Removing/moving cabinet hinges
llilibel03
llilibel03 is offline
PostPosted: Mon Apr 09, 2018 1:59 pm    Post subject: Removing/moving cabinet hinges Reply with quote
I did a search and found nothing. I am going to add another door the side od the hanging locker cabinet. I was going to change the size of a door and wold need to move a hinge. I noticed they are riveted in place. Can anybody give me advice on how to remove them with as little damage as possible to the cabinet and the hinge.
Also, once, a long time ago in a far off galaxy, someone specified the router bit number to cut the groove for the plastic edge moulding. If that traveller is still amongst us I would appreciate that info again.
87 syncro tintop
90 gl tin top
85 westy 2.0 tiico automatic (present)
SCM
SCM is offline
PostPosted: Mon Apr 09, 2018 2:29 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
As is the case with any rivet, I think your only choice is to carefully drill it out or use a Dremel tool to grind the head off of the rivet.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
jimf909
jimf909 is offline
PostPosted: Mon Apr 09, 2018 2:36 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
Adding this closet door is one of my favorite mods. I’ve done it in two vans.
I’m not certain if this is the router bit you’re looking for:
“Routed out the slot for the T-molding using a Freud 63-104 router bit.”
From this thread (there are a few good builds in this thread)...
Enjoy.
- Jim
Butcher wrote:
Guilty as charged.
djkeev
djkeev is offline
PostPosted: Mon Apr 09, 2018 2:37 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
This thread is what you seek......
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Mon Apr 09, 2018 2:38 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
Beat by one lousy minute!!! ^^^^ Laughing
Dave
Ghia
Vanagon
Beetle
llilibel03
PostPosted: Mon Apr 09, 2018 2:42 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
Thanks all. I kept searching "cabinet door" and "cabinet hinge."
I'm going to put mine on the side but smaller than the ones in previous thread. Reason- A lot of times I've found we needed to get jackets at a rest stop while that back area is loaded with camp gear. I want a door that walloped only the top half, above the seat back.
87 syncro tintop
90 gl tin top
jimf909
jimf909 is offline
PostPosted: Mon Apr 09, 2018 2:46 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
Ahhh, then you might be interested in the sliding closet door mod. Have you seen it?
- Jim
Butcher wrote:
Guilty as charged.
spitsnrovers
spitsnrovers is offline
PostPosted: Mon Apr 09, 2018 3:46 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
There's some info here on replacing the hinges, as well as wardrobe mods.
It may help.
http://www.griffco.ca/interest/vw/wardrobe.htm
'88 VW Westfalia
'75 Triumph Spitfire 1500
campism
campism is offline
PostPosted: Mon Apr 09, 2018 4:55 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
If you want access when the wayback is full of stuff, a slider is the way to go. You're going to all the trouble to cut up the wardrobe, so do yourself a favor.
jimf909
jimf909 is offline
PostPosted: Mon Apr 09, 2018 5:21 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
This is the one I was thinking of!
- Jim
Butcher wrote:
Guilty as charged.
campism
campism is offline
PostPosted: Mon Apr 09, 2018 6:51 pm    Post subject: Re: Removing/moving cabinet hinges Reply with quote
I copied Frank Condelli's mod. I think he was the first to do this.
I also went with more shelving instead of the hanging locker. One change I'd recommend and which I will eventually do is to make the lower edge flush to the top of the mattress to improve access to the lowest section of the cabinet.
