clips. |
Posted: Tue Feb 21, 2017 8:59 pm Post subject: Re: Fuel pump replacement |
kawfee wrote: |
The original VW fuel pumps have a rocker pin with a groove. "C" clips fit in that groove and secured the pin to the pump. The cheap, aftermarket fuel pumps don't. It's very common for the rocker pin to be "peened" in place on the cheap fuel pumps but the "peen" doesn't hold thus the rocker pin slides out of the pump body, leaving you broken down when the pump stops pumping. This picture above shows the rocker pin that rotated out of the pump leaving me on the side of the road on a Bus I had just bought.
This is an original VW Pierburg pump. You can see the rocker arm is secured with clips. _________________ Contact me at [email protected]
heimlich  VWNOS.com
Posted: Tue Feb 21, 2017 9:02 pm Post subject: Re: Fuel pump replacement |
wcfvw69 wrote: |
This is an original VW Pierburg pump. You can see the rocker arm is secured with clips. |
I want one. |
Posted: Tue Feb 21, 2017 9:08 pm Post subject: Re: Fuel pump replacement |
kawfee wrote: |
wcfvw69 wrote: |
I want one. |
http://www.thesamba.com/vw/classifieds/detail.php?id=2022922
Shameless plug.. Here's one I rebuilt with an NOS rebuild kit. All three of my VW's are running these original VW/Pierburg pumps with NOS kits. These pumps are the best ones for generator equipped bugs. They won't fit on alternator equipment engines. They also have a internal fuel filter and cut off valve. _________________ Contact me at [email protected]
