squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 784 Location: Langley, BC, Canada
Posted: Mon Apr 01, 2013 9:10 am Post subject: |
hans j wrote: |
How about MPG? Notice any increase with them? |
No.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1996 Location: Pittsburgh PA (ish)
Posted: Mon Apr 01, 2013 11:31 am Post subject: |
To clarify, i am "pissed off" because of what the salt is doing to the cars, and the rate at which it is doing it.
The van in question was purchased as a parts bus but recommissioned. It is not that rusty body wise. During the recommisioning, we replaced the entire exhaust system.
That was last January.
This Feb, I needed a new muffler already, and the bulk of the exhaust is already looking extremely crusty.
That's one year and 2000 miles. Not acceptable.
Yes, the first muffler failed prematurely, but it certainly failed due to rust, and having a dedicated winter bus makes you think a bit differently about what the road crap really is capable of.
I wll be doing some extensive and hopefully creative means of reducing future corrosion soon, the idea of wheel well liners is just one of the first steps.
I'm glad to hear some people are running them, but the fitment issues have me concerned. Photos would be nice, as well as some input from the man behind the supplier.
Shy of covering the whole car in axle grease, I'm open to anything. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry." |
1vw4x4 Banned
Posted: Mon Apr 01, 2013 6:35 pm Post subject: |
Craig,
First great thread. As you know I've given up the fight on my
City Syncro. With out yearly cleaning, sanding, and rust proofing, every vehicle is doomed. Its just a matter of time. You can slow the rust but you can't stop it. A lift in your new garage would be best, but I know how that is....
You think your pissed off... try 30 year of it!
Eric
Phishman068 wrote: |
Shy of covering the whole car in axle grease, I'm open to anything. |
svenakela Samba Member
Posted: Mon Apr 01, 2013 11:14 pm Post subject: |
I have successfully rust protected several cars with zincing. It is an industrial method where the surface is sand blasted and then coated with zinc. The zinc applicator looks like a mix between a paint gun and a welder. The wire is fed to the tip where it is electrified and melts. Air is blowing the 500 celcius degrees hot metal onto the surface.
One of the companies here that makes this kind of galvanizing use a HVLP sand blaster and they can clean any metal sheet without warping. They have an Alfa Romeo standing in the parking lot, unpainted. It has been there the last 25 years or so.
It is not needed to make it over the entire car, only the sensitive areas like wheel archs etc. Why not the entire exhaust? I'm pretty sure you can find a similar company in your hoods. I have three in my little area. |
kipkohl Samba Member
Posted: Tue Apr 02, 2013 12:14 pm Post subject: |
Gee, I don't know....maybe I'm doing something wrong but these don't seem to fit very well on my '91 Gl. The passenger side front went in OK, but there seems to be gaps around the lip of the well where water and mud could get in. The others could be trimmed to fit (and BD does state they might need to be) but even if correctly fitted I'm wondering if they're going to trap moisture around the edge of the wheel well. And, will trimming effect the tension needed to keep them in. Is there more to installing these than pushing them in and tucking the edge in? |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Tue Apr 02, 2013 3:10 pm Post subject: |
Another full-body option!
http://www.thesamba.com/vw/forum/viewtopic.php?t=548839 _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Tue Apr 02, 2013 5:14 pm Post subject: |
That is about the only thing that will stop the salt from eating your car alive. I have plenty of experience. While driving, the salt water get flung everywhere and will wick into every seam and crevise if it can. There it sits, rusting away. It is not uncommon after many washing and driving in the rain to crawl under the car and see white spots where salt is still wicking out of joints in the early summer here in upstate NY. To protect a non rusted vehicle every cavity, boxed section and inner panel has to be coated with a thin rust proofer and then the outside panels covered with heaver bodied coating to both keep in the thinner stuff and keep out the salt water. Reapplication/touch up would need to be done before every winter. Don't forget under the window seals as the pinch welds there start rusting pretty easily.
