Reference for tail light placement 56-61
hootowls
hootowls is offline
PostPosted: Sun May 30, 2010 9:58 am    Post subject: Reference for tail light placement 56-61 Reply with quote
The following diagram is from "Der Motor Test," July 1958, showing the rear view drawing of a European bumper 58 sedan with relative dimensions for the location if the tail light housings. Note that "leer" means "empty" and the units are in millimeters. Thought the drawing might be useful for the ovals and the squares as this is common to both.
Another post
Rome wrote:
stale air wrote:
Despite the rusty, but level bumper, this should be a "sticky" for correct taillamp height for oval, or even thru-'61 restorations. We see many redone Beetles where the snowflakes are mounted too high.
OvalWindowBucket
OvalWindowBucket is offline
PostPosted: Sun May 30, 2010 10:56 pm    Post subject: Reply with quote
The height of my snowflakes is mismatched, thank you very much for this..
envycustoms
envycustoms is offline
PostPosted: Mon May 31, 2010 10:55 pm    Post subject: Reply with quote
heres a diff view on the subject Wink
56 SunRoof (o\U!U/o) "Hood Fellas"
Damn.. not another car on earlies!
www.EnvyCustoms.Tumblr.com
Chip Premium Member
Chip is offline
PostPosted: Fri Jun 04, 2010 8:55 pm    Post subject: Reply with quote
I prefer the second one, otherwise my lights would end up way to high, the reference to the ground can only be used on a bug sitting at stock height with out any rear end sag. Good luck finding one of those, except on a fresh resto.
Volumex
Volumex is offline
PostPosted: Fri Jun 04, 2010 9:46 pm    Post subject: Reply with quote
You can use the distance from the bottom of the popes nose to the centre of the snowflake - it is obviously 153mm (679-526) and independent of the height of the car.
Just need a stringline, spirit level & tape measure - and three hands.
Chip Premium Member
Chip is offline
PostPosted: Sat Jun 05, 2010 6:53 am    Post subject: Reply with quote
Good point, I'll work on the 3rd hand thing Laughing
RJoval
RJoval is offline
PostPosted: Sat Jun 05, 2010 2:27 pm    Post subject: Reply with quote
for those that think there tail lights are going to be to high using diagram one its simple,
measure the height of your number plate light off the ground because it is very rare that the holes in your bonnet have been filled and need redrilling, then subtract the difference from the height that is shown on the drawing, this is the difference then subtract that from all other height measurements and away you go.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Jun 06, 2010 10:31 am    Post subject: Reply with quote
Another related thread and specs.
http://www.thesamba.com/vw/forum/viewtopic.php?t=354891
Still no absolute proof.
TSLAVO
TSLAVO is offline
PostPosted: Thu Aug 31, 2017 8:18 pm    Post subject: Reply with quote
Trying to get my 57 tail light position right. Couldn't get it right and found out my fender measurement joining rear apron is out. My apron is original. Could 57 fenders have different dimension?
Kjell Roar
Kjell Roar is offline
PostPosted: Fri Sep 01, 2017 2:31 pm    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Might be aftermarket fenders.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
AlteWagen
Troll
PostPosted: Fri Sep 01, 2017 5:52 pm    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Strange, I just measured two original fenders I have, the euro is off a 58 and the non ribbed is from a 60. Putting the hook from the tape measure and holding it flat against the curve of the fender I get 13.5 for both.
Official Dual Carb Thread
TSLAVO
TSLAVO is offline
PostPosted: Sat Sep 02, 2017 9:05 am    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Possible my fenders are aftermarket. Thinking of my rear apron is very likely to be original to 57, measurement of fenders adjoining to apron should be correct.
TSLAVO
TSLAVO is offline
PostPosted: Sat Sep 02, 2017 9:08 am    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Could you get 15" and 6 3/4" as per the picture? If not, what are yours?
Snort
Snort is offline
PostPosted: Sat Sep 02, 2017 4:01 pm    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Here are some measurements from my 57 Bug original fender.
1. I measured 13 5/8 inches from the bottom to the bend
2. This one is an attempt to get a square alignment off the apron line but that line is not square so it's averaged.
3. Edge of overrider support hole to wire hole.
4. Edge of overrider support hole to top mounting hole.
5. Square alignment from rear quarter panel line.
TSLAVO
TSLAVO is offline
PostPosted: Wed Sep 06, 2017 8:53 pm    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
I finally found the problem after taking the fenders and fitted to body at body work shop. The bend on fenders do not fit perfectly to the body with some gaps. I measured the rear apron from bottom to where the bend should sit and get exactly 13 5/8 inches.
Thanks for everyone who respond to my post and i am happy to get the right position. The picture guide in this FAQ is pretty helpful.
pdxeuro
pdxeuro is offline
PostPosted: Mon Jul 05, 2021 5:48 pm    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Disappointing weekend as I starting to look deeper at the body of my 1959 US bug project. I learned the hood is a 3-pin (raised emblem) hood, so I need to find a 4-tab. Also, my rear fender seems like a mess. Like some on here, I get 13.5” for the left side measurement (white line) but the holes don’t match anything on here. It came with later taillights, so I guess not a shocker.
Anyone have a sense for the year of these fenders? They are not ribbed, which isn’t surprising.
Portland, Oregon
1991 Westy MV
1959 Bug
1977 Westy Bus - sold
1968 Bug - sold
2002 Eurovan - sold
Bub
Bub is offline
PostPosted: Tue Jul 06, 2021 7:08 am    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Seems like the later US models had higher tail lights due to the over riders?
I've seen too many cars- and many that seem to be proper, or built by very reputable shops, or even original- that have the lights mounted way high. Or at least higher than I like aesthetically. But all so close that I can't imagine they're all on the same kool-aid.
Somewhere it seems like there's a 'progressive refinements' page that seems to reflect this ?
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
sportin-wood
sportin-wood is offline
PostPosted: Wed Jul 07, 2021 12:38 pm    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
Bub wrote:
....reputable shops, or even original- that have the lights mounted way high. Or at least higher than I like aesthetically....
That's one of my biggest pet peeves. I MUCH prefer the slightly lower-mounted early taillights over the high-mounted lights. Makes such a big difference.
Dave
1966 Bug project
1973 Thing project
AlteWagen
Troll
PostPosted: Sat Jul 10, 2021 10:26 pm    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
this is why I asked about 5/55-7/55 placement.
Dan22
Dan22 is offline
PostPosted: Sun Jul 11, 2021 10:22 am    Post subject: Re: Reference for tail light placement 56-61 Reply with quote
My US spec June 1955 with snowflakes has these dimensions. It appears to match what Snort has done. I am 100% certain of these numbers to my car. The 17.5" dimension is reference as the point of the fender is never really accurate. I think better measurements come from the overrider hole. The 6-7/8" dimension is from the straight edge of the fender, and not the corner, but it appears this is very close to the corner, so maybe it is the same vertical position. Good reference if so.
Measurements taken from an OG dimpled fender. These do not match what was shown for the 1956 dimensions, but they do not appear to be 60mm lower than the 1956 position. Perhaps there was a US spec only for snowflakes, higher than the teardrop or egg lights. If someone can confirm that it would be helpful to the group. According to pdxeuro, these are about 1" lower than 1956 and later.
Perhaps this thread name should be updated to include 1955?? Wink Wink
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
