samotorsport Samba Member
Joined: December 04, 2013 Posts: 199 Location: Luxembourg
Posted: Fri Sep 22, 2017 10:43 am Post subject: Drag racing alternator |
Hey guys , i wanna add an alternator to my dragster.
After couple runs it starts getting weak and heavy to start. Due to no electricity available at the airfield i wanna put a one wire mini race alternator on .
Would love to get one from Jaycee , but:
599$ & approx 100 shipping to Luxembourg & 7% import tax & 17 % vat would bring me to 875 $ which is a bit expensive
Therefore I am looking for an alternative to build myself, maybe somebody can help me with a p/n from denso so I can see to get an alt over here.
And if someone has a drawing with measurements for the bracket ?
Or even the cnc program ?
Thanks for any advise , help or picture from your setup
Greets
Sam _________________ 1958 Dragster 1835cc Topchop
1962 Split Panelvan Camper
1967 Herbie the love Bug
1970 Karmann Ghia 14 |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4277 Location: deepest, darkest Switzerland
Posted: Fri Sep 22, 2017 11:22 am Post subject: Re: Drag racing alternator |
I don't know what your cooling setup is, if you have a fan, etc..
But you can add an alternator :
Just thin hollow steel tube, well triangulated, and an extra pulley, stock mounting points (1 coil thread, 1 upper exhaust stud, 1 front engine stud) I'm using an old inner valve spring as a tensioner. The alternator puts out 90 Amps, with a completely separate circuit.
not sure how that helps, but it gets the topic flowing. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2284 Location: Jacksonville, FL
Posted: Fri Sep 22, 2017 1:17 pm Post subject: Re: Drag racing alternator |
Any small, "one wire" type alternator can be made to work. I've often heard of an alternator from a Toyota forklift (lift truck) as being the best bang for the buck. Unfortunately I don't have any detailed info.
Oh, it's assumed you'll have to do your own fabrication to mount it. With that said, alternators will put out power no matter which direction they rotate, so if you had to you could mount it "backwards". _________________ www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
neil68 Samba Member
Joined: March 17, 2007 Posts: 3448 Location: Calgary, Canada
Posted: Sat Sep 23, 2017 12:15 am Post subject: Re: Drag racing alternator |
Thanks a lot , the JPM looks like a good one for me . The price is ok , and due to Sweden is in the EU i dont have to pay import and VAT taxes .
I think i give it a try  _________________ 1958 Dragster 1835cc Topchop
calvinater Samba Member
Joined: September 06, 2014 Posts: 3589 Location: 802 The Pointless Forrest
Posted: Sat Sep 23, 2017 2:46 am Post subject: Re: Drag racing alternator |
Or maybe a spare battery to swap out when the charge gets low? _________________ "Albatross"! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20834 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Sep 23, 2017 7:11 am Post subject: Re: Drag racing alternator |
Small generator and battery charger to run while in pit or in start line up....
Dale _________________ “Fear The Government That Wants To Take Your Guns"
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Sat Sep 23, 2017 10:07 am Post subject: Re: Drag racing alternator |
most racers charge between rounds. other than that you can just get a small alt from whatever and put it on.I dont care if they have 1,2 or 3 wires going to them. and you can wire up a full throttell cut off switch so it isant deawing more power going down the track. also the size of the drive pully can be alturd to get the rpm of the alt down and engine power draw down too.
there are some realy small alts out there nowdays. |
