hybridvw - [email protected] - Sven
Viewing feedback for: hybridvw
Email: [email protected]
Last Visited: August 20, 2023
PostPosted: Thu May 28, 2009 10:24 pm    Post subject: hybridvw - [email protected] - Sven Reply with quote
I installed a set of the LED bulbs in my Bus today.
http://www.thesamba.com/vw/classifieds/detail.php?id=768772
Everything looks great, can't wait to try driving around at night.
Admin notes:
Website is:
http://www.auto-hub.com/
Another thread from 2023 (negative feedback due to non-delivery):
https://www.thesamba.com/vw/forum/viewtopic.php?t=785928
Sniperx
Sniperx is offline
PostPosted: Wed May 09, 2012 11:08 am    Post subject: Reply with quote
Good stuff.
After battling with reverse polarity and such I located this seller. I swapped out all my bulbs with his and they work great. The idiot lights are bright and will definitely catch your eye. No need to worry about replacing gels or anything...you could have purple in there and the LEDs would blast through. I had an alternator lamp go out for some reason and he happened to be at OCTO. He came over and checked it out. He said, "Yep, that one went bad for some reason...heres a new one". He even installed it there at the show. The "exciter" attached to the alternator lamp also keeps the bulb from doing the phantom glow the incandescent bulbs do sometimes. Don't have to blip the motor to get the light to turn off either at startup.
I also changed out the backlights. What I got where the "cool" colored white bulbs. They throw kind of a ghostly pale blue white light across the face. It also is pretty dim really. After explaining my wish for a more stock-less-tech look in there he came up with a "warm" white bulb. Not only do they have a nice "incandescent" yellow cast to them...but they are also much brighter than before. The "40" mark is clearly legible now.
I would absolutely buy again...
flatfour
flatfour is offline
PostPosted: Tue Jul 03, 2012 3:51 pm    Post subject: Reply with quote
These LEDs are awesome and made such a HUGE difference on my '68 bug. As soon as the late model Ghia ones are available I will buy those to. You don't realize how dim your OE lights are until you see these in action!
'68 Bug
'74 Ghia
flatfour
flatfour is offline
PostPosted: Fri Feb 15, 2013 8:28 am    Post subject: Reply with quote
Looks like his ad is down now. Website still up but he doesn't seem to be responding to emails from there either. He was working on some late model Ghia lights and was hoping to order those since the others worked so good.
'68 Bug
'74 Ghia
PapaG1954
PapaG1954 is offline
PostPosted: Wed Aug 07, 2013 9:16 am    Post subject: sven led lites Reply with quote
Installed the speedo lights and all of them work except the turn Signal flasher green one.All the turn signals are working Has anyone else had this problem?I was told it might need a resistor between it and the flasher to make it work.
Also,would the test light illuminate at the flasher terminal where it goes to the light in the speedo that is not working if there were no wire hooked to it?
PapaG1954
PostPosted: Wed Aug 07, 2013 9:18 am    Post subject: sven led lites Reply with quote
That's in a 67 Bus by the way. ..
PapaG1954
PostPosted: Wed Aug 07, 2013 9:20 am    Post subject: Reply with quote
Anybody have Svens ph.#
PostPosted: Wed Aug 07, 2013 9:44 am    Post subject: Reply with quote
It's in his ads, use the link above.
robsvdub1
robsvdub1 is offline
PostPosted: Mon Dec 16, 2013 11:34 am    Post subject: Reply with quote
Lights are great. Seller is upstanding guy. Returned my call promptly and fixed up a little mixup. Stands by his product and ships quick. Makes a huge difference in my 64 6v. Dash lights are much brighter.
kidvdub
kidvdub is offline
PostPosted: Mon May 05, 2014 8:23 am    Post subject: Reply with quote
Best money spent on easy install and FAR better visibility than stock bulbs...
thanks!
Goshen
Goshen is offline
PostPosted: Thu Jul 03, 2014 1:33 pm    Post subject: Reply with quote
Smooth transaction..
I can't wait to see them installed on my 66 Maseratti Blue bug below
My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870
Goshen
Goshen is offline
PostPosted: Tue Jul 29, 2014 6:01 am    Post subject: Reply with quote
Sven,
I received the following set of BA7 LED bulbs from your website Auto-Hub.com but i have to tell you quite honestly that i am very DISSAPOINTED with the results of the white LED Speedometer illunination bulb... You can see here by the pic... it is not as bright as i thought it would be from your description
Look so you can see compared to the VDO gauges
What can we do about this... because i am not at all pleased with the result.
Goshen
Goshen is offline
PostPosted: Mon Aug 04, 2014 7:13 pm    Post subject: Reply with quote
Sven was able to get me the correct ones so now i am back in business so i will post my update tomorrow.
Thanks Sven for the good customer service
Michasulliv
Michasulliv is offline
PostPosted: Sun Nov 16, 2014 6:26 am    Post subject: Awesome LEDs Reply with quote
Very Happy
Wait until you see these in action what a "HUGE" difference compared to the dim Bay OE speedo pod lights. Night time driving the speedo has a nice bright blue/green color due to the internal OE color domes fitted.
Goshen
Goshen is offline
PostPosted: Mon Nov 17, 2014 11:44 am    Post subject: Re: Awesome LEDs Reply with quote
Michasulliv wrote:
Very Happy
Can you post pics please ?
cjargo
cjargo is offline
PostPosted: Fri Feb 27, 2015 8:51 am    Post subject: Reply with quote
Not responsive to emails after purchase.
'63 Vert. Bug - '58 Bug Ragtop RHD - '63 Vert. Bug -
'78 911 SC Targa - '69 911 E - '57 Vert. Porsche - '84 GTI - '69 Bus - '57 Bug - '68 Bug / Sunroof -
'65 Bug - '63 Bug - '74 Bus - '72 Karmann Ghia
'67 Bus / Sundial - '59 Karmann Ghia
68Bug-lite
68Bug-lite is offline
PostPosted: Sun Aug 16, 2015 6:17 am    Post subject: Reply with quote
What a difference! I was tired of squinting at my 68 bug's speedometer; at night it felt like I was driving a submarine... LOL.
I went with two of his bright white LEDs for the illumination and it really brightened up the speedo's face plate and easy on the eyes. I like the look.
Also replaced my melted dome light housing with a quality one from WCM, and using one of Sven's 41mm LED festoon bulbs. WOW, really lights up the interior and burns cool, - no more melted light housings!
Quality product and fast shipping.
Thanks Sven.
thewreckingsoul
thewreckingsoul is offline
PostPosted: Wed Feb 03, 2016 5:58 pm    Post subject: Re: hybridvw - [email protected] - Sven Reply with quote
Ordered these in Jan for a 68 project I just completed. Wanted the gauges to match in color so I went with the Red dash lights. Love the way they turned out! I'm satisfied with the way they look. Shipping was quick and was well packaged.
Thanks, Sven!
Here's a pic I took last night:
bakersam
bakersam is offline
PostPosted: Mon Mar 14, 2016 3:54 pm    Post subject: Re: hybridvw - [email protected] - Sven Reply with quote
First rate product and fast service. Can't say enough good things about the way things look with these LEDs installed. these are well worth the price!
dave millard
dave millard is offline
PostPosted: Tue Mar 13, 2018 9:33 pm    Post subject: Re: hybridvw - [email protected] - Sven Reply with quote
Sven, where is my order placed on March 6, 2018. I called you twice and left messages, also sent emails with a copy of my PayPal payment to you. Where is my order?
