Wiring "quick/temp" fix
z33taxi
z33taxi is offline
PostPosted: Thu May 11, 2017 8:44 am    Post subject: Wiring "quick/temp" fix Reply with quote
This morning I went to drive the beetle to get some milk and fill the tires with air. I got about 100 yards when the car stalled out. I tried restarting thr car, but it only cranked. When i checked the rear I noticed smoke and the smell of electrical. It was the main wire going to the + side of the coil, it was roasted, as was the wire going to the fuel aolenoid on the carb.
The PO added a new section of wire at the rear firewall from the main black cable; seems it had broken and they just ran a smaller cable.
My question is, short of a new harness,which will be on order after typing this, what can I do? I had a trip planned in the beetle for next week and Ive been working all winter for this. I'm thinking of going farther back and running just that one cable. OR doing what the PO did,but wiring it better and with the appropriate gauge wire. Any help would be appreciated
I have the rear door card out and was thinking about splicing there. I dont know how possiable/probable it would be to run a single wire from the fuse box all the way back
My 1968 1600SP build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=665936
Cusser
Cusser is offline
PostPosted: Thu May 11, 2017 8:57 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
z33taxi wrote:
I dont know how possible/probable it would be to run a single wire from the fuse box all the way back
I've done exactly that on both my VWs, decades ago: out through grommet under driver front fender, under running board, back under. My gauge wires follow same path. I have also installed a 10-amp in-line fuse between the fuse box and the coil positive wire. Use cable ties, use existing grommets and nooks and crannies to route it.
Or go forward to where the #15 positive wire is OK, and solder in heavier gauge wire, use shrink tubing too. And see the part about the in-line fuse above.
z33taxi
z33taxi is offline
PostPosted: Thu May 11, 2017 11:18 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
I ran the wire in stock location. Wasnt too hard, I used a coat hanger to help guide it. It comes to a thick red wire that is tied into #2 on the fuse box
Frodge
Frodge is offline
PostPosted: Thu May 11, 2017 11:30 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
These wires all harden up with age. Some of mine seem like the insulation is a little hard. Is it necessary to do a complete wiring harness because of the 1 black wire that goes to the coil? Seems insane. I don't want to eventually have to run a whole new harness because of that. Say it ain't so. what do you folks do for a couple wires in the engine bay that have hardened up?
z33taxi
z33taxi is offline
PostPosted: Thu May 11, 2017 11:40 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
I guess do what I did and just run the indivual one as needed.
sb001
sb001 is offline
PostPosted: Thu May 11, 2017 11:43 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
IMO I do not think the smaller wire they ran is the issue, otherwise this would have happened a long time ago. What I believe happened was another wire connected to your + terminal on the coil fell off and/or shorted to ground somehow causing this issue. You should have 3 wires connected to the + coil terminal- power wire to the coil from up front, reverse light switch wire coming off the coil, and the other wire you mentioned coming off the coil going to your carb idle solenoid. This wire ALSO daisy chains off that and goes around the other side of the carb to your choke. Check ALL these wires and make sure one did not come loose.
Frodge
Frodge is offline
PostPosted: Thu May 11, 2017 12:23 pm    Post subject: Re: Wiring "quick/temp" fix Reply with quote
I agree with the above.
Another thought I had, is, I'm pretty sure these 3 wires in most cars have been rewired at some point, both from being yanked, pulled, shorted, hardened etc. What is the vw method of doing a repair I'd the wire is broken or hardened etc after it comes out of the harness in the engine bay....
z33taxi
z33taxi is offline
PostPosted: Thu May 11, 2017 2:15 pm    Post subject: Re: Wiring "quick/temp" fix Reply with quote
You are correct. It was a wire in the front that had come off and grounded. How are the reverse lights wired? I know they come from the coil, i know there is an inline fuse,
mondshine
mondshine is offline
PostPosted: Thu May 11, 2017 7:04 pm    Post subject: Re: Wiring "quick/temp" fix Reply with quote
On my Thing, I have added an in-line fuse to protect the "terminal 15" ignition circuit.
This is a Metri-pack 630 Pull to Seat ATC Fuse Holder from: http://www.cycleterminal.com/
These cars are engineered for "bare bones economy"; but to me, leaving the ignition circuit unprotected is a mistake.
Joel
Joel is offline
PostPosted: Thu May 11, 2017 7:55 pm    Post subject: Re: Wiring "quick/temp" fix Reply with quote
You would need a pretty heavy fuse in that as its now carrying the load of the entire ignition circuit - wipers, turn signals, coil, fan, instrumentation etc.
A better way to do it is to remove the coil wire itself from the fuse box and run an in line fuse there.
Everything else on the ignition circuit is already fused.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
sb001
sb001 is offline
PostPosted: Thu May 11, 2017 8:07 pm    Post subject: Re: Wiring "quick/temp" fix Reply with quote
Yes the wiring for the reverse light switch bolted to the transmission (activated when you select reverse gear) comes off the coil + terminal and has an inline fuse protecting it. After the fuse, that wire goes back around the fan shroud passenger side and down through a hole in the front engine tin to the switch on the transmission.
Then, another wire comes back off that switch, back up through the same sheathing and comes out right past that hole in the front engine tin and goes into a plastic "T" connector. (If you look down behind the fan shroud passenger side you should see this connector dangling there.) Each wire coming off the other side of the T connector is for your reverse lights, they both go back behind the tarboard and to either side of the car for left and right reverse lights.
z33taxi
z33taxi is offline
PostPosted: Fri May 12, 2017 12:43 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
Pic of the melted coil wire
z33taxi
z33taxi is offline
PostPosted: Fri May 12, 2017 12:51 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
Wasn't that how it was from the factory? Carry that load? Could I not throw an inline fuse in and still have to run to the fuse box as well?
Cusser
Cusser is offline
PostPosted: Fri May 12, 2017 6:45 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
Like I said earlier, I have a 10-amp inline fuse on the ignition circuit on both of my VWs. I happened to use cylindrical glass fuses but a more-modern inline fuse would be fine.
Joel
Joel is offline
PostPosted: Sat May 13, 2017 5:59 am    Post subject: Re: Wiring "quick/temp" fix Reply with quote
Sorry I was talking about Mondshines setup.
Coil wasn't fused from factory in vws, the cause of many fires.
You can remove every fuse in a vw and it will still start and drive, just wondering the have lights or wipers.
Just put an in line fuse on the coil wire same as cusser has done above.
