JP02840 Samba Member
Posted: Sat Apr 22, 2017 7:38 am Post subject: 23 window brasil ???? |
I am new to VW. trying to validate a brasil bus.. claims to be original 1964..
question is
Did they manufacture 23 window/ sambas in brasil?
this bus has no belly pan
what is the date of this chassis code, BH370456?
my limited knowledge put s this number somewhere in the '70,s ?
Thank you for any input |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25988 Location: Olympia Wash Rinse & Repeat
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 946 Location: Las Vegas, NV
Posted: Sat Apr 22, 2017 9:31 am Post subject: Re: 23 window brasil ???? |
They never manufactured a 23 window bus in Brazil. They made 15 window buses. If the one you are looking at is a 23 window bus it means someone added the 8 skylight windows and the sunroof. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Sat Apr 22, 2017 9:39 am Post subject: Re: 23 window brasil ???? |
Thank you for responses,
yes, my concerns were correct.. the bus is listed here in classified as a conversion, and on ebay missing the sentence about the conversion..
I talked to the seller on the phone who completely lied about the windows, buyers beware!!
http://www.ebay.com/itm/1964-Volkswagen-Bus-Vanago...mp;vxp=mtr |
Posted: Sat Apr 22, 2017 10:51 am Post subject: Re: 23 window brasil ???? |
Definitely buyer beware when buying an old VW. Doubly so if you are not going to fly down and check it out.
Good at least you are doing research first!
Knew a fellow who bought a Split Window Bug back in the 1990s that was a show winner and owned by a well known VW collector down in Texas. It supposedly was full of NOS parts and no expense spared on it.
We offered to drive down to Texas from Seattle and check it out for him, and visit relations we have down that way. If the deal went thru we could tow it back for him for $500.00. He turned us down, bought it, and had it shipped up North.
First sign of trouble was the Bug had to be pushed off the truck when it would not start. Then the horn button was missing, later to be found under the rear seat. Front hood would not open, and I had to go up and open it for the shop. Button in the past had been sanded down to fit into a different steering wheel, to fit back in the VW steering wheel it had tape wrapped around it to make it a press fit. Engine was tuned up to turn out it was not firing on all cylinders due to low compression. Engine lid had bondo all over it, some places about 1/2" thick. Driver door window would not roll up, due to worn out lift mechanism. Later after the engine was rebuilt it turned out the transaxle needed the same. There were lots of other problems with it that were fixed. He ended up spending more than it cost to buy the Bug in the first place and later had to sell it off for less than he had in it.
Brings a new meaning to no expense spared... _________________ In Stereo, Where Available! |
Posted: Sat Apr 22, 2017 2:31 pm Post subject: Re: 23 window brasil ???? |
wow..
Unfortunate what people will do for a dollar,  |
