Early model throw out bearing conversion
rockin mike
rockin mike is offline
PostPosted: Tue May 01, 2018 9:14 am    Post subject: Early model throw out bearing conversion Reply with quote
Anyone tried using a conversion kit to upgrade to late model throw out bearing
https://www.kustom1warehouse.net/Throw_out_bearing_conversion_kit_p/113141165bconv.htm
Looks like a good idea I'm having problems with the one I have now I'm getting ready to drop engine and replace it just wondering if anyone has tried this conversion ?? Or any thoughts??
Cusser
Cusser is offline
PostPosted: Tue May 01, 2018 9:20 am    Post subject: Re: Early model throw out bearing conversion Reply with quote
I'd leave as is. Never trouble trouble until trouble troubles you.
Use the throwout bearing clips with the coiled spring, not the U-shaped ones.
Plus, you'd need a pressure plate without the center ring.
rockin mike
PostPosted: Tue May 01, 2018 9:37 am    Post subject: Re: Early model throw out bearing conversion Reply with quote
This is 3rd time went out repair shop has been working on it before now I'm going to do it myself this time, haven't dropped engine yet will know more after, betting something is wrong with bearing car shutters when push in clutch and gears grind and car pulls forward drives fine after clutch pedal released
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Tue May 01, 2018 10:27 am    Post subject: Re: Early model throw out bearing conversion Reply with quote
^ Have to agree with Cusser .. the old release system works flawless with the proper good parts.
Better clips are out there.. I generally just mod the originals.
Ya may want to search ... Clutch Bowden Tube..
If the clutch shudders.. when engaging the clutch (releasing pedal to take off).. the Bowden tube is worn or improperly set up.
Clutch "shudder" severe enough can dislodge the release bearing from the shaft.. its generally the result.. not the root cause.
More advice.. check the clutch cable and the clutch cable tube.
If the cable is fraying and or the tube itself is loose from its welds..... mayhem ensues...
Engine and transaxle mounts too..
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Tue May 01, 2018 12:25 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
Early 60s had clutch shaft where the arms that hold the bearing were just welded on the bottom. This may have been ok with a 180mm parts but there was a heavier design like the one in your picture. Also the clips were upgraded to a wrap around spring type per a service bulletin. What everybody forgets to check is where bearing rides on the arms and nobody lubes these two points of contact. I’ve seen this worn to oval shapes after hundreds of thousands of miles but you need to look close. There is also a way to safety the clips like the off-road guys do but that supposes you are handy with the wire and pliers.
The long way around? You can convert an IRS box to swing axle and use the better 71 and up parts. But before 71 people did as I described earlier. I’d also take a real good look at Bowden tube and make sure welds aren’t breaking on clutch tube. 😀
rockin mike
PostPosted: Tue May 01, 2018 4:28 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
Thanks guys it's been an on going problem since it first happen last year no more repair shops, going to dive in and fix myself so it will be done right I'll pull motor and acess the situation and go from there and thanks again for the info!!
epayne611
epayne611 is offline
PostPosted: Tue May 01, 2018 9:36 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
I bought that kit, it didn’t work out too well...ended up buying a properly welded arm from Rancho, and the RJE adapter:
https://www.thesamba.com/vw/classifieds/detail.php?id=1441973
Rocky can also sell you the seal. But if I had to do it again, I wouldn’t do it at all.
rockin mike
PostPosted: Fri May 04, 2018 11:15 am    Post subject: Re: Early model throw out bearing conversion Reply with quote
Thanks for heads up I was wondering about that conversion kit, I saw RJE adaptors they looked very well made was thinking going in that direction because I do want to convert my throw out bearing to the late model type I'll keep you posted on the work on the conversion Very Happy
rockin mike
PostPosted: Mon May 07, 2018 6:02 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
Got lazy today didn't do anything on the car yet I really wanted to get the engine pulled today dammit I'll shoot for tomorrow need to get it done so I can move on to the other projects around the house Confused
rockin mike
PostPosted: Tue May 08, 2018 4:38 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
Pulled engine today no smoking gun to account for all that shudder and pulling with pedal engaged wasn't able to get in hear at all at a stop thought throw out bearing would have been blown all up it's fine
Now I don't know what to do flywheel looks blued in spots like it burned disc is polished on the edge on flywheel side that where it's at Sad
Cusser
Cusser is offline
PostPosted: Tue May 08, 2018 5:58 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
If you re-phrase the above and make clearer, myself or others might have an easier time helping you.
Sounds like the flywheel needs to be resurfaced or replaced, and you definitely need a new clutch disc. I'm recommending a complete new clutch kit, which will include a new release bearing. Use clips with the coil spring.
nelson845
nelson845 is offline
PostPosted: Tue May 08, 2018 6:34 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
Make sure the shaft isn't moving side to side. I had a similar recurring problem and it turned out there was a bit of play on the shaft, causing the bearing to fall off the fork.
rockin mike
PostPosted: Tue May 08, 2018 8:23 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
Going to replace everything, with a clutch kit (no throw out bearing conversion, not the problem) and going with lighten flywheel, after closer inspection the ring on the pressure plate was not even level, it was at an angle as if the thines were warped, so it is all going in the trash so sad it was all new parts replaced by a shop for me less than 1500 miles ago. Any tips on putting it all back together, someone mentioned end play at flywheel, I noticed a small gap at top of transmission bell housing and engine before disassembly, how critical is it for the engine to seat tight all the way around trans, bell housing? Just want to have to do it twice, just right
Thank guys
rockin mike
PostPosted: Tue May 08, 2018 8:26 pm    Post subject: Re: Early model throw out bearing conversion Reply with quote
10-4 on the spring clips
Tvättbjörn
Tvättbjörn is offline
PostPosted: Sat Feb 09, 2019 10:00 am    Post subject: Re: Early model throw out bearing conversion Reply with quote
Dealing with it last night. I had the same issue with the noise you are talking about. Make sure your throw-out arms on the shaft are centered and have the same distance from the input shaft. I have two after-market throw-out shafts and both are just crap. Not only did the bushing not fit the shaft ( hole was too small ) The bearing was sitting 4 mm off center to the right. I had to bent the arms sideways to get the bearing centered. It looks like everybody is making just a copy a bad part from somebody else.
