Alaskaberrys  Samba Member
Joined: June 19, 2016 Posts: 1085 Location: SE Alaska
Posted: Sat Dec 16, 2017 12:40 pm Post subject: 1.9l AAZ in T3; A learning experience A to Z |
[changed subject heading to cover broader AAZ topic drift...]
Hi All,
As I'm learning (oh so much) about my imported doka I keep running into some things way over my pay grade... i.e. wtf does this wire do and why is it cut off?
I've got almost zero experience with diesels (am up to about 5% now) and having a transplanted engine in a European T3 makes it more challenging for sure.
First there are two, what I assume are breather tubes fro the transmission? (Syncro), coming out of the transmission just aft of the rear axels that run up to the top on the engine bay and gooseneck to...well, nothing.
From the top (yellow arrows on right point to the ends of the transmission tubes - hard to see one under the oil cooler pump. Yellow arrow on left dead ends also under air filter)
Better view of the upper one I repositioned for clarity
Though that seems like a pipeline or debris into my precious synchro transmission perhaps this is normal? Or did they connect to the original 1.6l JX somehow and were left off? Any insights most appreciated.
Mark (the gremlin herder ) _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Last edited by Alaskaberrys on Tue Dec 26, 2017 2:20 pm; edited 2 times in total |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4624 Location: East Kootenay, British Columbia
Posted: Sat Dec 16, 2017 12:57 pm Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
Yes, those are breather pipes. VW built the Syncros to work, and one of the things they had in mind were stream crossings.
Not sure why they thought the diesel bell-housing needed such large breather pipes, (the gas versions have just a small plastic breather hose), but bell-housing, transaxle and front diff all have breathers because they are sealed against water intrusion.
The two hoses from the transaxle and front diff usually terminate over the fuel tank.
It's always a good idea to check the small pipes for dirt clogging the opening.
You may want to double check that smaller hose you are pointing at that leads to the air-filter. Follow it back where it comes from. If I remember correctly that should be a vacuum hose for the LDA and connects to the intake manifold. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Sat Dec 16, 2017 2:07 pm Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
Are you sure that's an AAZ? _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Sat Dec 16, 2017 11:50 pm Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
| MsTaboo wrote: |
Thanks MsTaboo! Knowing that is a relief. After reading many of the trans threads and how mere dust motes can wreak havoc with our gears I was alarmed at a passage(s) that would slow several fat gerbils to pass easily. I will do my best to keep them above water. I did find a small plastic line - 1/4” ID that comes off the forward end of the transmission just before the driveshaft (the transaxle?) that runs to the general vicinity of the fuel injection pump - resting on top of the engine and isn’t connected to anything. Perhaps it was routed more forward over the fuel tank in the past but flopped out when the new engine was installed. I’ll look for the front diff ones now and check they are clear too.
| MsTaboo wrote: |
| You may want to double check that smaller hose you are pointing at that leads to the air-filter. Follow it back where it comes from. If I remember correctly that should be a vacuum hose for the LDA and connects to the intake manifold. |
I’m not sure what that device is - something throttle related (I’ll look up LDA) - but the other end isn’t connected to anything. Perhaps it was on the 1.6l - no obvious small male ports that I can find. I’d like to know where/what it should connect to.
Perhaps to this hiding behind the drivers taillight assembly? (Current intake air hose is removed for photo)
Original intake fan? Not sure, but it’s tied into the electric still - 10 years after the swap.... (don’t mention the rust by the way....I’m still adjusting to the fact it’s, well, everywhere ) _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Last edited by Alaskaberrys on Sun Dec 17, 2017 12:07 am; edited 2 times in total |
Posted: Sun Dec 17, 2017 12:00 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
| Zeitgeist 13 wrote: |
| Are you sure that's an AAZ? |
Ha! Good point. I did finally receive my copy of the Bently covering the Jetta, Golf, GTI, and Cabrio just the other day and was able to find out where they hide that engine code - I had looked everywhere!
Well, here it is hidden under the top coolant port line etched in discrete 0.1mm line for all to see. Not sure how I could have missed it
So, finally 100% sure it’s an AAZ and 8% educated on such. Progress. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Posted: Sun Dec 17, 2017 12:19 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
I asked because the valve cover and injection pump don't appear to be AAZ. They appear to be standard 1.6TD JX pieces. That's not to say there hasn't been some mix n' matching going on, but it's always nice to know what baseline you're dealing with. _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
Posted: Sun Dec 17, 2017 1:18 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
I wasn’t sure either till yesterday and verified. I have learned that the 1.6 JX to 1.9 AAZ was/is a pretty straightforward swap and used the same injection pump so I assume that is the original pump.
