CdnVWJunkie  Samba Member
Joined: February 01, 2004 Posts: 1135 Location: Sarnia, Ontario, Canada
Posted: Thu Aug 17, 2017 3:15 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| 91Transporter16" wrote: |
I sell the reinforcing plates as well.
$38 for a set and $28 for the bracket that supports
the carrier bar on the left side.
Tony
http://tinypic.com/m/i1ehhg/1 |
I will vouch for Tony and his fabricated parts. Quality parts and gentlemanly service. I will gladly purchase from again. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3670 Location: Dartmouth, Mass.
Posted: Thu Aug 17, 2017 7:13 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| CdnVWJunkie wrote: |
Yes, I had already purchased his motor mount brackets for my ABA swap. Have PayPal'ed him and he's sending the bracket tomorrow. _________________ John - 86 Wolfsburg Westfalia "Weekender"
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10514 Location: Sunshine Coast B.C.
Posted: Fri Oct 13, 2017 3:27 pm Post subject: Re: '82 VS '83 diesel engine carrier bars differences |
| crazyvwvanman wrote: |
Here is what I have done, mostly mimicking the VW method.
Mark |
Hi folks.
I'm making reinforcement plates today.
Are folks making their plates out of 1/8" ?
The plate in the above image looks about 1/8" and the rough measurement of the OEM plates on my '81 shows about 2.5 - 3 mm thickness. Just double checking before I start hacking away.
Thanks.
Neil.
thanks. _________________ 1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
91Transporter16" Samba Member
Joined: February 07, 2011 Posts: 267 Location: Tualatin Oregon
Posted: Fri Oct 13, 2017 4:53 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
If you are not bending the edges like the factory plates, make them out of 1/4".
Tony |
Posted: Fri Oct 13, 2017 5:53 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
Tony |
Thanks Tony. I wondered about that aspect. You obviously know this stuff but for others using the early bars on a PS equipped Vanagon, with the part now in hand, it looks like the OEM PS reservoir bracket will have to be shaped to fit around a gusset on the carrier to body bracket. No big deal though.
So many details. e.g. my Audi 5000 mount sure sits close to the oil pan. Even with engine weight on it. Maybe that's part of why some use the Saab or similar smaller hydro mount.
Are the arms off the engine to carrier bars the same (edit: length) for all diesel Vanagons?
Neil.
(VW Gas I4)
VE7TBN |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Fri Oct 13, 2017 6:02 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
I think that PS bracket needs to be cut off and re-installed elsewhere on most 50 degree installs, at least that's been my experience. I had to do this on my 15 degree install, as well. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Fri Oct 13, 2017 6:24 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| Zeitgeist 13 wrote: |
| I think that PS bracket needs to be cut off and re-installed elsewhere on most 50 degree installs, at least that's been my experience. I had to do this on my 15 degree install, as well. |
Hmm.... well, its off and still in pretty good shape. Would an engine accessory interfere with the reservoir mounted in the OEM position? No worries right now of course. PS is last on the list.
(VW Gas I4)
VE7TBN |
Posted: Fri Oct 13, 2017 6:45 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
Hey, that's a pretty clean cut!
I'm sure you've already thought of this, but before you settle on it's final resting place, make sure you can bolt up the stock WBX PS return/feed lines. I ended up placing it in a different location than I had planned at the outset, for this very reason.
'89 Bluestar ALH
NEAT, no ICE. |
Posted: Fri Oct 13, 2017 7:51 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
Edit: and if I'd removed that bracket while the engine was out, I could've used an angle grinder cut off. Would've taken less time. Hint to others: Easier to remove that part while engine is out!
Oh, I hired out for that cutting job. LOL. Thanks. Ya, I used my Dremel with metal wheel, then it started to die so cold chisel, a little bending, then some hammer and vice work to kind of straighten it.
Hmm.... well, if I can find a way to adapt the Vanagon PS pump to the ABA, I will. As for the lines, they're pretty rusty so I"m hoping I can keep the reservoir/pump position close to stock when it comes time to install new rubber front to back PS hoses.
Nice install. Lots of room! _________________ 1981 Westy DIY 15º ABA
(VW Gas I4)
VE7TBN |
Posted: Fri Oct 13, 2017 8:41 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
I was able to use the stock WBX high and low pressure lines on the ALH PS pump. I'm not sure what pump the ABA uses, but have you checked to see if the banjos are the same? _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
Posted: Fri Oct 13, 2017 10:28 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| I was able to use the stock WBX high and low pressure lines on the ALH PS pump. I'm not sure what pump the ABA uses, but have you checked to see if the banjos are the same? |
Good to know Casey. Thanks.
I haven't checked yet but they may be. But, as was pointed out to me by someone else, is the [presumably] smaller I4 pump sufficient enough, over the long term, to power the Vanagon PS rack? But maybe that's splitting hairs?
(VW Gas I4)
VE7TBN |
Posted: Sun Oct 15, 2017 9:01 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
Tony |
Thanks again Tony for that tip. I looked at the factory plates on my '81. I see what you mean.
For anyone other first timers diving into this, though I've had a little DIY type "fabricating" experience, I'd suggest its not too hard to more or less replicate the OEM edge bends. It seems to me though, that accurately transferring a mark from the apron to the point on plate where cuts are made, is important. Adjustments could be made at the bolt holes though.
