dgsaz Samba Member
Joined: November 04, 2008 Posts: 584 Location: Phoenix / San Diego
Posted: Wed Jun 28, 2017 4:11 pm Post subject: Hose Clamps on Fuel Lines |
I have noticed that some do and some don't (put hose clamps on fuel lines).
I'm using the braided German fuel lines.
Is the pressure generated by the fuel pump not enough to cause the line to leak. I was surprised to not find any clamps, starting at the fuel tap, inline filter, fuel pump had one at the intake, no others.
Like I said, some do and some don't. Are hose clamps a good idea on fuel lines?
Or over kill?
dgsaz |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52775 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jun 28, 2017 4:19 pm Post subject: Re: Hose Clamps on Fuel Lines |
dgsaz wrote: |
Are hose clamps a good idea on fuel lines? |
VW thought so, that's why they put Ottiker style clamps on all the fuel lines at the factory.
The "finger puzzle" reasoning doesn't work on me, shure it's hard to pull off, but it still offers no resistance to internal pressure pushing it off from the inside.
No doubt there will be other opinions, this subject is like where to put a filter or what motor oil is best. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
kokanee Samba Member
Joined: April 15, 2007 Posts: 329 Location: Washougal WA
Posted: Wed Jun 28, 2017 4:29 pm Post subject: Re: Hose Clamps on Fuel Lines |
My opinion is if you think it's worth the chance of the fuel line coming off the don't run hoseclamps to me it's not worth the potential fire |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Wed Jun 28, 2017 4:56 pm Post subject: Re: Hose Clamps on Fuel Lines |
Always use clamps on fuel line connections. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Wed Jun 28, 2017 5:16 pm Post subject: Re: Hose Clamps on Fuel Lines |
The ethanol in our fuel line chews them up faster than fuel did 50 years ago. They need to be clamped. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Wed Jun 28, 2017 5:41 pm Post subject: Re: Hose Clamps on Fuel Lines |
Clampit! _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79493 Location: Sneaking up behind you
Posted: Wed Jun 28, 2017 5:52 pm Post subject: Re: Hose Clamps on Fuel Lines |
Clamps...
But then I wear suspenders and a belt. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Wed Jun 28, 2017 6:09 pm Post subject: Re: Hose Clamps on Fuel Lines |
it's hard to be leave this thread exzist..Jethro is that you? please mr clampit. |
ach60  Samba Member
Joined: May 14, 2001 Posts: 4137 Location: Santa Maria
Posted: Wed Jun 28, 2017 6:24 pm Post subject: Re: Hose Clamps on Fuel Lines |
dgsaz wrote: |
Or over kill?
dgsaz |
Learn not to burn, Read this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= _________________ Good Luck
Al |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20807 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Jun 28, 2017 6:32 pm Post subject: Re: Hose Clamps on Fuel Lines |
CLAMPS....
EFI Style...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Glenn  Mr. 010
Posted: Wed Jun 28, 2017 6:34 pm Post subject: Re: Hose Clamps on Fuel Lines |
ach60 wrote: |
dgsaz wrote: |
Or over kill?
dgsaz |
And this one: https://www.thesamba.com/vw/forum/viewtopic.php?t=131225
https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Member #1009
#BlueSquare
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7500 Location: Houston, Texas
Posted: Wed Jun 28, 2017 8:06 pm Post subject: Re: Hose Clamps on Fuel Lines |
Dale M. wrote: |
CLAMPS....
EFI Style...
Dale |
Are those best? |
74 Thing Samba Member
Posted: Wed Jun 28, 2017 9:05 pm Post subject: Re: Hose Clamps on Fuel Lines |
Those clamps are good since they are smooth on the inside and won't dig into the hose like hose clamps you get at your local hardware store.
There are spring clamps that are good as well as the crimp on ones like OEM.
McMaster Carr has a lot of different clamps as well as searching Ebay.
I am not a big fan of the woven outer German fuel hose with Ethanol. Look into some of the Gates hose that works with the blended crap fuel we have. |
slalombuggy Samba Member
Posted: Wed Jun 28, 2017 9:11 pm Post subject: Re: Hose Clamps on Fuel Lines |
kawfee wrote: |
Dale M. wrote: |
CLAMPS....
EFI Style...
Dale |
Are those best? |
Yes, they clamp all the way around the hose without digging into it and tearing the rubber. They are used primarily on fuel injection systems so if they can hold 60psi 3 psi won't be an issue
brad |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71520 Location: Phoenix 602
Posted: Wed Jun 28, 2017 11:02 pm Post subject: Re: Hose Clamps on Fuel Lines |
bugguy1967 wrote: |
Yes, this. The fuel line weakens and can slip off under pressure.
You really don't need it on the inlets since they are not under pressure but it doesn't hurt.
It depends how often you check your lines.
If I am using the woven lines I check them once/year.
In the olden days you had to cut the ends of the German woven lines to get them off - that is how well they worked with old quality lines and non-ethanol gas. Even so, VW added clamps at a certain point. _________________ How to Post Photos
Posted: Thu Jun 29, 2017 6:26 am Post subject: Re: Hose Clamps on Fuel Lines |
74 Thing wrote: |
Places like Summit racing has bag of 10 for $X.xx....The come in all sizes...
https://www.summitracing.com/search?SortBy=BestKey...e%20Clamps
jason Samba Member
Posted: Thu Jun 29, 2017 6:27 am Post subject: Re: Hose Clamps on Fuel Lines |
In Ca. here and the German cloth lasts only a year sometimes 6 months. Hose clamps will hold the piece on underneath but not the hose. I usually only use on the pressure side. I changed to SS hard and ptfe. I was tired of changing the lines. |
Glenn  Mr. 010
Posted: Thu Jun 29, 2017 6:40 am Post subject: Re: Hose Clamps on Fuel Lines |
I looked at 2 styles of clamps. One was an upgraded work drive and the other was a band clamp. Both were stainless steel and both had rolled edges so they don't cut the hose.
I went with the ABA band clamps. _________________ Glenn
Member #1009
#BlueSquare
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23130 Location: Oklahoma City
Posted: Thu Jun 29, 2017 6:54 am Post subject: Re: Hose Clamps on Fuel Lines |
74 Thing wrote: |
Lets be clear here.....because when people do a search on nuggets of information......they may not bother to read important details like....APPLICATION.
Spring clamps are excellent for carburetor fuel lines.....but are NOT to be used with fuel injection.
If you get a split in the inner plies of the fuel line in a fuel injection system where pressurized fuel is traveling laterally between plies......which is very common.....the hydraulic pressure can literally defeat the spring pressure and cause a line to blow off.
Ray |
dgsaz Samba Member
Posted: Thu Jun 29, 2017 11:35 am Post subject: Re: Hose Clamps on Fuel Lines |
That settles it.
I'm going to clamp the entire fuel system.
I will not put the inline filter in the engine compartment.
dgsaz |
