Swabyk Samba Member
Joined: May 05, 2013 Posts: 6 Location: Hertfordshire
Posted: Mon Sep 18, 2017 10:33 am Post subject: Painting/Spraying the black rubber dash switches?? |
I have a 1970 cabriolet which im doing the inside in off-white, seats, steering wheel etc....The question I have is, has anyone tried to paint the round rubber dash switches into other colours? (Wipers/Lights etc)
I want to do these too in an off-white colour and presume with a decent rubber-friendly paint theyd be ok. Does anyone know or has anyone done this?
I cant find any other options for this model than the standard black rubber ones.
Thanks
Ken |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Mon Sep 18, 2017 12:30 pm Post subject: Re: Painting/Spraying the black rubber dash switches?? |
The only thing similar to spraying the hard rubber dash knobs, that I've seen, is leather and vinyl color.......I used to spray ( I went from red to black) the seats in my TR3.......It held up much better than I expected but did need touch up from time to time.
I imagine it would be the same thing for the dash knobs, it would need touch up occasionally ???? _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5560 Location: Lefty, CA
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 344 Location: Denmark, Europe
Posted: Wed Sep 20, 2017 12:54 am Post subject: Re: Painting/Spraying the black rubber dash switches?? |
Haven't painted the knobs, but the dash and other parts. Used vinyl dye, and it holds up pretty good. Even painted my running board rubber, no problem.
Danpa Samba Member
Joined: August 21, 2007 Posts: 1289 Location: Valparaiso, in
Posted: Wed Sep 20, 2017 3:11 am Post subject: Re: Painting/Spraying the black rubber dash switches?? |
flat4olsen wrote: |
I think I've said it before but, it needs repeating...
MAN, does that interior look good!!
Dan _________________ 67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle, Finally back on the road after 18 years! |
Posted: Wed Sep 20, 2017 8:45 am Post subject: Re: Painting/Spraying the black rubber dash switches?? |
Thanks Dan  |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7504 Location: Houston, Texas
Posted: Wed Sep 20, 2017 9:44 pm Post subject: Re: Painting/Spraying the black rubber dash switches?? |
That looks nice. How easily does it rub off? _________________ www.vwnos.com [email protected]
Posted: Thu Sep 21, 2017 1:22 am Post subject: Re: Painting/Spraying the black rubber dash switches?? |
Not easily. It's amazingly tough. Cleaning and degreasing is essential. My running board rubbers are holding up just fine even though it's on the outside. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4934 Location: Stuck in Ohio
unclewede Samba Member
Posted: Thu Sep 21, 2017 12:48 pm Post subject: Re: Painting/Spraying the black rubber dash switches?? |
Does that do a full color CHANGE, or shades of colors? The dash right now is black, but it might be interesting to consider matching the rest of the green interior. |
Posted: Thu Sep 21, 2017 9:18 pm Post subject: Re: Painting/Spraying the black rubber dash switches?? |
Yes, you get full coverage. My dash pad was Black before painting (only colour VW made them in), and so was my centre console.
6-7 very thin coats of dye gives you a complete colour change. |
irun5k Samba Member
Joined: February 21, 2014 Posts: 335 Location: St. Petersburg, FL
Posted: Tue Sep 26, 2017 7:08 pm Post subject: Re: Painting/Spraying the black rubber dash switches?? |
I second using the SEM system. It is flexible, and they have a pre-treatment that actually softens the material temporarily allowing the paint to fuse with the surface.
I used it on my GTI years ago as part of a fix for some ill-chosen soft-touch material VW used. It never failed in any way after many FL summers to spite ridiculous interior temps.
I then used it on my bug to freshen up the original kick panels as well as other odds and ends like the door release inserts. |
vamram  Samba Member
Posted: Wed Sep 27, 2017 3:30 am Post subject: Re: Painting/Spraying the black rubber dash switches?? |
flat4olsen wrote: |
Flat4, echoing others here, it looks awesome. Can you be specific about the name brand of the "vinyl dye" you used?
Thanks,
Victor _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Posted: Wed Sep 27, 2017 4:24 am Post subject: Re: Painting/Spraying the black rubber dash switches?? |
Thanks! I'm danish and SEM is not available around here. I use a German brand,- MHW. The system is three parts, a cleaner (which seem to lightly dissolve the outer layer of the vinyl), the color itself and a clear "finish spray", that toughens the surface.
Cleaning and prepping and thin coats is the key. |
sb001 Samba Member
Joined: May 19, 2011 Posts: 10458 Location: NW Arkansas
Posted: Wed Sep 27, 2017 5:46 am Post subject: Re: Painting/Spraying the black rubber dash switches?? |
flat4olsen wrote: |
That looks freaking fantastic. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
