fccperdiem Samba Member
Joined: August 16, 2005 Posts: 107 Location: Ellsworth, Maine
Posted: Mon Oct 23, 2017 6:28 am Post subject: Webasto Heater Retrofit |
There was no way in Hell that I was going to endure another Kansas Winter without a heater in my DD. So, I finally installed my Webasto! It fits in the stock location with a simply fabricated bracket. I managed to plumb it in using only the factory holes utilized by the BN-4. So far, I'm pleased with the fit and performance. It was only 45F tonight (hardly a real test...) but I can tell this thing is going to ROAST me out of the car! I had to turn it way down after 5 minutes, or so. We are forecasted to be below freezing in a few days, so I'll report back with the results.
[/img] _________________ Eric
Beard Fire Metalworks
Ellsworth, ME
207-242-0016
www.beardfiremetalworks.com |
74 Thing Samba Member
Posted: Mon Oct 23, 2017 7:10 am Post subject: Re: Webasto Heater Retrofit |
Can you provide a link and some info about that heater, and maybe photos where it dumps into the passenger compartment? |
KAmes Samba Member
Joined: February 16, 2014 Posts: 914 Location: Illinois
Posted: Tue Oct 24, 2017 9:05 pm Post subject: Re: Webasto Heater Retrofit |
Very interesting to see that installed. I have one of those I bought for a beetle project I'm working on, currently still in the box. You have a gasoline unit then? I did finally get a gasoline one, but it took me a while to find it. Diesel units seem to be more plentiful. I had seen inlet and exhaust through fittings on ebay, for marine purposes I think. I have a working BN4 in my Thing, I can imagine a modern version being even better. Enjoy! |
Posted: Tue Oct 24, 2017 9:26 pm Post subject: Re: Webasto Heater Retrofit |
Where did you guys buy the gasoline units?
I just see diesel ones available as well.
How is the wiring? Pretty much and exhaust and a combustion intake tube on the bottom then an intake on one end and the outlet on the other. It puts out 7500btu from what I read. |
Posted: Tue Oct 24, 2017 10:23 pm Post subject: Re: Webasto Heater Retrofit |
I ordered mine from Heatso.com. They initially sent me a diesel version, and I considered running it, but returned it for a gasoline unit.
The wiring was super easy to put together. My only gripe is that the harness is built for LARGE vehicles. For example, the wiring from the controller to the heater is 8ft long. I chose to coil the excess wiring behind the heater rather than trim to fit, in case I pull it for another project.
Next up is block-off plates for the ducting inlet and discharge hoses... _________________ Eric
Ellsworth, ME
207-242-0016
KAmes Samba Member
Posted: Tue Nov 07, 2017 10:44 pm Post subject: Re: Webasto Heater Retrofit |
I am pleased to report that the Webasto is doing great! Temps were down to 28F a couple days ago, and the temp inside the cabin was 72F at a 1/3 setting. I reconfigured the flow to pull fresh air from the trunk, rather than recirculating. It really cut down on the many tiny drafts from curtain gaps. _________________ Eric
Ellsworth, ME
207-242-0016
Posted: Tue Nov 07, 2017 11:53 pm Post subject: Re: Webasto Heater Retrofit |
Can you post photos of your new config when you get a chance? Thanks! |
DucksHockey Samba Member
Joined: April 30, 2016 Posts: 27 Location: Wilson County, TN
Posted: Wed Aug 03, 2022 7:42 am Post subject: Re: Webasto Heater Retrofit |
I am just about to install a diesel heater (similar to your Webasto). Can you please post a picture of how you ran the ducting for the fresh air intake? Also, are you just running the one output that is located in the middle of the car under the dash? _________________ 1971 Bus
2161 Full-flow Engine
Dual HPMX 44's
Vintage Speed Exhaust and Shifter
1972 Karmann Ghia Convertible
2007 Full-flow Engine
Dual HPMX 40's
1973 Thing
1904 Full-flow Engine
Dual HPMX 40's
1976 Deluxe Westy
1.8 engine
Fuel Injection |
KAmes Samba Member
Posted: Wed Aug 03, 2022 1:27 pm Post subject: Re: Webasto Heater Retrofit |
In my case in my beetle fresh air for combustion was left open to draw out of the trunk. My weather seal on the trunk is so bad it doesn't concern me much. Exhaust goes through the fender. Otherwise air is drawn out of the cabin on the driver's side, is heated and put back in the car on the passenger side. This works well as it doesn't set my feet on fire, now my wife (passenger), well I didn't ask her first. If I installed one in my thing I would do it similarly, I do need to devise a take off for defrost.