I work slow, but for POV, this took about 5 hours. Sad, yes, but true. At some point I do wonder what my times worth; I'm sure that for most folks, it makes better sense to buy the part.
I'm not suggesting that swaps using 1/8" plates without bends are some how suffering without this; I know too little to say. I mostly did this to see if I could. Obviously the bends add a little rigidity but it now seems obvious that welding the bend to frame will provide even more strength.
Ironically, the first bracket turned out better than the second. In hindsight, I should've extended the bend further than the ~ 10mm shown and run the ear down onto the horizontal plane like the factory part. Just couldn't "see" how to do it at the time.
Neil.
This is the first one. Made these brackets with basic hand tools. Callipers, cut off wheel. I was able to anneal the metal to slightly dark red using a propane torch.
driver side
(VW Gas I4)
VE7TBN |
Posted: Mon Oct 16, 2017 9:36 am Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| vanagonjr wrote: |
| I cut one of these out of my former parts van. Still took about an 1.5 to 2 hours to cut grind and chisel it away from the back panel that it was welded on (if that makes you feel better). |
yes. I feel much better. LOL. Just joking. Oh, I know that drill. I did the same for the upper rad bracket on my air to water cooled swap.
Ya, it doesn't really matter how long it took I was just attempting to shed light on time vs money one might pay to buy the parts new. (does Tony make these?) i.e. I probably paid myself $10 CND/hour at best. But then I learned more. e.g. next time I'd make the bracket adaptor longer so I could bend an ear above the upper bolt hole. I may even weld a small strip of metal on these two bracket adaptors.
(VW Gas I4)
VE7TBN |
Posted: Tue Oct 24, 2017 1:06 pm Post subject: |
The diesel nose mounts are different from wbx nose mounts because VW tilts the diesel tranny way up at the nose to drop the back of the engine down for better engine lid clearance. The nose mount bolt patterns for 83+ are the same but diesel brackets are taller to angle the nose up. The rear shift rod is then bent differently in diesels to reach the higher lever on the side of the higher mounted trans.
So hypothetically speaking......
if we assume the engine weights are equal, using the same gas 2wd Vanagon, between a WBX and Vanagon diesel mounted in that van, what is the ground clearance difference between the lowest point of oil pan or case and ground? Or put another way, how many inches below the rear apron (where diesel arms mount) does that VW spec of 4º put the diesel crank center?
I imagine I could make a 4º cardboard template?
And am I reading the diagram below correctly?
(I edited it)
Thanks
Neil.
(VW Gas I4)
VE7TBN |
Posted: Tue Oct 24, 2017 2:54 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
Neil, since you're welding your own engine brackets to the carrier bars, I wouldn't think it to be important that you hew to that early style of drivetrain orientation. You can move everything further aft and lower like the '83 and later diesels and WBX drivetrains. I assume the later configuration put less strain on the CV joints among other benefits. _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
Posted: Tue Oct 24, 2017 3:17 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| Neil, since you're welding your own engine brackets to the carrier bars, I wouldn't think it to be important that you hew to that early style of drivetrain orientation. You can move everything further aft and lower like the '83 and later diesels and WBX drivetrains. I assume the later configuration put less strain on the CV joints among other benefits. |
For sure Casey. Yes. The mount brackets will be positioned further to rear to accommodate the current OEM WBX 4 speed transmission position.
I'm having trouble deciding on engine height but may mount it so part of the intake is above engine lid. Should I make a custom lower profile intake, raising the engine 1- 1.5" higher shouldn't affect other components.
Ground clearance difference question is mostly academic but I was curious to know where the factory diesel crank lines up with the body for future ABA engine height position reference.
(VW Gas I4)
VE7TBN |
Posted: Wed Nov 01, 2017 3:49 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| Vanagon Nut wrote: |
Neil. |
So I figured this was worth mentioning.
With my 2.1 WBX on the ground, measuring from bottom of carrier bar to crank centre:
~ 8"
Installed ABA with diesel Vanagon oil pan, measuring from bottom of pan to crank centre:
EDIT ~ 5"
Not an accurate measurement on the WBX but it seems to me there's a difference. So, if one is concerned about ground clearance loss, this may figure into that?
EDIT: deleted last paragraph.
(VW Gas I4)
VE7TBN |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19072 Location: Retired South Florida
Posted: Wed Nov 01, 2017 5:38 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| If the crankshaft centerline is set the same installed, it sounds like you would gain 3" clearance with the diesel pan? |
Posted: Wed Nov 01, 2017 6:00 pm Post subject: Re: '82 vs. '83 diesel engine carrier bar differences |
| MarkWard wrote: |
That would be my rough guess yes. As mentioned, the WBX was on the ground when I measured it but I measured at least twice and am happy to measure again.
And speaking of ground clearance....
On my 15º ABA, from the ABA oil pan to each frame rail, I see about 11". Add in the Stupendously Horrendous ™ engine carrier that runs under the pan and it becomes 13" or so.
On this current ABA 50º swap, with the engine set low enough so the ABA intake just touches the engine lid foam, from bottom of diesel oil pan, I see 10.75" for same pan to frame rail measurement. With engine at this height, and ever so just slightly toward driver side, the Mk3 PS pump (banjo fastener actually) clears the '82 diesel carrier. I hope. I'd really like to have PS.
(VW Gas I4)
VE7TBN |
