Ksprague Samba Member
Joined: April 29, 2015 Posts: 42 Location: Finger Lakes Region Upstate NY
Posted: Mon May 08, 2017 9:34 am Post subject: DIY Painting |
I've been researching and agonizing over the prospect of painting my Bus at home. I'm a novice (but thats the beauty of old buses, isnt it? - One is a novice at EVERYTHING . . . the first time) I do have a couple of friends with varying levels of proficiency in spraying, but my research led me to this strange, but appealing prospect of Roller Painting:
http://wiki.club8090.co.uk/index.php/Bodywork_and_Glass_Roller_painting
It seems like just the thing for Maggie the 72 Bay!
The process uses a special Rustoleum product called "Combicolor". The only catch is: it seems to only be available in the UK. Anybody else had experience with it or happen to know of a place to acquire it here in the states?
Thanks.[/url] _________________ Kevin
(1972 Campmobile "Maggie")
"The bus came by and I got on, that's when it all began."
~ Bob Weir |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon May 08, 2017 9:41 am Post subject: Re: DIY Painting |
Ksprague wrote: |
Thanks.[/url] |
hmmm... I have doubts... But I assure you that you can paint it that way, and it will have color. But I bet quality is pretty low, maybe look into prepping it and dropping it off at Maaco for a cheap paint? Just a thought. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Mon May 08, 2017 9:57 am Post subject: Re: DIY Painting |
Thanks Spike,
I know!- I was dubious too, but researching this kinda convinced me.
Seems like a good choice for a number of reasons.
The key of course is in the prep work, following the proper procedures and in getting the right product. That's where this combicolor seems to come in. It's not your off-the-Lowes-shelf, garden-variety, chalky Rustoleum.
(probably non EPA compliant or something) - hence the apparent inability to buy it on this side of the pond. _________________ Kevin
~ Bob Weir |
cmonSTART Samba Member
Posted: Mon May 08, 2017 10:14 am Post subject: Re: DIY Painting |
My local Ace Hardware can mix up custom colors of an oil based enamel for farm implements. I had a color mixed pretty darn close if not exact to what my bus is - I've been using this to patch up the paint while I do body work. It applies pretty well with a brush or roller for spot repairs and seems to be pretty durable.
I brought in a section I had cut out (but still had good paint), and they were able to go right off that for the color. _________________ '78 Bus 2.0FI
de K1IGS |
Joined: August 31, 2013 Posts: 13289 Location: North Carolina
Posted: Mon May 08, 2017 10:39 am Post subject: Re: DIY Painting |
cmonSTART wrote: |
I brought in a section I had cut out (but still had good paint), and they were able to go right off that for the color. |
I just did this on my bus for those areas not seen.
I took the fuel door & had it scanned & had a batch mixed up.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon May 08, 2017 10:54 am Post subject: Re: DIY Painting |
Using a alkyd enamel can work pretty well. The alkyd paint on my bay is pretty much as tough as a much more expensive automotive paint. It takes a couple of months for the paint to fully harden though. My wife and daughters just brushed it on about 10 years ago, though rolling would be better. On my Toyota I brushed the paint on and then went over it with a smooth roller, looks pretty decent. I did put additives in the paint to make it lie down better.
A brushable marine polyurethane can give a very nice finish as well. With a good job of "tipping" the paint it will rival a good automotive paint finish. |
Posted: Mon May 08, 2017 11:03 am Post subject: Re: DIY Painting |
What additives did you use? _________________ '78 Bus 2.0FI
de K1IGS |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2714 Location: Ocean Beach - San Diego
Posted: Mon May 08, 2017 11:27 am Post subject: Re: DIY Painting |
There are any number of threads here (and elsewhere - this topic ended up on any number of forums) on roller painting. One of the original ones was started by "69chargeryeehaw" or something like that.
Roll and Tip with Interluxe Briteside marine polyurethane can work if you are really good at it. I sprayed Briteside with a HF turbine sprayer in my front yard. Results were "ok" - and I could say that I had painted my own car.