By the way, is there a special tool to remove the fuel lines from the check valves on the pump outlets? I tried to remove the fuel lines to the injectors to replace my glow plugs but they are fused on way tight. Could only back the check valve part out of the pump - but doing so would bend/destroy the lines so I left them in place. Major pain! _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
T3messie Samba Member
Joined: October 03, 2017 Posts: 215 Location: Germany
Posted: Sun Dec 17, 2017 1:25 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
Hi,
it´s a clean conversion to make it look like a JX, probably to avoid the higher taxes of the 1,9 (the engine code isn´t that obvious as you said ).
It would be interesting, if it´s the AAZ head with hydraulic lifters modified to accept the valve cover of the JX or a head from the 1,7 KY with mechanic lifters which of course you´ll have to calibrate from time to time.
Greetings |
Posted: Sun Dec 17, 2017 1:45 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
| T3messie wrote: |
Hi,
Greetings |
Hi T3messie. Good to know about the 1.7 KY possibility. Would I be able to find that out very simply? Remove cover? Or does it involve anything with settings that need to be reset to do so? I’m not afraid to explore and replace a gasket or two - but nearest mechanic that would be familiar with these is 1000km away. All the shops in Juneau said “do not bring it here”. No love. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Sun Dec 17, 2017 3:44 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
To be 100% sure, you have to remove the cover.
The mechanic lifters have 2 opposite recesses to remove the shims https://www.ebay.de/i/351960885144?chn=ps , the hydraulic ones are just flat in one piece. |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2427 Location: Der Vaterland
Posted: Sun Dec 17, 2017 4:11 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
Fixed that for you. The '/' goes at the end (just an FYI).
Secondly, I think this should be tied into your other post about the AAZ.
Now, on to the mystery air pump (by the original intake). This is a blower motor specifically for our Diesel Syncros. There is an extra temp sensor on the front of your motor, across from the gauge sensor. This is tied together with the extra water pump, they work together.
When you are 'Syncro-ing' at low speeds, and the cooling system needs some extra help, the air blower blows cool air directly on the turbo. Good luck finding the metal pipe that makes that a reality. I have one, it took me almost two years to find, and I can't fit it because I have a K24 turbo (bigger).
You DO want to have the heat shield in place though:
As mentioned in the other thread, here is my setup:
Extra water pump:
Air Blower:
Spaghetti-Monster wiring:
I hope this helps. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10479 Location: Orbiting San Diego
Posted: Sun Dec 17, 2017 6:37 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
The head should have a nine plus digit part number cast into it where you can easily find it.
The first 3 digits will show what family the head is from.
068 = 1.6
028 = 1.9
033 = 1.7 (never seen one, going by the parts book)
If an existing part is carried over to a later model it keeps the same base part number so keep that in mind for other parts besides the head.
Mark
| Alaskaberrys wrote: |
| .... Good to know about the 1.7 KY possibility. Would I be able to find that out very simply? Remove cover? Or does it involve anything with settings that need to be reset to do so? I’m not afraid to explore and replace a gasket or two - but nearest mechanic that would be familiar with these is 1000km away. All the shops in Juneau said “do not bring it here”. No love. |
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2408 Location: Adobe Jungle USA
Posted: Sun Dec 17, 2017 8:25 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
The diesel clutch was overbuilt for slippage, which generates heat. Crossing a river or mud can severely affect a hot clutch when cold water hits it. The diesel Syncro bellhousing was outfitted with extra vents and a snorkel tube out the top. This extra venting is to prevent hot pressurized water, mud and grit from getting pushed backwards through the input shaft oil seal into your soft parts. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Outback Kampers Samba Member
Joined: December 29, 2004 Posts: 2345 Location: Oregon Outback
Posted: Sun Dec 17, 2017 11:22 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
| Gnarlodious wrote: |
| The diesel clutch was overbuilt for slippage, which generates heat. Crossing a river or mud can severely affect a hot clutch when cold water hits it. The diesel Syncro bellhousing was outfitted with extra vents and a snorkel tube out the top. This extra venting is to prevent hot pressurized water, mud and grit from getting pushed backwards through the input shaft oil seal into your soft parts. |
The Syncro bell housing is sealed to the engine using sealant, when built. There is no way for water to reach the clutch unless the van wades deeper than these vent hoses. I disagree that the clutch is in any way 'overbuilt', it's just enough for a 1.6 but beyond that insufficient for an AAZ or any other more powerful engine. If it slips for any significant time it's toast. _________________ Karl Mullendore
1990 Syncro 16" sunroof Reimo highroof conversion
1990 Westy Multivan 112i automatic
1992 LT31 Karmann Distance Wide 'La Tortuga'
2014 Touareg X TDI |
Posted: Sun Dec 17, 2017 11:55 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
| Team WorldTour wrote: |
| ... I think this should be tied into your other post about the AAZ. |
brurud started the other “Strange AAZ Problem” thread conicedentaly right around the same time. I only hijacked it a bit... Agreed it would be good to merge at some point for open ended AAZ issues.
