Time to play NAME THAT WIRE!
vanagonforever
vanagonforever is offline
PostPosted: Sat Oct 21, 2017 8:24 am    Post subject: Time to play NAME THAT WIRE! Reply with quote
I've got an 86 2wd Weekender that had smoke pouring from the top of the instrument cluster the other day. I've found the melt-y bits but I need help identifying what these wires power so I can make sure I fix the problem correct. I'm hoping you guys can help me.
In this shot I've got the instrument cluster out and the steering wheel removed
Here is another angle that shows the burnt wiring
Here is a close up of the wires I'm trying to identify
Here's a shot of the culprit going into the fuse panel under the dash
Please help me figure out what this is. You are all my heroes. Thanks!
1986 2WD 2.1L WBX Vanagon Weekender
1983.5 1.9L WBX Vanagon Westfalia
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Oct 21, 2017 9:02 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
That looks like the bundle that comes/goes to under the driver seat.
Slide the seat forward and look closely under there.
Are you storing metal objects under there?
Is something going on with the the relay under there?
Mark
Tobias Duncan
Tobias Duncan is offline
PostPosted: Sat Oct 21, 2017 10:13 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
^^^^^^ This guy
is crazy good at this stuff, pay attention and give him all the info he asks for.
vanagonforever
PostPosted: Sat Oct 21, 2017 11:50 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
WINNER WINNER CHICKEN DINNER
Amazing work. Indeed I believe I understand what happened.
So normally I have an aux battery but its nearing the end of its life and I pulled it so I could better test and care for it. Well, I thought I had secured the cables and was safe. It looks to me like my positive wire could have hit the metal on the seat and run current through it. That little guy must have been the path of least resistance. It's pretty amazing something way worse didn't happen really.
So if you were me, what step would you take next to right this wrong?
Thanks again for the suggestion. No telling how long it would have taken me to link the two and realized the problem was right under my ass the entire time.
crazyvwvanman
PostPosted: Sat Oct 21, 2017 4:20 pm    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
I would make careful notes of how things are connected and then remove the Westy aux battery harness. Once out I would split open the loom cover and see if any wires can be reused.
I'm curious what vintage 86 you have. Can you tell me the last 8 digits of the vin number, changing the last couple to xx ?
Mark
Abscate Premium Member
Abscate is offline
PostPosted: Sat Oct 21, 2017 4:22 pm    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
Those looms need to be cut open and every wire in them inspected.
Fires are not fun.
vanagonforever
PostPosted: Sun Oct 22, 2017 6:22 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
The last 8 digits are: GH0376XX. Its a Wolfsburg Westy Weekender.
UPDATE: I pulled the bundle and its totally shot. I'm going to completely replace it and the relay under the seat. I'm thinking I'll reuse the connectors since they appear in decent shape and will be a lot harder to find replacements for. Now to source replacement wire. I'm hoping I can find the right colors to avoid future headaches. Anybody have a good source for replacement wire?
vanagonforever
PostPosted: Sun Oct 22, 2017 9:57 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
I'm having trouble making sure I'm using the correct gauge wire. The ebrake sensor wire is fine (gray/green) so I'm reusing it. The gray, gray/red, and blue all look to be 18 gauge based on measured diameter and strand count.
The thing that is stumping me is the red/black and the solid red. Red/black has 32 strands and measures at 16 but that's more stands than is typical in 16 gauge. The red measures at 12 but it has 36 strands and that does make sense either. I don't know if I'm doing the right though so I'm hoping you guys can help.
Also I can't for the life of me figure out where this stuff is in the Bentley. Sorry for my noobery. Thanks again for all the help.
crazyvwvanman
PostPosted: Sun Oct 22, 2017 10:34 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
That is partly why I asked about the vin# info. In any case it seems like the factory used a fridge relay harness on your early 86 instead of the aux battery harness my various 86/87 Wolfys had/have.
86 fridge relay wiring on page 97.33b
86 aux battery relay wiring om page 97.34a
Mark
Wildthings
Wildthings is offline
PostPosted: Sun Oct 22, 2017 10:57 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
You can get the DIN wire gauge from the schematics and then use a chart like this to find the comparable AWG size
https://www.kayjayco.com/techAmpsNSAE2Metric.htm
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sun Oct 22, 2017 11:06 am    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
I have re used those type of factory connectors before. The ones I dealt with were most likely solid copper so I wasn't concerned about prying them open then re crimping. (metal fatigue) I also soldered the wires. Of course I cleaned them well beforehand. Of note, they were on fused circuits. Not all the circuits on a Vanagon are fused from the factory. Not saying re using and/or soldering on these terminals is the right way to do this but something to consider? For wires into the relay block, you might find that a generic relay block + wires might do. Those locking terminals aren't easy to find at a FLAPS. IF the new wire gauges on block match or are larger, just connect them to your new wires.
My "VW" parts place stocks various barrel type terminals. If you can find a European parts place, they might have stock of what you want? A proper crimp tool is another thing.......
I don't know the logistics of R&R for this portion of harness but if you assembled the wires, loomed them, then had new terminals crimped on by an electrical specialty shop, could the harness still be reinstalled?
Neil.
1981 Westy DIY 15ยบ ABA
(VW Gas I4)
1988 Westy DIY 50ยบ ABA
VE7TBN
vanagonforever
PostPosted: Sun Oct 22, 2017 12:43 pm    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
My current plan is to use one step up awg wire from the metric wire (just learned metric wire was a thing today) and I'm reusing the connectors by using splice connectors and a proper crimping tool with the exception of the 12 gauge wire that completely melted the casing off it. That is mostly to ensure that I've got proper wire colors at the connections so I don't get confused as much as it is to not have to source new connectors. Then thinking I'll just wrap the whole thing in electrical tape, do a test run to make sure nothing is getting hot, and then route the new wiring properly. I'm going to replace the relay under the drivers seat as well.
I'll be keeping a very close eye on all this. That should get me back on the road. Then I'm going to see if I can find a replacement for the entire harness from a junkyard or eBay. When I find one I'll probably ditch my mess for the old good stuff.
Anything else to look out for?
Vanagon Nut
PostPosted: Sun Oct 22, 2017 1:29 pm    Post subject: Re: Time to play NAME THAT WIRE! Reply with quote
Something I tend to forget; stagger wire repair joins.
Some electrical tape is better than others. IMO, its always worth using the better stuff. Split loom wire cover is generally always a good idea. As a side note, the cover with blue stripe has a higher temp rating, I recently learned. WD40 makes a decent lube if pulling covered wire through grommet. Even if used on the corrugated split loom stuff. If you use cable straps, invest in a flush cutter. The stub left behind by side cutters is devilishly sharp. Makes a spelunking adventure under the dash much more interesting. Twisted Evil
Neil.
(VW Gas I4)
VE7TBN
