mugford Samba Member
Posted: Tue May 29, 2018 10:50 am Post subject: Drilling into sloping wall under rear bench - how to do it? |
I want to mount a piece of plywood under the rear bench against the sloping wall in front of the engine bay.
Given its a syncro I suspect that the gas tank is right behind it so how much gap is between it and the sheet metal? Will use Rivnuts in the new holes. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18770 Location: Retired South Florida
Posted: Tue May 29, 2018 10:56 am Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
Others probably can advise you better, but the syncro tank is really right up against the firewall. I would not recommend drilling for even rivnuts with the tank in place. If you can't resist, put a piece of fuel hose on the drill bit to limit the depth the drill can protrude through the sheet metal. Good luck. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Tue May 29, 2018 11:26 am Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
How about using construction adhesive rather than screws? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue May 29, 2018 11:42 am Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
Adhesive, not a bad idea, because I was planning on using 1" wooden standoffs to clear the bump on the driver's side. I'll probably just glue the standoffs and mount threaded inserts in those instead.
Thanks |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17151 Location: Brookeville, MD
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3633 Location: Dartmouth, Mass.
Posted: Tue May 29, 2018 5:30 pm Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
I regularly use construction adhesive to adhere Mercedes hood pads into place. It works well in a high heat environment, and I think it's just flexible enough to deal with road vibrations. _________________ Casey--
y u rune klassik? |
Posted: Tue May 29, 2018 5:40 pm Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
The polyurethane construction adhesive are really quite good, I have used them for all kinds of projects over the years. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Tue May 29, 2018 10:20 pm Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
Agree with Wildthings. The mastic and other construction adhesives are crazy strong. I knew of a guy in college who glued shelves to the wall instead of nails (in fact the product may have been Liquid Nails). They were stout. Unfortunately when it came time to take them down, he had to pay for the drywall to be replaced. It would not come off without taking the drywall.
I'le also seen it put between 2X4s and you will not pry them apart. The wood will fail first. So take a look. There are also expanding foam versions that might account for your bump or unevenness of the metal wall.
This has actually been a great thought from you. I have been wanting to add some hooks and small shelving units under there to hold things I always have - axe, place to bungee jumper cables up out of the way, fishing rod brackets, etc. I am thinking of glue-ing all manner of things under their to make my life more simple and organized. I run without the seat panel, so everything's accessible. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Jun 11, 2018 5:17 pm Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
Just a big thanks to all who chimed in with suggestions. The gluing and mounting went quite well and having it removable via threaded inserts makes all the difference.
Posted: Tue Jun 12, 2018 2:54 pm Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
Nice work. I like the use of threaded inserts. _________________ Casey--
y u rune klassik? |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Tue Jun 12, 2018 5:42 pm Post subject: Re: Drilling into sloping wall under rear bench - how to do it? |
Zeitgeist 13 wrote: |
Nice work. I like the use of threaded inserts. |
x2
mugford, What are you mounting to the plywood? ECU? |
