My bay is overcharging?!?
Serpent7
Serpent7 is offline
PostPosted: Tue Dec 27, 2011 1:04 pm    Post subject: My bay is overcharging?!? Reply with quote
I have a 79 vw bus. About every 6-9months i have to replace the battery (under warranty thank God). I have now at least found the problems and would like some help fixing it. I installed my new (3rd.) battery and checked the voltage at the battery cables. It's reading 18Volts. I'm pretty sure 12-14.4volts is the area it should be in. Any idea what it could be? 2 batteries ago I replaced the voltage regulator so i'm thinking it is not that. this time I purchased a new bosh alt. new bosh voltage reg., and new bosh battery. After installing these new units will it (should it) fix the problem? Any idea what else can it be, or any other checks i should do before installing?
Thanks...
2019 Audi Q5
2014 Volkswagen Touareg X
1997 Honda Shadow
1979 Kawasaki KZ1000
1979 Volkswagen Transporter
1973 Volkswagen Thing
busdaddy
busdaddy is offline
PostPosted: Tue Dec 27, 2011 1:13 pm    Post subject: Reply with quote
You'll want to test all the wires between the alternator and voltage regulator, sometimes the terminals push back out of the plug sockets and sometimes the wire breaks inside the insulation, if the reg isn't getting the signal that the alt is overcharging it'll happily keep telling it to make more.
Слава Україні!
Vince Waldon
Vince Waldon is offline
PostPosted: Tue Dec 27, 2011 6:43 pm    Post subject: Re: My bay is overcharging?!? Reply with quote
Normal charging voltage is somewhere between 13.5 and 14V, depending on temperature. 18V is way too high and causing you to boil your battery(s).
Serpent7
Serpent7 is offline
PostPosted: Wed Dec 28, 2011 2:20 pm    Post subject: Re: My bay is overcharging?!? Reply with quote
Yeah, kinda figured... gonna take busdaddy's advice and pull the Bus in the garage now for a hour and see what I can find out. too windy and too cold outside right now.
2019 Audi Q5
1997 Honda Shadow
Inane Cathode
Inane Cathode is offline
PostPosted: Wed Dec 28, 2011 5:49 pm    Post subject: Reply with quote
Find and test continuity (wiggle the plugs too) of the voltage sensing wire from the regulator to the battery. If it's corroded or dirty it will read too low of a voltage from the battery, and jack the voltage up until it sees 14v coming back.
Serpent7
Serpent7 is offline
PostPosted: Sat Jan 07, 2012 7:44 am    Post subject: Re: My bay is overcharging?!? Reply with quote
Right below the plug that connects to the volt. reg is a pigtail plug, right under that is a whole bunch of lots of wires (8-10) that have been taped together with using ducktape by previous owner, that's about a foot long. I have to unstick and cut all these wires from the ducktape. Already started, and its a huge mess! I'll try and snap a picture today and post. TCleaning up the tape alone is goingto take some time... Thanks previous owner!!!
2019 Audi Q5
1997 Honda Shadow
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jan 07, 2012 1:30 pm    Post subject: Reply with quote
we bought a new harness from the alternator to the VR and electrical system as the old one was hardened and the insulation cracked. The old plugs and connectors on ours were deformed from age and heat. I was going to rebuild it but there is a fellow here on TheSamba who makes them so we just bought his new one. That is absolutlely the solution unless you want to rebuild your own. The new one was the same gauge wire, flexible and new connectors that worked perfect. I threw in a new VR on principal since the car has close to 110,000 miles on it and our charging system has been rock steady.
http://www.thesamba.com/vw/classifieds/detail.php?id=829880
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Serpent7
Serpent7 is offline
PostPosted: Sat Jan 07, 2012 5:01 pm    Post subject: Reply with quote
This sounds like the best ticket!!! I'll purchase this next weekend...
Before I install the new parts, i'll take before and after pics and post them here. The OE wires are all messed up and have been re-taped, and cut and put back together, so with this I won't have those worries. Thanks Kent!