Thanks! I assumed it was to do with the JX. I’ll have to look for the wire to the extra sensor and see if it’s all in place. I’ve got the blower out now and can give it a good once over to see if it works. I won’t be doing any serious ‘syncro-ing’ in the next year or so - tho our dirt road flooded (prone to do that here) and I was wading through 24” of water.
I don’t think this is installed. There was some tattered insulation wrap around the piping (the orange one in your photo) but no bent metal as shown in yours - if I’m looking at the right thing. Was that easy to find, or did you have it fab’d up?
Extra water pump:
Air Blower:
I hope this helps. |
It helps a bunch! Thanks
Is that injection pump from an AAZ then? I can now see the differences from the JX pump I have. How about the valve cover? _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Sun Dec 17, 2017 12:02 pm Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
| crazyvwvanman wrote: |
068 = 1.6
028 = 1.9
Mark |
Thanks, I look for those. I found a five digit series above the block code “23A97” but it’s not on the head. I’ll give it a though search, I need to figure that out - sooner better than later! _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Sun Dec 17, 2017 12:07 pm Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
| westyventures wrote: |
The Syncro bell housing is sealed to the engine using sealant, when built. There is no way for water to reach the clutch unless the van wades deeper than these vent hoses. I disagree that the clutch is in any way 'overbuilt', it's just enough for a 1.6 but beyond that insufficient for an AAZ or any other more powerful engine. If it slips for any significant time it's toast. |
I found this out in the first minute of driving it. Between mal adjusted shifter linkage, heavy footed longshoreman, bad flywheel, an AAZ and a novice driver we smoked a clutch pretty quick. P/O said it was a new clutch less than 1000km ago.... I drive it veeeery gingerly now  _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Mon Dec 18, 2017 3:27 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
So, I too had the tatty insulation around the original rubber hose, and NO heat shield. Well, after a loooong hill last summer, and suddenly losing power about 3/4 the way up, I figured out that the rubber hose burnt through .
So, I bought the heat shield (aftermarket), and the new air hose (silicone, rated for re-entry) and fixed the problem. As you can see here:
The wire for the extra air blower can be seen. This is where you need to look for yours. I have come to the conclusion that mine doesn't function because I have a cooler thermostat installed. (85° as opposed to 87°). I think the switch opens at 90°. I've replaced it twice, and it never works, however if I ground it against the head, it fires right up.... go figure. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Mon Dec 18, 2017 10:34 am Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
Thanks for that - I had no idea it can get that hot - tho now that I think about it makes perfect sense.
Saving your pictures - It’s great to have pictures with labels. I’m in the process of doing that for our WBX in the Westy to help me learn and talk the wife through any issues. The AAZ is still mostly Greek to me. This helps a lot!
I’m going to see if I can get my “Luftbläser” working too  _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Mon Dec 18, 2017 3:22 pm Post subject: Re: 1.9l AAZ in T3 Hose Dead Ends?? |
Just in case you haven't seen this forum, it's a great source of info.
You want the IDI engine section.
http://vwdiesel.net/forum/index.php
Another great source is Vince Waldon's page. His info is directed at VW diesel Golfs, but the info is good for the AAZ in your Transporter.
http://vincewaldon.com/index.php?option=com_content&task=blogcategory&id=14&Itemid=28
I did the "pimp your glow plug" mod and it works terrific.
(click on the little printer icon to see pictures)
Also the 80-90 forum from England has lots of good info, they have many more diesels over there.
http://forum.club8090.co.uk/index.php _________________ Currently:
