andrewtf Samba Member
Joined: August 10, 2011 Posts: 670 Location: Illinois
Posted: Sat Sep 17, 2016 6:06 am Post subject: non-vinyl Riviera canvas? |
I am redoing my "new" '77 bus (Murphy) which is getting - by necessity - a total makeover. The top canvas was really toasted so it needs to be replaced. I would really prefer to not use the yellow or white vinyl type, but something more 'natural' like hemp. At one time I thought I saw someone making them, but now all I can find are the vinyl type. Does anyone know of a company that makes them out of an alternate material?
Additionally, the canvas comes in one of two circumferences (176" or 184" circumference). Mine was so far gone that this measurement could not be determined. Should I just get the larger one and potentially just have a 'looser' canvas?
And just in case I was not clear enough..... it is the larger riviera pop top.
Thanks - Andrew
_________________ '75 Riviera - 'BIG EMMA' - Travel Beast
'77 Riviera - 'Murphy' - Daily driver in nice weather
'78 Westy - New to the family
'63 Austin Healey - sitting alone in a museum |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2575 Location: MICHIGAN
Posted: Sat Sep 17, 2016 6:30 am Post subject: Re: non-vinyl Riviera canvas? |
user blue71 had a amish connection, but I don't think they had a riv/chc/sportsmobile template to go off of. you would need the bigger canvas if your lift mech was inside the old canvas. smaller if the scissor action was on the outside. look at your old screw holes on the roof to see how it was. |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1937 Location: anchor pt. alaska
Posted: Sat Sep 17, 2016 7:37 am Post subject: Re: non-vinyl Riviera canvas? |
Any compitent upholstery shop that does alot of boat tops should be able to make you a replacement . Have them make it from sunbrella canvas which comes in many colors. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4342 Location: southwest Arizona
Posted: Sat Sep 17, 2016 8:48 am Post subject: Re: non-vinyl Riviera canvas? |
I'm doing that exact same project- so if you can get a discount on doing 2 at once- PM me with the details. not a fan of yellow or vinyl either. Also check the nylon rollers mine had 4 broken ones -seemed to work But will be better soon.
Take good care of that rust above the B pillar- mine cut thru and ate up the door channel and flooded all the way back to the rear hatch hinges
-[img][/img] _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
blue71 Samba Member
Posted: Sat Sep 17, 2016 10:00 am Post subject: Re: non-vinyl Riviera canvas? |
I tried to post this in the thread from my phone but it says "session invalid" despite being logged in:
Thanks Alman72.
If somebody has a so so Riviera canvas of the different years that can be used as a template (I don't know year cut offs for size) they will give a prototype discount. It would be the tan marine type canvas of the Westy versions. The last I knew they can get weird yellow vinyl if somebody absolutely wants that stuff, but the price was different and they only buy a giant bolt at a time (that material isn't used for their regular boat and other cover business).
I tracked a so-so one down before from a supposed 1975 and gave it to them but the measurement for the opening was in the 70s inch range according to their equipment. I don't know what happened to it when the patriarch moved to a new house and made a bigger shop. I'd guess it's MIA. _________________ R.I.P. Mom
A.K.A.: "Doc", "Subwoofer Nick", "the LEAKOIL parts whore", "Amish canvas connection" |
Posted: Sat Sep 17, 2016 12:32 pm Post subject: Re: non-vinyl Riviera canvas? |
Mine is a 78 and looks like your pic the scissor is on the outside. it is complete but zippers and fly screen is shot- I f you need a templet and have a supplyer- let me know- Tan would be supper.
[img][/img]
Edit- found your web site- left a note- nice prices- what material do they use? and you westy turn around is couple of weeks- i imagine prototype would be longer? < Maybe find a few more needing tents - would make it worth while? _________________ some days I get up and just sit and think. Some days I just sit.
blue71 Samba Member
Posted: Mon Sep 19, 2016 5:14 am Post subject: Re: non-vinyl Riviera canvas? |
They use a tan marine grade type canvas fabric. Bay westy versions are made to order, no need for a group buy. That will be the case with all canvases after a prototype is made and test fitted with positive results. They don't want to make multiples of a prototype, have a problem due the template condition, and have to remake a group of them.
I would guess a prototype could take about a month to do, everything depends on which family members are available to do what step and if they are swamped with boat cover orders for this coming winter from people with boats that they take on Lake Erie. The price to me is an unknown for a bay Riviera as it uses more fabric than a bay westy and they use materials cost as a main component in determining their price (late bay uses more fabric than early bay, thus they cost more, but within reason). _________________ R.I.P. Mom
Posted: Mon Sep 19, 2016 5:45 am Post subject: Re: non-vinyl Riviera canvas? |
I would be in on this for sure.
I'm not sure I would be good for a prototype (although I would be happy to be that guy) since I have a winter of body work to get done (maybe more) so I would n't be ready to install it until maybe next June or so. I do need the same one as WilliamM, so maybe we can get something going.
I would probably not select tan as my color, but I'll take that over white or yellow for sure.
Whatever roll I can play in getting this going, I'm up for.
thanks - Andrew _________________ '75 Riviera - 'BIG EMMA' - Travel Beast
Ives676 Samba Member
Joined: June 20, 2013 Posts: 274 Location: Rogers, AR
Posted: Mon Sep 19, 2016 7:47 am Post subject: Re: non-vinyl Riviera canvas? |
Hey Fellow Riviera Owners.