Here is the back end of a 88 van. Twenty five years of salty winters and it was shot. In all honesty that is a pretty good accomplishment. I doubt many vehicles could do that.
Here the salt water got to the front, side seat belt attachment point on a 88 van. I just pull the belt up and this is what I saw.
It is a lot of work to "rust proof" a vehicle every square inch inside and out needs to be protected. It can be done but not with out a lot of effort. Non salt belt areas of the country might not have as tough as a time. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
terence wilson Samba Member
Joined: March 16, 2013 Posts: 3 Location: Honeoye Falls,N.Y.
Posted: Wed Apr 03, 2013 1:28 pm Post subject: |
Hello jprato,i live in Honeoye Falls ,i have an 87 wolfsburg weekender i bought in november. It is in gc,and i have been washing salt off of it all winter.What kind of under coating are you using?thanks Terence |
Cdub! Samba Member
Posted: Sat Jun 24, 2017 8:13 pm Post subject: Re: Inner Fender Liners. |
Anyone have any recent experience with these??? Thinking of buying them; but would hope the fit issue with the right rear has been addressed. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Sat Jun 24, 2017 10:25 pm Post subject: Re: Inner Fender Liners. |
The old maintenance schedule called for a through inspection and reapplication of waxoil every fall. Very few owners in the states do that. Our 1987 had the optional additional undercoating and waxoil application performed at the factory when new. It spent the first 13 years in the midwest rust belt before we moved to California. It was treated yearly with waxoil, it is still rest free, seams included. BTW although it rarely see salty roads these days we still touch it up every fall with waxoil.
We tried a set of the liners. The fit was awful. FWIW I believe they are made in Poland. I would happily twice the price for good quality well fitting liners. |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4546 Location: East Kootenay, British Columbia
Posted: Sun Jun 25, 2017 11:37 am Post subject: Re: Inner Fender Liners. |
The fitment problems with these liners has to do with trying to tuck them under the outer wheel well lip.
If installed outside the wheel well outer lip they fit fine, but look like crap!
For the rears at least, using fender flares (Terrawagen) to cover up this join works great. Unfortunately because the front flares attach to the door this trick won't work for the front liners, so I'm running only the rears.
Looks good and works.
Been using since last summer. Happy with result. I do plan to take off both the flares and the liners every year or so to clean and wax underneath to protect against rust. So far the liners have kept the area protected by them very clean.
Of course I did a thorough cleaning and rust protection regime before installation. Just putting the liners on over a rust problem won't help any!
(edit) I got to thinking about the front liners again. Since the front flares do cover the wheel well lip when the door is closed maybe I will try fitting the front liners. The front flares are split between the portion which fits to the door and the small section that is attached to the body, this may present a problem but a little trimming may help. The edge of the wheel well liner will show when the door is open but that might be a small price to pay for added protection and maybe a little less road noise.
I'll play around with it when I have time (trying to finish the house this summer) and report back with pics. _________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
timichango Samba Member
Joined: April 07, 2012 Posts: 858 Location: Squamish, BC, Canada
Posted: Sun Jun 25, 2017 4:22 pm Post subject: Re: Inner Fender Liners. |
Subscribing. I think I need a little of this magic plastic protection — the salt around here in the winter is brutal, and unfortunately I need to run my van in the winter for at least another season until we can afford to pick up a beater truck for the salt season. _________________ . . . . . . . . . . . . . . . . . . .
Vroomhilde-San: Our 1991 Silver Vanagon Westy automatic + Subie EJ25 |
Cdub! Samba Member
Posted: Sun Jun 25, 2017 6:29 pm Post subject: Re: Inner Fender Liners. |
Thanks for the replies. The van's in Southern California so no salt or corrosives; just wanting to be proactive in keeping the inner fenders free of debris and anything that would promote rust. |
Posted: Tue Jun 27, 2017 10:00 am Post subject: Re: Inner Fender Liners. |
I'm assuming that those things are probably vacuum-formed — anyone try using a heat-gun to reform them slightly to resolve any fitment issues? _________________ . . . . . . . . . . . . . . . . . . .
