T Hollis Samba Member
Posted: Mon Apr 02, 2018 11:10 am Post subject: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
What are acceptable "ohm" specs for the 12 volt BOSCH Blue Ignition Coil.
At the "4" readings below.
Primary - 200 & 2000
Secondary - 20,000 & 200,000
I'm thinking that the secondary windings in the BOSCH are shot.
200 -
2000 -
20,000 -
200,000 -
I'm getting.
BOSCH Blue Coil
200 - 3.3
2000 - 4
20,000 - 6.35
200,000 - 6.4
Delco Remy-Coil.
200 - 2.4
2000 - 4
20,000 - 10.60
200,000 - 10.30 |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3445 Location: Hamble, Hampshire, UK
Posted: Mon Apr 02, 2018 11:48 am Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
No , both coils have reasonable resistances.
However take a look at the surface of the nose of the coil for burning or tracking if spark over the surface.
It may also be flashing over internally. For instance if it got hot it may lose insulation or if some oil leaks out of the coil
The ohm meter is not an adequate complete test for an ignitiin coil. It tells you only that both your coils may be worth testing further. _________________ Ancient vehicles and vessels
Posted: Mon Apr 02, 2018 11:53 am Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
It may also be flashing over internally. For instance if it got hot it may lose insulation or if some oil leaks out of the coil the sparks may start jumping.
The ohm meter is not an adequate complete test for an ignition coil. It tells you only that both your coils may be worth testing further.
I have had burnt insulation on the nose of a coil , condenser going bad , electronic points wemulating burnt points and wires simply being loose on the coil.
As well as Taylor Spiro pro plug connectos springing off at 70mph before I knew how to put them on right. _________________ Ancient vehicles and vessels
Posted: Mon Apr 02, 2018 12:52 pm Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
| mikedjames wrote: |
The ohm meter is not an adequate complete test for an ignitiin coil. It tells you only that both your coils may be worth testing further. |
I see no burning or tracking.
What other test needs to be done.
And, thanks for the reply! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20899 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Apr 02, 2018 1:05 pm Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
Always use reading in lowest scale of meter... It's most accurate...
As a rule "most" ignition coils are anywhere from about 0.5 to 5 ohms on primary and 7,000 to 15,000 on secondary....
In your case use the 200 scale on primary and 20k on secondary...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Mon Apr 02, 2018 1:08 pm Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
| Dale M. wrote: |
Always use reading in lowest scale of meter... It most accurate...
As a rule "most" ignition coils are anywhere from about 0.5 to 5 ohms on primary and 7,000 to 15,0000 on secondary....
Dale |
"Thanks" Dale, get pic. / info. as always! |
Posted: Mon Apr 02, 2018 1:12 pm Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
| Dale M. wrote: |
Dale |
OOPS one to many zeros in 15,000....
Posted: Mon Apr 02, 2018 1:20 pm Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
"Ah" what's another "0" its just a number....  |
Posted: Mon Apr 02, 2018 6:55 pm Post subject: Re: BOSCH Ignition Coil ohm specs @ 200-2000-20,000-200,000 |
In some circles it would be 150,000.....Not 15,000...
