US style towel rail bumper installation *pic heavy!
Page: 1, 2, 3, 4  Next
mcdonaldneal
mcdonaldneal is offline
PostPosted: Wed Mar 07, 2018 1:41 pm    Post subject: US style towel rail bumper installation *pic heavy! Reply with quote
I'm embarrassed to say it has been two years since I took the bumpers off our late '69 Ghia. They've been blasted and painted and reinstalled incomplete, but I am now ready to put them together.
Or at least I would be if I hadn't just bought a zinc plating kit and I've decided to zinc plate the bolts before the final installation.
Anyway,
I've found assembling and installing the bumpers a little bit tricky, but it's mainly a case of working out the best order to do everything in. So, I thought I would do a pictorial 'how to' to help anyone else who is as visuo-spatially challenged as I am!
I've only done the front bumper at the moment, I will add the rear to this thread when I get around to it. I hope it helps someone!
1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery!
mcdonaldneal
PostPosted: Wed Mar 07, 2018 1:43 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
First, gather the parts together.
This is pasted from another thread, but is a good guide to remind you of the bolt sizes etc:
sputnick60 wrote:
This next image is from the parts book and you can see how the various bolts, washers, nuts and rubbers go together.
List of Parts (its a bit wobbly because I don't know how to do tables in html)
PParttype…….DWG N..……..QTY……..……..……..vw part……..……..……..description
dome bolt..…….5……..……..……..4……..……..……..113 707 191 C……..……..……..screw bumper
washer…….…….6……..……..……..4……..……..……..N 12 228 2……..……..……..spring washer B 8
nut……..…………7……..……..……..4……..……..……..N 11 0008 8……..……..……..nut hex M 8
bolt……..……….10……..……..……..2……..……..……..N 10 240 4……..……..……..bolt hex head M 8 x 20
washer………….11……..……..……..2……..……..……..N 12 228 2……..……..……..spring washer B 8
screw…………….18……..……..……..4……..……..……..N 14 131 2……..……..……..screw fillister head AM 5 x 15
washer...……...19……..……..……..4……..……..……..N 12 225 1……..……..……..spring washer B 5
washer….……….22……..……..……..2……..……..……..N 12 228 2……..……..……..spring washer B 8
bolt……..………..23……..……..……..2……..……..……..N 10 370 1……..……..……..bolt hex head M 8 x 70
packing bow...27……..……..……..2……..……..……..141 707 181……..……..……..Packing Bow Front bumper guard
washer……..…..28……..……..……..2……..……..……..151 871 187……..……..……..washer 10.2 x 20 x 4
washer……..…..29……..……..……..2……..……..……..N 12 228 2……..……..……..spring washer B 8
bolt……..………..30……..……..……..2……..……..……..N 10 239 2……..……..……..bolt hex head M 8 x 18
bolt……..………..43……..……..……..2……..……..……..111 899 145 ……..……..……..bolt hex head M 8 x 27
washer………..…44……..……..……..2……..……..……..N 12 228 2……..……..……..spring washer B 8
washer……….…44……..……..……..2……..……..……..N 12 228 2……..……..……..spring washer B 8
bolt……..……….45……..……..……..2……..……..……..N 10 352 2……..……..……..bolt, hex head BM 8 x 55
rubber………..…52……..……..……..2……..……..……..141 707 253……..……..……..Rubber cushion outer front
rubber………..…53……..……..……..2……..……..……..141 707 255……..……..……..Rubber cushion inner front
washer………….54……..……..……..2……..……..……..131 821 150……..……..……..spring washer 8.1 x 22
bolt……..……....55……..……..……..2……..……..……..N 10 360 2……..……..……..bolt, hex head BM 8 x 60
Bolt……..……...56……..……..……..4……..……..……..111 899 145 ……..……..……..bolt hex head M 8 x 27
washer……….…57……..……..……..4……..……..……..N 12 228 2……..……..……..spring washer B 8
dome bolt…….62……..……..……..4……..……..……..113 707 191 C……..……..……..screw bumper
washer.……….63……..……..……..4……..……..……..N 12 228 2……..……..……..spring washer B 8
nut……..……....64……..……..……..4……..……..……..N 11 0008 8……..……..……..nut hex M 8
bolt……..….…..67……..……..……..4……..……..……..N 10 240 4……..……..……..bolt hex head M 8 x 20
washer…….…..68……..……..……..4……..……..……..N 12 228 2……..……..……..spring washer B 8
screw……..…...81……..……..……..4……..……..……..N 14 131 2……..……..……..screw fillister head AM 5 x 15
rubber……….…82……..……..……..2……..……..……..141 707 251 A……..……..……..Rubber seal bumper bracket cover
rubber………….83……..……..……..2……..……..……..141 707 353……..……..……..Rubber cushion bumper bracket rear
washer……….…84……..……..……..2……..……..……..131 821 150……..……..……..spring washer 8.1 x 22
bolt……..……...85……..……..……..2……..……..……..N 10 269 1……..……..……..bolt hex head M 8 x 38
Good Luck
Nicholas
mcdonaldneal
PostPosted: Wed Mar 07, 2018 1:49 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Bolt the three blade parts of the bumper together.
The shiny, chrome, domed bolt goes on top, of course!
The cat is keeping an eye on things.
Next, it's helpful to assemble the bumper brackets and the painted covers. Theres a rubber grommet between the painted parts. The head of this pointed bolt, and the washer are eventually painted body colour, but keep things loose for the time being.
mcdonaldneal
PostPosted: Wed Mar 07, 2018 1:56 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Next, position ONE overrider (I've done the LEFT) and its backing plate, ready for the long bolt that attaches the black bracket, through the bumper to the overrider.
Now, the central towel rail can be loosely attached to this one overrider.
