scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1046 Location: gigharbor W.A
Dauz Samba Member
Posted: Tue Sep 19, 2017 8:20 pm Post subject: Re: 2332cc build |
Best of luck.. |
Onceler Samba Member
Posted: Tue Sep 19, 2017 8:46 pm Post subject: Re: 2332cc build |
What did u modify on the crank for better oiling? _________________ 1972 Karmann Ghia |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Tue Sep 19, 2017 9:41 pm Post subject: Re: 2332cc build |
It's best to balance after mock-up, just in-case you need to grind on the throws to avoid the camshaft. The oiling mods do change things, but it's probably too small of a difference.
Make sure also to prep those cylinders before installing those new rings in there. |
pondervwmike Samba Member
Joined: June 16, 2017 Posts: 373 Location: Ponder(Dallas) Texas USA
Posted: Thu Sep 21, 2017 3:25 pm Post subject: Re: 2332cc build |
Awesome build keep up the good work and keep us posted. I am building a stroker as well. _________________ 1967 Cal Look Beetle Street Car in re-restoration,customization. Mom and Dad bought it in 1983 when I was 4.
2010 VW Tiguan
2000 BMW 528i
1997 Jeep Cherokee
2127cc build thread https://www.thesamba.com/vw/forum/viewtopic.php?t=681556&highlight= |
nsracing Samba Member
Posted: Thu Sep 21, 2017 6:18 pm Post subject: Re: 2332cc build |
It does not make sense to get the crank balanced and then grind it/modify it again after it gets home. That defeats the purpose of the balance work.
Get it all mocked up to final stage and then when you are satisfied, get the parts balanced. |
porkchop-rob Samba Member
Posted: Fri Sep 22, 2017 9:14 am Post subject: Re: 2332cc build |
If I am reading correctly, the OP did the crank modifications BEFORE he sent it to be balanced. _________________ 1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper) |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4263 Location: Aumsville, Oregon
Posted: Fri Sep 22, 2017 8:25 pm Post subject: Re: 2332cc build |
To everybody building a stroker. Make it as strong as your pocket will allow and research cam and heads. You won't regret it. Love my 2276...you'll love your buiilds. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Sun Oct 08, 2017 1:01 am Post subject: Re: 2332cc build |
Very nice tool, looks like a good clean cut. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Thu Oct 12, 2017 8:32 pm Post subject: Re: 2332cc build |
Modify all 8 lifters. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1150 Location: Western Washington State
Posted: Thu Oct 12, 2017 8:59 pm Post subject: Re: 2332cc build |
Nicely done, Scott. Great pics.
Gig Harbor, eh? I live across the Narrows. We should connect. I know VERY FEW aircooled VW gear heads in the area. It's like a wasteland. Those of us around here who are into it should connect.
BTW, the engine sitting on my stand REALLY close to getting fired for cam break in is a 48 IDA'd 2276 monster. Check out my '67 progress.
Peace. _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
Posted: Sat Nov 04, 2017 10:58 pm Post subject: Re: 2332cc build |
Looking good. I'll be posting pics of my own 2332 build within the next couple of weeks. Interesting you're using a w130. I went with a SLR XR310 on 110 lobe. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Fri Nov 10, 2017 12:31 am Post subject: Re: 2332cc build |
When I build a stroker, I will do the trial assembly all the way to the rocker geometry. I will install everything except for the rings. I mount light springs for the topend so I can observe the rocker system in movement.
Once I am happy w/ the rocker system, then I will cut the pushrods to final size.
When everything checks out, then I will take it apart and clean the parts for the last time to get ready for the sealing.
I do not seal that lower end until the whole engine has been mocked up to its finality. Everybody has their way, but I find it is more efficient to do the mockup all the way to the end see it work together before deciding to seal it.
I know people that have sealed the lower end and something hangs up and then had to clean everything. But ..your engine so you do your way.
It is all good. |
