Putting the rear axle/seals/bearings back together
delliott101
delliott101 is offline
PostPosted: Tue Dec 09, 2008 10:11 pm    Post subject: Putting the rear axle/seals/bearings back together Reply with quote
I think I have it right... but does anyone have a blown apart diagram of how all the parts (axle tube to wheel backing plate) go back together? Simple non-CV joint '59 rear axle.
Thanks!
Transplanted Jersey Boy living in Idaho by way of Northern California!
We don't own old VWs, we just take care of them for the next driver
NOTAHONDA
Vegas Don
NOTAHONDA is offline
PostPosted: Tue Dec 09, 2008 11:43 pm    Post subject: Reply with quote
Just replaced mine over the weekend, heres the pic i used...
li_gangyi
li_gangyi is offline
PostPosted: Wed Dec 10, 2008 12:04 am    Post subject: Reply with quote
When you get to the seal area, press the seal and slinger into the cover, put the axle spacer into the seal/cover 1st, before bolting it all up.
Often peeps will try to put the spacer on the axle and then get the cover on, it will most likely then not seat properly and leak...
Me messing with the transmission and stuff...(includes pictures and the whole 'story')
http://vwbeetleadventure.blogspot.com/
delliott101
PostPosted: Wed Dec 10, 2008 7:08 am    Post subject: Reply with quote
Wow.. thanks!!!
HBCRUZR
Location: The center of TheRoddersJournal #45 sucka's!!!
HBCRUZR is offline
PostPosted: Sun Dec 21, 2008 4:52 am    Post subject: Reply with quote
Does anybody sell the bearings and spacer's as a kit? Best place to buy those?
Chris
SBS #89
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Dec 21, 2008 8:59 am    Post subject: Reply with quote
That picture is 65 and newer.
Gary: OK. Ima poop.
Jeckler
Jeckler is offline
PostPosted: Sun Dec 21, 2008 11:30 am    Post subject: Reply with quote
Early with slinger, from the other Andy's site....
Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote:
I am the crabby old guy.
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad.
delliott101
PostPosted: Sun Dec 21, 2008 1:26 pm    Post subject: Reply with quote
My rear axle was put together like the first picture above... those are the parts on it when I took it apart. I don't have that oil deflector thing on the second picture and I had the paper gasket on there.
I already put it all back together, per picture number one. I will hold onto this thread for future reference, though
rcroane Premium Member
rcroane is offline
PostPosted: Mon Sep 25, 2017 9:21 am    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Reviving this old thread, because I saw something in the Bug Me video on this subject that confused me. In the video, the narrator shows the removal of a grease seal on the FRONT side (wheel side) of the bearing cover. I don't see that seal in either of the diagrams shown in this thread.
My car is a '65....am I going to have that outer grease seal?
Thanks.
'65 Sunroof Bug
61SNRF
61SNRF is offline
PostPosted: Mon Sep 25, 2017 11:30 am    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Thanks.
Does the Bug Me video specify what your they are working on?
Up to 64 you can put the seal in the bearing cap from the outside.
65-> the bearing cap changed and you have to install the sealfrom the inner side.
Study the above illustrations carefully and you can see the visable difference in the caps.
-Bruce
An ounce of prevention is worth a pound of cure.
rcroane is offline
PostPosted: Mon Sep 25, 2017 11:34 am    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
That might be it....they did both so maybe he was showing both versions. I watched it a couple of times and didn't hear him say that it was two different versions.
Thanks for clarifying.
'65 Sunroof Bug
67rustavenger
67rustavenger is offline
PostPosted: Mon Sep 25, 2017 5:37 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
In the 65 diagram make sure to put the oil slinger in the bearing cover before installing the seal through the back side of the cover. Use a seal installer. You'll be happy you did. You can rent one for free at the FLAPS.
Another poster in another forum suggested inserting the machined spacer that the seal rides on into the seal, then installing the entire cover and spacer as one piece on the axle. That way you don't catch the lip of the seal on the axle when installing the bearing cover.
Makes sense to me. I recently changed a rear axle bearing and snagged the seal when I installed the cover. Got to change the seal again the next weekend Shocked
Make sure to lube the seal very well before installing the bearing cover.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
rcroane is offline
PostPosted: Mon Sep 25, 2017 6:20 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Thanks for the replies. Finished step 1 this evening....draining the gear oil (will let drain overnight). Good news is that it looked very clean. Bad news is it seemed pretty low (rear end of car was jacked up...not sure if that made it seem lower than it actually was). I've dropped the car back to level while it drains overnight. I'm going to measure how much came out after it finishes draining.
Do I use gear oil to lube the seal?
'65 Sunroof Bug
67rustavenger
PostPosted: Mon Sep 25, 2017 6:33 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
I used wheel bearing grease on the seal.
I really wouldn't sweat how much oil was left in the trans. Unless your anal retentive. Shocked Then go for it.
Just make sure that when you fill the trans that you give it time for the gear lube to settle into the case. In other words. Fill it slowly.
Good Luck.
Buy Once, Cry Once!
61SNRF
61SNRF is offline
PostPosted: Mon Sep 25, 2017 7:58 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Did you pull both drain plugs? That way ensures you have drained as much as practical with the trans in place.
Any lip seal with a garter spring needs to be pre-lubricated with something compatable with the main oil spec. With all the different wheel bearing grease compounds available nowadays, I'd suggest simply using a light film of your chosen gear oil on the seal and race.
Yes on installing the spacer/seal race into the installed seal from the wheel side before you install the assembly onto the axle/bearing/backing plate. This way you can look and verify that the garter spring remains safely intact and in place.
-Bruce
rcroane is offline
PostPosted: Tue Sep 26, 2017 5:45 am    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Crap...didn't realize there are two drain plugs! Looks like I'm back under there tonight Shocked
'65 Sunroof Bug
rcroane is offline
PostPosted: Tue Sep 26, 2017 4:35 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Ok....having trouble locating the second drain plug. My car has a camber compensator. It is attached in the center to a bracket/plate and it looks like there is a drain plug under there....does that sound correct? So, I will need to remove compensator and plate to access drain plug?
Thanks.
'65 Sunroof Bug
mukluk
mukluk is offline
PostPosted: Tue Sep 26, 2017 5:19 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
In this pic from the gallery, you can see the fill plug on the side, the forward drain plug at the forward end of the tunnel, and the rear drain plug pretty well centered under the differential.
rcroane is offline
PostPosted: Tue Sep 26, 2017 5:37 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Got it....like I thought, it was covered by the camber compensator and bracket.
Removed the second plug and about another 1/2 -3/4 cup of fluid drained out. Will leave it overnight.
I noticed that the compensator is EMPI....based on notes in my owners manual, the original owner had the dealer install it at the time of purchase.
Thanks again for all the advice so far.
'65 Sunroof Bug
61SNRF
61SNRF is offline
PostPosted: Tue Sep 26, 2017 7:54 pm    Post subject: Re: Putting the rear axle/seals/bearings back together Reply with quote
Yep, the unit assembly is called a a transaxle for a reason 😉
Transmission drain plug is forward, and the rear axle aka differential drain plug is rear most. Internal webbing in the housing prevents full drainage from only one plug.
The Manual and best practice would have you warm the engine and transaxle up to normal temp then driving the car over a pit or flat ramp before pulling both drain plugs to change the oil. Compromise and adapt as you must.
In a perfect world you would expect to recover ~3/4 of what full refill spec is. Less than that it might have been a little low.
-Bruce
