busdaddy Samba Member
Joined: February 12, 2004 Posts: 52829 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Mar 02, 2017 11:08 pm Post subject: Re: 72 Westy - first bus |
Vacuum advance cutout, requires the bonus switch on the transmision, not critical for happy driving, more of a smog feature.
Breather connection for a 411/412, not used on a bus system, cap it.
Balance tube connector, connects to the tube pictured below.
That runs across the bellhousing tin and supplys the brake booster too.
Purge air for the charcoal canister, connects to the nipple on the end with no small nipple.
Where the other end of the charcoal canister connects. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2509 Location: Centreville, MD
Posted: Fri Mar 03, 2017 8:02 am Post subject: Re: 72 Westy - first bus |
Schwing wrote: |
I have an SVDA pertronix flamethrower. |
You'll be disappointed, start searching for a real VW 021-905-205E to replace it and put a module in that if you feel you must.
For now cap the nipple on the aircleaner side of the carb.
http://www.ratwell.com/technical/VacuumHosesCarb.html _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Mar 15, 2017 7:07 pm Post subject: Re: 72 Westy - first bus |
Finished assembling the engine on March 2nd and spent the next couple of days prepping the bus.
Here she is, in all her glory.
Installed the gas tank and replaced all breather lines. Filler hose was in great shape.
Tank cover.
Also replaced throw out bearing with a good German Sachs after degreasing trans bellhousing. I also cleaned up the engine bay while I could.
The weather got cold and nasty and my neighbor has a nice concrete floor and a pellet stove. We both enjoy drinking beer and playing vw so he let me use his garage. Took a few shots with the bus in my front yard.
This made way for my Chevy to take the engine over to his garage.
Thats my ugly mug
And in!
Amazing we didn't scratch my kids artwork. That meant a lot to me.
bolted on headers and muffler and called it a night.
The next day I did wiring, fuel lines, battery connectors. Lots of stuff to re-do in prep for the big start.
It actually didn't start because I had the dist gear in wrong. Feeling defeated I called it a night.
After buying a timing light the next night we got it to run!!!!! It idled dammmn high. I let it run for about 20min alternating RPM from 2k to 3k for breakin. After that it was flooded and wouldn't run again. I'd later discover a faulty fuel pump which flooded the cause and hydrolocked (really petrol locked). _________________ Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
Herman the oval
https://www.thesamba.com/vw/forum/viewtopic.php?t=388895 |
Posted: Wed Mar 15, 2017 7:31 pm Post subject: Re: 72 Westy - first bus |
Here is the first time it started. The valves are too tight and its idling at about 2600rpm. After this run I decided to remove the fuel pump and inspect. I discovered a slightly torn diaphragm so I had to dump the oil since the engine was flooded. My first clue was fuel dripping from the headers. I hand cranked to push the gas out of the pistons. and left it sit overnight with no plugs.
I replaced the fuel pump with my original pump which was also not rebuilt (a rushed move, looking back). This seemed to resolve the issue but I still had some problems with flooding. I could start the vehicle but if it were to stall it would be really tough to start again. If I pulled a plug, it would be soaking wet. I decided to reset and tackle this with a fresh approach....so I pulled my carbs and I will check everything on the bench. I also purchased a new fuel pump from aircooled.net.
I checked compression and the numbers look great so there was no damage done with the hydrolock. Phew!
Here are my averages:
1st cylinder - 122
2nd cylinder - 119
3rd cylinder - 114
4th cylinder - 123
I'd hope to see higher compression on a new engine, but this was cold and technically its not broken in yet, so I could see these numbers improve.
It ran really smooth.
Herman the oval
Posted: Wed Mar 15, 2017 7:44 pm Post subject: Re: 72 Westy - first bus |
Congratulations!, looks great so far, none of your "suprises" are really epic and all can be fixed, so far so good! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Wed Mar 15, 2017 7:59 pm Post subject: Re: 72 Westy - first bus |
If it keeps flooding, I'd look at something going on with the float(s). I had a problem in the notch (similar carbs). The metal spring piece that keeps the float in place has to be in just right, or it will stop the float from being able to float properly, which of course then floods the crap out of that side of the engine. Can't wait to see this one in person. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23919 Location: NYC/Upstate/ROW
Posted: Thu Mar 16, 2017 1:28 am Post subject: Re: 72 Westy - first bus |
Congrats on getting it going!