Posted: Tue Jun 27, 2017 10:36 am Post subject: Re: Inner Fender Liners. |
timichango wrote: |
I'm assuming that those things are probably vacuum-formed — anyone try using a heat-gun to reform them slightly to resolve any fitment issues? |
Yep, I used a heat gun to form a pocket around the upper right rear shock mount. As for trimming, I only needed to cut a little off around the spring perch. _________________ Currently:
TinyPickle Samba Member
Joined: December 15, 2021 Posts: 190 Location: Slovenia, Europe
Posted: Fri Jun 17, 2022 2:53 am Post subject: Re: Inner Fender Liners. |
reviving this century old thread.
Does anybody know/have experience, how much more rubbing with bigger wheels is present, if any? lets say 215/75 R15 on stock syncro.
Cheers, _________________ God of rust, have mercy.
WIP - Offroad Spec Syncro - 1.9 TDI AFN - Build Thread
IG: syncro_brothers |
chrismsnt Samba Member
Joined: March 06, 2018 Posts: 259 Location: Cumming, GA
Posted: Fri Jun 17, 2022 5:09 am Post subject: Re: Inner Fender Liners. |
TinyPickle wrote: |
Cheers, |
Yes they can rub... I state this from experience! LOL Make sure they're fitted with screws or the likes. These are the ones that I have: https://www.brickwerks.co.uk/t3-plastic-wheel-arch-liners.html _________________ Chris
1989 T3 Vanagon 16" Syncro
1967 Squareback
https://vwvandiesel.com
Instagram @VW_VanDiesel |
Posted: Fri Jun 17, 2022 5:21 am Post subject: Re: Inner Fender Liners. |
chrismsnt wrote: |
TinyPickle wrote: |
Cheers, |
Yes they can rub... I state this from experience! LOL Make sure they're fitted with screws or the likes. These are the ones that I have: https://www.brickwerks.co.uk/t3-plastic-wheel-arch-liners.html |
Approximately how much of clearance would you say you lost inside the wheel well? you probably bolted them right?
Is there alot of mud and dirt caught behind them, ever noticed this? _________________ God of rust, have mercy.
Posted: Fri Jun 17, 2022 12:38 pm Post subject: Re: Inner Fender Liners. |
I've been using the liners sold by BusDepot for years. Mounting them works best if you also use TerraWagen Flares.
By putting the liners in so the edge is outside the wheel well they fit much better than trying to stuff them under the lip. This is where the TerraWagen Flares work to cover that join and look good.
I pulled mine off recently when doing extensive maintenance and the amount of grime under the flares was less than I expected.
The liners do a great job of reducing the amount of dirt/mud that spray around the wheel well. You still need to use something like Fluid Film before mounting to protect from salt corrosion.
Plenty of clearance with 215/65r/16 tires.
Pretty clean under here considering the roads I've been driving. The plastic liners clean easily with a hose.
redrosie Samba Member
Joined: November 05, 2019 Posts: 35 Location: Indiana
Posted: Sun Jun 19, 2022 3:35 am Post subject: Re: Inner Fender Liners. |
I am happy with my front installation, haven't done the rears yet.
I used rubber trim to help seal the gap.
I tucked the liner behind the fender flare.
A heat gun softens the plastic so you can push and stretch the liner for a tighter fit. Go easy with the heat, don't hurry this step. Hold the plastic to the shape you want and let cool. Do this step gradually.
My mud flaps help hold the liners in place. I had to trim then just a little.
I also trimmed the liners slightly they are sloppy from the factory.
Bulb trim.
https://www.amazon.com/gp/product/B07HR1N87N/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Also sprayed a few coats of Flexseal on body side of the liners to help deaden the sound.
This is not shown in the pictures, of course be sure to do this after the heat gun process. |