The central towel rail WILL NOT FIT if both overriders are installed, hence the sequence I am showing!
mcdonaldneal
PostPosted: Wed Mar 07, 2018 2:03 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
If you are lucky, your overriders will be stamped to tell you which goes where. This one is stamped VR for Vor Rechts (Front Right) The others are VL, HL and HR, work it out!
As your bolts are loose, you can now slide the other overrider into position. First onto the towel rail, then onto the bumper blade. I should have mentioned to make sure that the rubber edging strips are in place.
You should now be able to slip the painted bracket/cover assembly onto the towel rail, and rotate it down into place and bolt it on to the blade.
Then secure the painted support to the overrider (loosely again).
mcdonaldneal
PostPosted: Wed Mar 07, 2018 2:14 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
The outer parts of the towel rails can now be secured. They also have a rubber/plastic grommet protector.
I've mocked up the very outer securing bolt that goes through the bodywork (with its cut rubber sleeve) although obviously this is inserted when the bumper is attached to the car!
Again, the bolts and washers which secure the painted support to the overrider were originally painted body colour. I intend to install the bumper with the bolts all slightly loose, tighten them up, remove the bumper again and THEN paint the bolts, so that the paint is not marred by the spanner/socket.
The final result! As I say, I've taken it all apart again, so that I can zinc plate the bolts, but I'll document the rear bumper in the same way, when I get around to it.
smuenchrath
smuenchrath is offline
PostPosted: Wed Mar 07, 2018 3:08 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
This is a great step-by-step instruction! Thanks very much for putting this together.
I hope this gets added to the stickies...
68 Ghia Regatta Blue Convertible
69 Ghia Toga White Coupe
74 Westfalia
sputnick60
sputnick60 is offline
PostPosted: Wed Mar 07, 2018 5:25 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Indeed. Done. Cool
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
mcdonaldneal
PostPosted: Thu Mar 08, 2018 4:33 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Thanks Nicholas (thanks particularly for the parts diagram at the top of the page!)
Phil
NOVA Airhead
NOVA Airhead is offline
PostPosted: Thu Mar 08, 2018 7:16 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Should be added to the Stickies!
Ghia Owner Emeritus
paul_round
paul_round is offline
PostPosted: Thu Mar 08, 2018 9:15 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
This is great! Unfortunately it makes me realise how many parts I’m missing!
cal34
cal34 is offline
PostPosted: Thu Mar 08, 2018 11:09 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Really great detail. Where did that parts list and image come from?
VeloMikey
VeloMikey is offline
PostPosted: Thu Mar 08, 2018 11:21 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Great post! Who did your plating? A company across the pond or did you ship them to the states? Everything looks great!
'58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748
mcdonaldneal
PostPosted: Thu Mar 08, 2018 12:42 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Thanks!
I'm not sure where the parts list and image came from originally. Nicholas (Sputnik60) had used it in a thread and when I found it, I lifted it for my build thread and then lifted it again to help with this thread.
I can't find the original quote now though!
mcdonaldneal
PostPosted: Thu Mar 08, 2018 12:48 pm    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Cheers!
It's the original chrome, just polished up with Autosol polish. I'm very lucky!
The inside of the bumpers were very rusty, but all surface rust, so I had them carefully media blasted and then painted them to match a NOS picture from the classifieds. Eastwood rust encapsulator spray paint from memory. I treated and painted the insides of the towel rails too, so hopefully the bumpers will outlast me!
mcdonaldneal
PostPosted: Fri Mar 09, 2018 8:34 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Ok.
Let's try the rear bumper now, before I lose my enthusiasm!
Like the front, the blades go together with domed nuts and bolts, shiny side up.
The over riders and the bumper supporting brackets aren't so interconnected at the rear, so you can install one overrider, using its 65mm bolt. I've chosen 'HR', hintern rechts, back right.
The outer towel rail attaches with one 18mm bolt. Don't forget the rubber 'grommet'.
mcdonaldneal
PostPosted: Fri Mar 09, 2018 8:51 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Like the front, the centre towel rail won't fit with both over riders in place. The painted support will wriggle in and stand up, out of the way. Then, the centre towel rail slips in and you can juggle it, and the painted support into the other overrider, and bolt it into place.
The painted supports are slightly different and the tubular parts splay out if they're laid down next to each other.
I keep everything pretty loose at this stage, so you can adjust the final position on the car and then do a final tighten and paint the couple of bolt heads that need it.
mcdonaldneal
PostPosted: Fri Mar 09, 2018 9:04 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
The second outer towel rail can now be bolted in place (18mm bolt) and the long bolt (55mm) at the towel rail joint loosely placed.
This painted part is vulnerable to damage, so you might want to pad it. Actually, I'm going to wrap it in padding before I assemble this, next time!
mcdonaldneal
PostPosted: Fri Mar 09, 2018 9:10 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
The black bumper support brackets bolt on simply, with 15 or 16mm bolts.
Then, there's a fiddly process of attaching the painted covers with a cross head screw. A short screwdriver and a long temper are useful if your screw threads aren't nice and clean! I ended up running a tap and die, which helped.
The painted cover has a bump next to the screw, which seats in a slot in the black support. They should also have a rubber edging strip/seal to protect the car body. The final adjustment will be on the car.
mcdonaldneal
PostPosted: Fri Mar 09, 2018 9:17 am    Post subject: Re: US style towel rail bumper installation *pic heavy! Reply with quote
Nearly there!
I've mocked up the end bolts (40mm) and the rubber spacer that keeps the bumper end off the bodywork. Note the orientation. Note also, the large penny washer next to the rubber.
I should have said, ALL of the bumper bolts have a wavy washer. You can see that.
Lastly, the complete bumper assembly, before I took it apart again to clean up the bolts and zinc plate. Another day!
Page 1 of 4