About two years ago I contacted country homes campers about a replacement canvas. They got in touch with a company in Washington or Oregon that makes the riviera canvases in yellow and white to ask about other colors. They told me they could make the canvas out of multiple fabrics and had lots of colors to choose from. I went with a gray outdoor vinyl (the same material as the yellow and white canvas).
Here is my original canvas next to the new gray one. Notice how worn out the elastic is in the corners.
_________________ 1974 Riviera - Subaru EJ22
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=630031 |
blue71 Samba Member
Posted: Mon Sep 19, 2016 8:46 am Post subject: Re: non-vinyl Riviera canvas? |
If you don't mind my asking, what did the gray replacement cost? I haven't really delved into the prices for Riviera and Sportsmobile canvases, just the bay westy versions to have an estimate of what the catalogs cost to see if the Amish could match or potentially beat those prices. So far they have been able to on the bay westy.
A few people have told me "It's very similar to the quality of the high end catalog one but for the price of the cheap one." Take that as you wish. Granted, nothing beats an original vintage NOS part when it comes to fit, but theirs come darn close. _________________ R.I.P. Mom
Posted: Mon Sep 19, 2016 8:59 am Post subject: Re: non-vinyl Riviera canvas? |
I believe it was about $400 shipped.
I found the name of the company that makes the replacements: [url]commercialfabricproducts.com[/url]
When I talked with commercial fabrics products they gave me lots of options to choose from in durable outdoor fabrics that have UV protection. They also said they were the original manufacturers for ASI/Riviera for the canvases.
I still haven't installed my canvas yet. I was planning on replacing the canvas and just using my bus as is when I first bought it. But the more I drove it and started fixing little things the more annoyed I got at the previous owner's hacks and fixes. I decided to just do a full restoration.
Just over three years later I am closer than ever with getting to the canvas though. I have the pop top repainted and installed and just ordered a replacement tack strip. Soon...... _________________ 1974 Riviera - Subaru EJ22
Posted: Tue Sep 20, 2016 10:31 am Post subject: Re: non-vinyl Riviera canvas? |
I did a little checking.....
The Commercial Fabrics Manufacturing will do the vinyl top in yellow, white or grey for right at $400. It is not listed on their website, but I called and talked to them.
For an additional +/- $140 they can do any Sunbrella Fabric an Owner wants select. They suggest the Sunbrella Marine Fabric line for these tops.
Hope this helps someone beside me. _________________ '75 Riviera - 'BIG EMMA' - Travel Beast
DougClink Samba Member
Joined: August 14, 2006 Posts: 93 Location: Fremont, Michigan
Posted: Sat Aug 19, 2017 5:45 pm Post subject: Re: non-vinyl Riviera canvas? |
My bay window is a sports Mobile. Is this exactly like the Riviera? It is a 1970 with the mechanism on the outside. In other words, can I purchase a Riviera top for my Sporty?
_________________ Air-cooled Preservation Society
Join us on Facebook!
1957 Sunroof Beetle • 1964 Beetle • 1958 Westfalia Subhatch • 1955 Baja Bus • 1970 Sportsmobile |
Posted: Tue Aug 22, 2017 5:49 am Post subject: Re: non-vinyl Riviera canvas? |
It looks very similar but I wouldn't take the $400 gamble.
If I were you I would take out the canvas and take it to a local upholstery shop to have them make a new one based off the old. Or get in touch with the samba member blue71 (seen in this thread) who had an Amish connection for making new canvases. _________________ 1974 Riviera - Subaru EJ22
Posted: Tue Aug 22, 2017 7:54 am Post subject: Re: non-vinyl Riviera canvas? |
Thats what I ended up doing- My local guy did it in tan with velcro instead of zips for right round $200. And left it open ended so I can fit it and bring it back for final stitching. Problem solved- and the original yellow is repairable . _________________ some days I get up and just sit and think. Some days I just sit.
BennyynneB Samba Member
Posted: Tue Nov 07, 2017 2:58 pm Post subject: Re: non-vinyl Riviera canvas? |
Is there any updates to the amish Rivi canvas? How did the country campers one work? I see Gowesty is selling a Rivi version now. Has anyone installed theirs? Im trying to get my 75 canvas replaced this winter....just not wanting the raincoat yellow! |
KentABQ  Samba Member
Joined: September 11, 2016 Posts: 2481 Location: Albuquerque NM
Posted: Sat Jan 11, 2020 11:17 am Post subject: Re: non-vinyl Riviera canvas? |
So Andrew...
What material did you eventually decide to use for Murphy's top? |
Posted: Sat Jan 11, 2020 12:55 pm Post subject: Re: non-vinyl Riviera canvas? |
Country Home Campers did it.
I got grey canvas with an added front window/screen.
The typical pop top canvas only comes with the two long side windows/screens.
Fit great, _________________ '75 Riviera - 'BIG EMMA' - Travel Beast
Posted: Sat Jan 11, 2020 1:18 pm Post subject: Re: non-vinyl Riviera canvas? |
andrewtf wrote: |
Fit great, |
for 400? |
