racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Sat Aug 22, 2015 3:56 am Post subject: |
Since I'm fitting a tach I moved the clock over to the passenger side and left it as 6v never even bothering to see if it worked or not when I restored the gauges....why I didn't just doesn't make any sense right now but in any case I ended up with a 12v T3 clock for parts to make my tach and decided to see if the movement worked but no potatoe. bummer.
Looked on the samba and came across the clock repair guide and sure enough mine had the "blown" fuse deal going on and I thought A HA! that's it! Re soldered the link but still no joy. Closed the contact manually and re connected 12v to see it energise and wind up the mechanism but no tickety tick......closed the contacts again and sprayed the gears and moving parts with spray oil manually operating the gears back and forth, tried again and wadda ya know, success!
Quite neat to watch it work and wind up every minute or so, seems to keep accurate time as well so far.
With the 12v movement working I took the clock apart and swapped out the 6v movement converting the clock to 12v.
Not overly useful or productive but quite neat for it too work. _________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1397 Location: Newfoundland
Posted: Sat Aug 22, 2015 7:38 am Post subject: |
reay wrote: |
t3kg wrote: |
Anco and Trico seem to be the two companies that still make refills. Not sure if they will fit the Bosch blade holders or not. |
These actually say they are not for Anco holders.
I've got some SWF rubber refills for T-3s if you still have your original blades... Would a couple of these help John?
_________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
Posted: Sat Aug 22, 2015 3:13 pm Post subject: |
Thanks for the offer Bob, I think the new SWF blades I got and painted silver are going to work just fine so I'll stick with those.
What I do need is a 12V wiper motor......
In saying that I removed both the push button dash and the wiper motor yesterday in order to bench test things to help understand what the f*&k is going on, here's what I think. The voltage dropper will not allow enough current to pass through it to satisfy the motor.
I ended up wiring in series a 6V 45W bulb (should be around 7.5amps draw) with the wiper motor and with that it runs at about the right speed, could be a little faster so a higher wattage bulb will allow more current.
I also tried a 6v 21W bulb which made it run slower confirming what I thought.
Now a 45w bulb glowing under the dash isn't all that appealing so some sort of current limiter would be needed. _________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23376 Location: Kimball, Mi
TheFop Samba Member
Joined: February 03, 2014 Posts: 302 Location: Auckland - New Zealand
Posted: Mon Oct 19, 2015 12:47 am Post subject: |
I was getting worried you'd forgotten the project there for a while with all your other goings on
Hoped to grab a chat yesterday but you left before I caught up with you.
Love the shiny new bumpers, fingers crossed they fit better than the Type 14 ones Kiwighia and I have. _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
Stock 69 LHD Karmann Ghia Coupe - Driver
67 New Zealand Spec Beetle - Being rebuilt
63 New Zealand Spec Beetle - Going Baja!
86 T25 Westfalia - Family Fun car |
TheFop Samba Member
Posted: Mon Oct 19, 2015 2:26 am Post subject: |
racoguy wrote: |
Bobnotch wrote: |
racoguy wrote: |
Stainless..........fresh off the plane.
Beautiful. Are they from PTT? |
No these are made by Harrington |
Great choice _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
simppa Samba Member
Posted: Mon Oct 19, 2015 8:06 pm Post subject: |
I couldn't find those bumpers from their website, are those custom made to you? |
tanhis Samba Member
Joined: July 23, 2005 Posts: 659 Location: Rauma Finland
Posted: Wed Feb 10, 2016 3:25 am Post subject: |
simppa wrote: |
http://www.groupharrington.com/en/part/929/vw-karmann-ghia-t34-bumpers.html _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
Walter64 Samba Member
Joined: December 06, 2013 Posts: 146 Location: Sydney
Posted: Wed Apr 06, 2016 3:25 am Post subject: Re: New Zealand T34 Ghia project |
Hi John, how is the progress on your resto, have seen any posts for a while.
I have started restoring my T34, unfortunately mine was in an bad accident previously with shoddy repairs and it affected the structural integrity and door openings amongst other things.
I have a 5mm difference between one side to the other. Do you have any measuremnts for your door openings, from the front door pillar to the striker?
I don't know which side is correct because both sides of the car were hit. _________________ VW fan & Real Estate Agent at www.argyproperty.com.au
66 RHD teak T34 karmann |
Disc Samba Member
Joined: September 24, 2009 Posts: 632 Location: Europe
Posted: Thu Jul 07, 2016 3:07 am Post subject: Re: New Zealand T34 Ghia project |
Long time, no see. Any updates>? _________________ The glory never gets old, just need new paint.
Nick |
Disc Samba Member
Posted: Wed Jul 05, 2017 5:14 am Post subject: Re: New Zealand T34 Ghia project |
An year later... racoguy, are you OK buddy? Any news here? _________________ The glory never gets old, just need new paint.
Nick |
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Chula Vista, CA
Posted: Wed Jul 05, 2017 8:14 am Post subject: Re: New Zealand T34 Ghia project |
WOW! Great work! Really like the look of these T34s and this one is super nice! _________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
1965 Bug (SOLD) |
Posted: Wed Jul 05, 2017 8:37 am Post subject: Re: New Zealand T34 Ghia project |
Disc wrote: |
An year later... racoguy, are you OK buddy? Any news here? |
I believe he's got it up and running, but don't know any more than that. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7770 Location: Santa Cruz
Posted: Wed Jul 05, 2017 10:01 am Post subject: Re: New Zealand T34 Ghia project |
Yeah, what the hey??
This picture was posted to another thread a couple of days ago..
_________________ Bus Motor Build
It does not exist! |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4621 Location: Pasadena CA/DTLA soon China
Posted: Wed Jul 05, 2017 3:49 pm Post subject: Re: New Zealand T34 Ghia project |
Clatter wrote: |
Yeah! He's enjoying his type 34. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
Posted: Thu Jul 06, 2017 2:46 am Post subject: Re: New Zealand T34 Ghia project |
Indeed it runs and drives, still tuning to do on the ecu but so far runs ok on a stock standard Golf GTI ecu which is pretty encouraging.
Have a bunch of things I'm not happy with but will remove those parts and rectify those.
One of them is the windshield seals, the trim does not sit in the middle of the Simon Kelley seals but so far have not found a better solution. _________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
Posted: Thu Jul 06, 2017 7:04 am Post subject: |
racoguy wrote: |
Do not fear friend, lots of engine related posts to come.....I have a vast plethora of ideas to carry out  |
