1 5/8 merged header gasket part number
Sergeantz
Sergeantz is offline
PostPosted: Sun Aug 27, 2017 8:58 pm    Post subject: 1 5/8 merged header gasket part number Reply with quote
So, I did a search. No luck. I'm trying to replace the gasket between the merged header flange and the stinger. I've got a mass leak there and wasn't to swap it out. I'm trying to see if AutoZone has something that will work but I have no part number. It's killing me because they're all over the internet but none of the part numbers match their systems. Am I out of luck?
Thanks.
-Noah
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Aug 28, 2017 3:54 am    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
Not a part you can buy at a auto parts store.
Which brand header?
You could just make your own from a sheet of gasket material.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Sergeantz
PostPosted: Mon Aug 28, 2017 8:05 am    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
I thought so.
It's the stainless steel EMPI setup. I think I'm going to have to cut my own.
Thanks brother.
mark tucker
mark tucker is offline
PostPosted: Mon Aug 28, 2017 4:12 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
I would try to go with copper or aluminum...or...cb perf has some that are supposed to be pretty good.I think there a composit type.
scubaseas
scubaseas is offline
PostPosted: Mon Aug 28, 2017 5:01 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
Try the walker exhaust catalog Might be a 31366
NAPA carries the walker line
http://www.walkerexhaust.com/products/accessories-hardware
Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired
sherco_chris
sherco_chris is offline
PostPosted: Wed Jun 04, 2025 1:06 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
I know this is an 8 year old post but I need a small 3 bolt header flange gasket and I think it might be a Felpro 60575, which my local Autozone has in stock.
I'll report back.
ps2375
ps2375 is offline
PostPosted: Wed Jun 04, 2025 1:29 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
This is why I had a V-band connection put on my merge, no gasket and no leaks.
NJ John
NJ John is offline
PostPosted: Wed Jun 04, 2025 1:42 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
That’s next, tig weld V band flange’s to the heads!
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
my3bugs
my3bugs is offline
PostPosted: Wed Jun 04, 2025 2:07 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
i checked CarCrafts website and i dont see it , but some time ago they sold me a copper 3 bolt gasket for my headers 1 1/2 , i been using or re using it for years . ya might ask em .
https://carcraftstore.com/search.aspx?find=copper+gasket
Jbugs has copper 1 5/8 copper exhaust gaskets but not the flange .
Mr. 010
Glenn is offline
PostPosted: Wed Jun 04, 2025 7:06 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
CB Performance
https://www.cbperformance.com/product-p/3694.htm
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sherco_chris
PostPosted: Fri Jun 06, 2025 12:33 pm    Post subject: Re: 1 5/8 merged header gasket part number Reply with quote
I can confirm that the Fel-Pro 60575 gasket fits and is available from my local FLAPS. It is the collector gasket for a 1977-1987 BMW 6 series 2.7, 3.0 and 3.2 liter. The CB Performance gasket is much better, but this was on the shelf and I could get rid of that raspy exhaust leak!