Your pictures reminded me of a gap in my knowledge..I had forgotten the 72-on Bus transmission no longer floats but has a hard top mount. No more chaining up the trans ( and much easier to install motor) _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
riverside66 Samba Member
Joined: June 04, 2008 Posts: 218 Location: Sparta, NC
Posted: Thu Mar 16, 2017 7:51 am Post subject: Re: 72 Westy - first bus |
What an inspiration this thread has been! Thanks for sharing! _________________ 1977 Standard Beetle -Sold-
1979 Transporter - "Wheatbread" -Sold- |
williamM Samba Member
Joined: August 07, 2008 Posts: 4342 Location: southwest Arizona
Posted: Thu Mar 16, 2017 8:36 am Post subject: Re: 72 Westy - first bus |
warm and fuzzy feeling aside--Great job. My only observation was the early part of the video showed the timing light with a bit of a studder --which cleared up quickly- so-- maybe your having a flamethrower prob. -- Not having one my self- I can't tell you if that system fails like a petronix if turned on and left to its own mortality.-
That motor will propel you down the road for ever- Now go have fun. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Thu Mar 16, 2017 1:49 pm Post subject: Re: 72 Westy - first bus |
Guys thanks! I'm not there yet though, but really close.
The timing was skipping a bit because the dist wasn't clamped, but very good eye!
I pulled the carbs and got them on the bench so I could check the needle valves and the float level.
Left carb float was 13.3mm and right carb was 13.4mm so I am happy with that. Bentley spec is 12-14mm so I am good with that. Needle valve is not sticking at all, so that checks out for my mental sanity. Who knows my disassembly could have freed something that wasn't right. I will never know.
And then it occurred to me, I messed with the chokes something fierce when I was fumbling with wiring. DOH, that (coupled with fuel pump) may have been my issue all along.
I lined both chokes up with their respective marks, assuming they need to have tension, not be loose cause you have to rotate them to line them up. Did I do it right?
Here are pics from checking float level and how I did it. I used a Mic to measure top of fluid level to top of bottom half of carb.
Hey Bill thanks for the heads up on the spring, mine matched the orientatiion in the Bentley diagram, so I think I am ok?
Needle valve worked great when flipped upside down.
Here I am adding fuel with the top installed. I stopped adding once it seemed to take no more and backup into the funnel. I then poured out funnel and careful removed fuel line and carb top. Then I mic'd it, pretty easy really.
Herman the oval
wcfvw69 Samba Purist
Posted: Thu Mar 16, 2017 3:11 pm Post subject: Re: 72 Westy - first bus |
Something you need to do that is VERY important is check your fuel pump pressure output. Whether it's a rebuilt original pump or a "new" one. Most of the VW carbs like around 3psi. It's not uncommon to see many "new" pumps put out over 6psi or more. That pressure can overcome the fuel cut off valves in the carbs.
In the bug world, they run Pierburg square top fuel pumps. The rebuild kits for them currently put out 6+ psi because the main diaphragm spring tension is too much.
So, next time you start it, check the fuel pump pressure. You can buy gauges with a "T" for $20-25 dollars if you don't have one.
Colin's site http://www.itinerant-air-cooled.com has an excellent write up on adjusting those dual carbs if you haven't seen it.
Congrats on your successful first run of your engine overhaul! As BD said, you just need to work out the minor kinks and then DRIVE IT!  _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Mar 16, 2017 3:27 pm Post subject: Re: 72 Westy - first bus |
After 45 years the marks on the choke heaters might mean squat, that bimetal spring changes over time and use. To set the chokes at room temp on the bench turn each one in the direction the choke plate closes until the plate is almost closed (~3/16") gap, you'll have to open the throttle a little to allow them to close freely. Once in use you may have to move them more or less to fine tune the warmup time. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
tewfiks Samba Member
Joined: February 19, 2016 Posts: 100 Location: Tallahassee
Posted: Thu Mar 16, 2017 3:36 pm Post subject: Re: 72 Westy - first bus |
This is awesome. I hope to follow in your foot steps in the very near future. _________________ 1968 VW Bus
1972 VW Westy |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2806 Location: Benton, Arkansas
Posted: Thu Mar 16, 2017 4:27 pm Post subject: Re: 72 Westy - first bus |
Awesome job getting closer and closer.
If I may make any suggestion, what really helped me with my dual carb setup was to visually see the numbers rpm's at idle and set timing at 3500rpms per Colin's and others suggested degrees of 28 or so BTDC.
Using a tachometer really made sense of what I thought I was hearing and was the actual numbers.
Cheers, and make sure to have some means of fire surpression for yourself and your beautiful family. To camping! _________________ The Bus Barn Ltd. Co.
Oct. β67 Double Cab (β68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
BusPriest Samba Member
Joined: October 08, 2014 Posts: 420 Location: Denver, Co
Posted: Thu Mar 16, 2017 6:49 pm Post subject: Re: 72 Westy - first bus |
Looks great. Love the artwork on the motor. _________________ 1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest. |
