t-hardwick Samba Member
Joined: December 13, 2009 Posts: 108 Location: Kelowna BC, Canada
Posted: Wed May 23, 2018 7:59 am Post subject: Anyone near The Algarve Portugal? Help me please |
Hi, I'm stranded at a campsite with my vw bus, drove from England to Italy thru France all the way to Portugal without a hiccup. In terms of describing - it starts up fine, idles fine and revs really well (you'd think it is running perfectly). 1st pull away and it will be smooth and almost normal (very slight hesitation through acceleration) and then after 500mtrs it will bog down fully, hesitate and will struggle to get above 40mph (even down hill). If my foot lightly rests on the pedal it will run smoother (but won't pick up speed) then if I put my foot down. The longer I drive it, the worse it gets.
What I have done
Plugs
Cap
Rotor
Leads
Fuel filter
Rebuilt carbs
Checked pump
Changed coil
I have a 2.0 with twin kadrons _________________ If the vans a 'rockin' dont come a 'knockin'
If you pay peanuts, then you're going to get monkeys'
1975 Beetle |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3541 Location: Wyoming,USA
Posted: Wed May 23, 2018 8:29 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Sounds like fuel starvation. Change the fuel filter again. Depending on the brand of filter and condition of your tank, they can plug up fast. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53015 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 23, 2018 8:41 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Is this your 75 Beetle we are discussing?, or some sort of bus?, if so what year? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17683 Location: San Diego, California
Posted: Wed May 23, 2018 8:49 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Try it with the gas cap off _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 908 Location: SouthEast
Posted: Wed May 23, 2018 8:58 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Could be fuel starved from the screen in the tank. Or a vacuum leak. |
Posted: Wed May 23, 2018 9:19 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
busdaddy wrote: |
Is this your 75 Beetle we are discussing?, or some sort of bus?, if so what year? |
It's a bus with a pancake 2.0 1980 _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Wed May 23, 2018 9:52 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
If you did not get a bath in gas, when u pulled the fuel hose off from the gas tank to the filter. Your gas tank is plugged. |
rsbadura Samba Member
Joined: November 30, 2009 Posts: 758 Location: Berlin, Germany
Posted: Wed May 23, 2018 11:19 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Tried no gas cap, didn't fix
Sprayed easy start all over for leaks , nothing
When I pulled the line off to change the filter lots of gas came out.
I have 40L in there currently but tomorrow I will drain out and check that filter.
I do think you're right on the starvation side but would any electrical faults cause this also? Or something deeper in the engine?
Thanks everyone. _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
timvw7476 Samba Member
Posted: Wed May 23, 2018 11:27 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
if the filter flows OK, then it's the wiring to your fuel pump, or the pump
itself can't deliver....I know there's a spec for the fuel injection pump, as
far as cc's per 20 or 30 seconds, I would think your pump is failing to deliver
if the fuel flows freely from the tank & filter isn't plugged up.
Would not start digging 'deeper in the engine' yet. |
Posted: Wed May 23, 2018 11:35 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Here is a video clip of what's going on.
Also will my tank have an in tank filter screen?
https://youtu.be/GU1CSU-lWWw _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
1970fun Samba Member
Posted: Wed May 23, 2018 1:11 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Defenitly fuel starvation, you can hear it puffing trough the carbs a typical sound for not enough gas in the carb bowl, could be the fuel pump, a clogged fuel line or dirty blocked jets? |
Posted: Wed May 23, 2018 1:24 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
I found a rag inside a tank once acting similarly _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed May 23, 2018 1:30 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Literally cleaned every part of it. Loads of fuel in the bowls. Jets are clear as are all the carb pipes etc.
Also brand new tank was fitted 6months ago. _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42808 Location: at the beach
Posted: Wed May 23, 2018 1:38 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Does the engine have a catalytic converter on it? _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Wed May 23, 2018 2:03 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
SGKent wrote: |
Does the engine have a catalytic converter on it? |
No cat converter. The spout on the tank is not removable. Is there still a screen inside the tank? _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
SGKent  Samba Member
Posted: Wed May 23, 2018 2:23 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
t-hardwick wrote: |
SGKent wrote: |
No cat converter. The spout on the tank is not removable. Is there still a screen inside the tank? |
no.
Electronic ignition or points? _________________ George Carlin:
Posted: Wed May 23, 2018 2:24 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
If the bowls are full you can rule out tank or pump. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed May 23, 2018 3:19 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Ok, let's say that the fuel system is ok and it is an ignition fault. I have replaced all the leads, plugs, cap and rotor (the original rotor was melted at the end). Perhaps the hall sender? Measuring the voltage at the coil I get nearly 12v.
The hall sender plug reads at 10.81v where I plug it into my distributor. So I am losing 1v somewhere. Could this cause a problem? In terms of other ignition perhaps the timing or vacuum advance is at fault? I'm on a campsite in Portugal with no 'specialist' tools so hard to check timing etc. Cheers _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
Posted: Wed May 23, 2018 3:21 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
SGKent wrote: |
t-hardwick wrote: |
SGKent wrote: |
no.
Electronic ignition or points? |
Electronic ignition _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