2019 Audi Q5
1997 Honda Shadow
Serpent7
Serpent7 is offline
PostPosted: Thu Feb 16, 2012 3:08 pm    Post subject: Reply with quote
Just ordered the Harness!!! That's the last piece of the puzzle. New Alt., new VR, new battery, and now new cables... Should be all good here by next week. I'll report back after everything is installed!
2019 Audi Q5
1997 Honda Shadow
pb24ss
Location: sitting around the fire with the bluegrass band - colorado
pb24ss is offline
PostPosted: Thu Feb 16, 2012 3:20 pm    Post subject: Reply with quote
i've seen wandering and really high voltage readings resulting from lose connections at the starter as well.
Serpent7
Serpent7 is offline
PostPosted: Thu Feb 16, 2012 5:42 pm    Post subject: Reply with quote
Good to know! I'll check all those as well. In the not so distant future I will be running dual batteries so I really want to make sure the electrical system is new, and up to par.
2019 Audi Q5
1997 Honda Shadow
SGKent is offline
PostPosted: Thu Feb 16, 2012 10:30 pm    Post subject: Reply with quote
99% of the time overcharging will be a bad regulator unless you are seeing AC at the battery from a bad diode in the alternator.
George Carlin:
1971 deluxe (sold)
1977 deluxe
Serpent7
Serpent7 is offline
PostPosted: Sat Feb 25, 2012 6:30 am    Post subject: Reply with quote
Kent, this is exactly what I was thinking... either the VR, or the Alt. I now have all the parts I need to finally rid myself of this problem:
1) Voltage Regulator
2) New Bosh Alternator
3) New Cabling from VR to Alt.
4) New Battery
I'm going to try and start today (wife willing). Then I have one more project to complete before the Spring Show-and-Go car show in NJ. Lowering it 9", and narrowing the front 5"! All parts arrived except rear boomerangs.... BusBoys is still making them.
Also before Bugout I want to have a dual battery setup with a nice inverter!
2019 Audi Q5
1997 Honda Shadow
drober23
drober23 is offline
PostPosted: Sat Feb 25, 2012 9:17 am    Post subject: Reply with quote
Just to add to SG's post. I had this happen to my '79 about 15 years ago. I was boiling my battery. It was the voltage regulator.
A new harness can't hurt either, but even if you get one I like SG's idea of also replacing the voltage regulator even if just on principle.
DJ
'75 Westfalia, '79 Deluxe, and some others...
(more busses than sense)
In a time of chimpanzees I was a monkey
Serpent7
Serpent7 is offline
PostPosted: Tue Feb 28, 2012 6:12 pm    Post subject: Reply with quote
I'm sure its the VR. I'll test the new VR first, and replace the wires. If its still overcharging I'll replace the alt.
2019 Audi Q5
1997 Honda Shadow
Manfreds78bay
Manfreds78bay is offline
PostPosted: Wed Feb 29, 2012 3:31 pm    Post subject: Reply with quote
My problem was the alternator wasn't charging the battery. I just ordered the harness and a new regulator as well. My harness was falling apart and might as well change the regulator while I'm at it. I bought a sweet combination battery last summer.
Let us know how it goes. fingers crossed.
Serpent7
Serpent7 is offline
PostPosted: Mon Jun 19, 2017 4:17 pm    Post subject: Re: My bay is overcharging?!? Reply with quote
Wow! Totally forgot about this post, many years later, it was the voltage Reg.
2019 Audi Q5
1997 Honda Shadow
Abscate
Abscate is offline
PostPosted: Mon Jun 19, 2017 5:49 pm    Post subject: Re: My bay is overcharging?!? Reply with quote
I think that qualifies for the Dorian Grey Post Award
Xevin Premium Member
Xevin is offline
PostPosted: Mon Jun 19, 2017 5:58 pm    Post subject: Re: My bay is overcharging?!? Reply with quote
Laughing
Thats a Wilde award.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
Jalabert
Jalabert is offline
PostPosted: Mon Jun 19, 2017 11:30 pm    Post subject: Re: My bay is overcharging?!? Reply with quote
Daft question, but is the voltage regulator properly secured and not vibrating? I've had weird charging issues in the past on other cars of similar vintage when it's worked loose.
'73 westy, 1700 type 4 with 34icts
