dual carb issues, Solex 32 PDSIT 2/3
daos
daos is offline
PostPosted: Mon Oct 02, 2017 2:50 am    Post subject: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
so.. i'm having problems with a dual carb set-up on my 69 fastback (converted from FI by PO), would really appreciate some trouble-shooting input.
- starts easily but will not idle at all
- jumps straight to fast idle after starting. runs for a while then revs reduce gradually until it dies
- lot of coughing/backfire from the right hand carb
i've adjusted valve clearance, points and static timing. dizzy is a 009 (copy).
also removed and thoroughly cleaned carbs, re-installed and set idle & volume according to manual. i did re-use the existing (not so old) manifold gaskets, should prob change those.
after than no amount of adjustment seems to make any difference. giving it some throttle bumps the revs up with the same result as before - fast idle then dies. can only keep it running with constant tweaks of throttle, otherwise it dies.
seems to run quite rough at lower revs (maybe this is the 2 cyl idle?) but ok at higher revs.
also checked & cleaned the plugs, all four were black and sooty/dry.
next on my list is to check for vacuum leaks (balance pipe & manifolds), check firing by removing plug cables, & do a compression test. also considering just changing plugs and plug cables, although there is decent spark on all four.
haven't had the car long so i don't know about the general engine condition. any thoughts on what else i should look for?
Mike Fisher
Mike Fisher is offline
PostPosted: Mon Oct 02, 2017 6:45 am    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
Sounds like your electric chokes might be the problem? Disconnect them and see how the car idles/runs without the chokes. The chokes can be adjusted/repaired when necessary.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ataraxia
ataraxia is offline
PostPosted: Mon Oct 02, 2017 7:18 am    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
Check for vacuum leaks first - I had a similar problem and it seemed to be the majority of the issue.
Chase one issue at a time - otherwise you'll just run in circles replacing parts that work just fine.
daos
daos is offline
PostPosted: Tue Oct 03, 2017 11:12 am    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
thanks mike and ataraxia for your input.
latest development - started with disconnecting the auto chokes and managed to get it to a stable idle, a little fast but better than anything up to now. interesting, they work ie. springs look healthy, elements heat up and open the choke flaps so not sure why they should be a problem after that. i'll try reconnecting them and see what difference that makes.
also checked for vacuum leaks and found nothing so that's eliminated.
a more serious issue though - still running a little rough with vibration from the left side, so checked the firing and found #4 is doing nothing. it has spark so something else is amiss. there is also heavy oil leakage from the base of that cylinder, something is clearly not 100%.
was definitely not planning to pull the motor but if it's not something that can be solved in situ.. Anxious
Mike Fisher
PostPosted: Tue Oct 03, 2017 11:20 am    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
I had 1 bad electric idle solenoid on my Solex's that caused a weird loping kind of running problem. Disconnect the solenoid wire & brush it on its connector. You can hear it 'click' if it's good. Bug solenoids will work for replacements.
P.S. Better buy a compression tester to test all 4 cylinders.
1rabbit1981
1rabbit1981 is offline
PostPosted: Tue Oct 03, 2017 1:48 pm    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
Be careful as not all bug solenoids will work. I recently had an issue with one of mine and was able to get it apart and clean the needle and sprayed some lube on it. Working great now.
ataraxia
ataraxia is offline
PostPosted: Tue Oct 03, 2017 4:58 pm    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
The best option - contrary to this advice - is to get the correct parts. They're not that hard to find.
daos
daos is offline
PostPosted: Wed Oct 04, 2017 1:24 am    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
i'm open to any and all input.
solenoids - are we talking about the idle cut-offs that stick out the side of the carbs? i don't have those. the only electrically operated part is the auto chokes - which appear to be functioning. here's a pic of the set-up (prior to cleaning):
dead #4 cylinder is a concern though. any thoughts on that? compression test is definitely on the to-do list.
daos
daos is offline
PostPosted: Wed Oct 11, 2017 12:01 pm    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
compression and leak down tests reveal an exhaust valve leak on #4. so i'm guessing either stuck - which would be nice - or burnt and not sealing due to overheating.
pedro sainz
pedro sainz is offline
PostPosted: Thu Oct 12, 2017 9:01 pm    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
well I can see the Right choke is completely closed
this is I would do first disconnect the chokes and open them FULL manually
by loosens the 3 screws
the MIX screw closed them little by little if you hear idle going shutting off
that's is GOOD is air tight if you keep closing the screw and NO change theres air sucking either from manifold or mid bushing
normally I tight the MIX and open 2 turns
68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There
pedro sainz
PostPosted: Thu Oct 12, 2017 9:09 pm    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
No Big Deal if you don't have the electric idle cut off
but unscrew the idle cut off manual jet and grap a thin wire and clean the smallest hole of the jet
there is one of each carb right?
I don't see the seal of your chokes is Overheating your carbs and air going IN too
and I don't see your balance tube from the manifold
N.O.N.A member #3
daos
daos is offline
PostPosted: Fri Oct 13, 2017 1:13 am    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
pedro, thx for the feedback.
carbs are now completely cleaned. now i need to fix the #4 cyl issue, then come back to the carbs.
manifold balance tube is installed, was off when i took those 'before' pics.
daos
daos is offline
PostPosted: Sun Oct 15, 2017 12:31 pm    Post subject: Re: dual carb issues, Solex 32 PDSIT 2/3 Reply with quote
well, got the engine out and heads off, this explains the total lack of compression in nr4 :
