Can1 Samba Member
Posted: Sun Apr 09, 2017 6:34 pm Post subject: Re: Rust Repair - Driver's Side Floor - Accelerator Pedal Area |
I think I have the same problem,
The passenger side is mint, look brand new, the drivers side unfortunately has been going on for a while. How did you seal that front seam above the headlights? Did you have to pull the dash? What type of sealer did you use. |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Sun Apr 09, 2017 7:22 pm Post subject: Re: Rust Repair - Driver's Side Floor - Accelerator Pedal Area |
| Can1 wrote: |
It was all external. Removed what I could of the old sealer and replaced it with Dynatron 550. Went from wet after every rain to dry as a bone. Others have found the antenna grommet to be at fault, and even window seals, but my problem was the seam. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
Can1 Samba Member
Posted: Mon Apr 10, 2017 5:48 am Post subject: Re: Rust Repair - Driver's Side Floor - Accelerator Pedal Area |
| Thanks for the reply. I have the carpet out and the insulation pulled up so it can dry. I'm hoping I don't have to cut too much out of the floor. At least it's not structural and the rest of the van is great. I bought it in Jan so didn't catch this because from underneath you can't see it. |
lorencjackson59 Samba Member
Posted: Thu Oct 01, 2020 7:03 pm Post subject: Re: Rust Repair - Driver's Side Floor - Accelerator Pedal Area |
You have inspired me to tackle this. The only panel I could find to purchase was $250 plus shipping
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19116 Location: Retired South Florida
Posted: Fri Oct 02, 2020 3:20 am Post subject: Re: Rust Repair - Driver's Side Floor - Accelerator Pedal Area |
| I wouldn’t waste my money on panels you don’t see to fix rust holes. I’d look for a donor part or fab my own out of sheet metal. Only you will know it’s not original. |