Any further car painting on our cars (if any) will be done by professionals. And I include Macao and Earl Scheib in that category. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 893 Location: Fort Wayne, IN
richparker Samba Member
Joined: November 24, 2011 Posts: 7494 Location: Durango, CO
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52756 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 08, 2017 7:11 pm Post subject: Re: DIY Painting |
If I was forced at gunpoint to paint a bus with a roller I'd use urethane porch and floor enamel (custom tinted at the local paint store) and a short pile roller. I've done some farm equipment like that and it really does stand up well to the weather and last if prepped well first. It's never super shiny unless you spray but it's on the high end of semi gloss for a few years until the weather gets to it.
If you want something that's worth the effort to wash more than once a year later you really should buck up for real auto paint and spray it, roller jobs look OK from 20', but they are never stunning by any stretch of the imagination. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1790 Location: Mouth of the Columbia
Posted: Tue May 09, 2017 1:49 am Post subject: Re: DIY Painting |
I have maybe not mastered but made competent auto painting jobs on my bus. That being said I think a relatively good roll and broom job can look pretty good. Like BD says "from 20 feet away". But then most people are 20 feet away.
I have used Penetrol in alkyd boat jobs for a quarter century with great results. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
tjrm63 Samba Member
Joined: November 15, 2007 Posts: 117 Location: Jersey Shore
Posted: Tue May 09, 2017 5:31 pm Post subject: Re: DIY Painting |
painted my bus last year in my driveway, used a cheap Harbor Freight HVLP paint gun with my little compressor. Yes I used the Rust-Oleum oil based paint, I used 2 quarts of the Royal Blue and 2 quarts of white. I mixed the paint with acetone and Japan dryers, the acetone thins the paint and makes it go on smooth and it dissipates quickly un like paint thinner. The Japan dryers helps the paint cure quickly since oil base paints take a long time to dry. Took me 3 days to complete. I drive her everyday and have taken numerous camping trips all year, the paint is holding up very well, yes I know oil base paints aren't made for automobiles but I wanted a quick inexpensive paint job to make her look pretty for awhile |
OB Bus Samba Member
Posted: Tue May 09, 2017 6:07 pm Post subject: Re: DIY Painting |
tjrm63 wrote: |
painted my bus last year in my driveway, used a cheap Harbor Freight HVLP paint gun with my little compressor. Yes I used the Rust-Oleum oil based paint, I used 2 quarts of the Royal Blue and 2 quarts of white. I mixed the paint with acetone and Japan dryers, the acetone thins the paint and makes it go on smooth and it dissipates quickly un like paint thinner. The Japan dryers helps the paint cure quickly since oil base paints take a long time to dry. |
Looks good! What was your ratio of paint/acetone/Japan dryer? _________________ Larry in OB
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Tue May 09, 2017 6:20 pm Post subject: Re: DIY Painting |
First off. Its not the right way to do it. Not when you consider the potential value of the old classic you are fixing up. Do it right - its done once. This is a half ass band aid that will make your bus look super cool for awhile.
That said. I did it to my 76 panel. It was used as a truck with a past life as a suedo pedifile cruzer. I sprayed it on though with paint thinner mixed in at like a 20 to 80 cut? Ill have to ask my cuz.
See the results below - and as others have said there are many many many vids and threads on Rustoleum or Tremclad painting for the lazy baller on a budget.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7204810#7204810
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Tue May 09, 2017 6:23 pm Post subject: Re: DIY Painting |
Ya, but if I spend 8K on a paint job I actually have to worry about what happens to it.... _________________ '78 Bus 2.0FI
de K1IGS |
Manfred58sc Samba Member
Posted: Tue May 09, 2017 6:24 pm Post subject: Re: DIY Painting |
Rustoleum cut %50 , about 6 coats. Let it dry for a month before you do anything. Had to cut and polish a few runs. Turned out well for this application. High dollar paint jobs go to zero after 1 door ding, too much risk for me.
_________________ Fat chick owner/operator |
cmonSTART wrote: |
Ya, but if I spend 8K on a paint job I actually have to worry about what happens to it.... |
If you drive it period you will need to worry about it  _________________
t3kg wrote: |
1964 1500 S
Xevin  Samba Member
Posted: Tue May 09, 2017 6:25 pm Post subject: Re: DIY Painting |
notchboy wrote: |
Poor bears all covered up in grey paint  _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
