Options for an oblong hole
crankbait09
crankbait09 is offline
PostPosted: Fri Jun 01, 2018 6:10 am    Post subject: Options for an oblong hole Reply with quote
I have 4 out of the 20 hubcap clip holes that are oblong, and are no longer perfect circles.
What are some ways to remedy this so the hubcap clips can properly seat tightly?
Has anyone ran in to this issue? What did you do to fix?
1963 Ragtop
hitest
hitest is offline
PostPosted: Fri Jun 01, 2018 6:38 am    Post subject: Re: Options for an oblong hole Reply with quote
Were these four holes the result of overzealous original rivet drilling?
If so, maybe a size up rivet or light welding and redrilling is in order.
FU#5
crankbait09
PostPosted: Fri Jun 01, 2018 6:47 am    Post subject: Re: Options for an oblong hole Reply with quote
yes, A number of the rivets were replaced with cheapies at one point, a couple oblongs were from the PO, and two were by me not being as straight as I thought.
1963 Ragtop
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Fri Jun 01, 2018 8:14 am    Post subject: Re: Options for an oblong hole Reply with quote
I’d use a soft aluminum rivet which would conform to the damaged hole, not a pop rivet either. You need a real solid shank rivet, a rivet gun, a bucking bar and two people that have experience driving rivets.
crankbait09
PostPosted: Fri Jun 01, 2018 8:16 am    Post subject: Re: Options for an oblong hole Reply with quote
great, none of which I have.
I spose I could possibly have someone weld those specific clips in to place.
1963 Ragtop
HippyTom
HippyTom is offline
PostPosted: Fri Jun 01, 2018 8:52 am    Post subject: Re: Options for an oblong hole Reply with quote
JB Weld.
On an old VW, one of the following can resolve 90% of you day to day problems:
PB Blaster - if it doesn't movecand it should
Duct Tape - if it does move and it shouldn't
Zip Tie - if something needs to be held somewhere it doesn't want to be
JB Weld - if something needs to be put back where it used to be
crankbait09
PostPosted: Fri Jun 01, 2018 8:54 am    Post subject: Re: Options for an oblong hole Reply with quote
jb weld - I'm listening. I have worked with that before.
How does it work in this scenario? Which product would I use?
1963 Ragtop
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Fri Jun 01, 2018 9:00 am    Post subject: Re: Options for an oblong hole Reply with quote
fudge and use a stove head nut and bolt on the 4 that are oblong. No use overthinking
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
pondoras box
pondoras box is offline
PostPosted: Fri Jun 01, 2018 9:06 am    Post subject: Re: Options for an oblong hole Reply with quote
If you value the hubcaps you are putting on the car I would skip the JB Weld "fix" It works on a static object not subject to stresses and vibrations encountered on your rims.
Larger pop rivets will work if you can get them to tighten down hard enough, my experience is the rivet stem breaks off before it gets tight enough to keep the clip from moving.
My suggestion is to weld the holes and then drill out to proper size and get original clips not repops. I save all the clips from every bent / rusted rims I can. They work WAY better than reproduction ones.
Driving solid rivets is not that hard to do. In fact I think Wolfsburg West sells a kit to do this properly. If you mess it up gently grind the head of the rivet off and the rest will just fall out, shouldn't need to drill through the opening at all.
I just sold a bunch of rims last summer at the Xenia show and almost had to give them away, most had a complete set of rivets. Check the swap meet at shows lots of stock rims at those.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk
anthracitedub
anthracitedub is offline
PostPosted: Fri Jun 01, 2018 9:23 am    Post subject: Re: Options for an oblong hole Reply with quote
It’s difficult to drill a weld so may the Shwartz be with you.
PostPosted: Fri Jun 01, 2018 9:38 am    Post subject: Re: Options for an oblong hole Reply with quote
I like Rick’s idea. Easiest to do 😁
HippyTom
HippyTom is offline
PostPosted: Fri Jun 01, 2018 9:47 am    Post subject: Re: Options for an oblong hole Reply with quote
^^^ I vote for this!!! ^^^
crankbait09
PostPosted: Fri Jun 01, 2018 10:24 am    Post subject: Re: Options for an oblong hole Reply with quote
um, stove head nut? I googled images of this and don't see a difference between that and the lock nut I have. Unless it's the "square" type nut.
oh, and these are new hub caps that I'd prefer NOT to have to replace Smile
1963 Ragtop
jason
jason is offline
PostPosted: Fri Jun 01, 2018 10:27 am    Post subject: Re: Options for an oblong hole Reply with quote
The nut name is on the box.
anthracitedub
PostPosted: Fri Jun 01, 2018 12:27 pm    Post subject: Re: Options for an oblong hole Reply with quote
I’d use a button head screw.... probably a 8 32 X 3/8 would work and of course the proper nut to back it.
crankbait09
PostPosted: Mon Jun 04, 2018 4:35 am    Post subject: Re: Options for an oblong hole Reply with quote
installed the screws and nuts this weekend, even on the oblong holes. tightened everythign down and the clips didn't move on bit. nice and snug. that was easy!
I installed the old caps just to see how it would hold up. it snapped in to place, and it was NOT moving Very Happy
The new hub caps will be in on Wednesday, so I'll get them on, and then drive away Smile
1963 Ragtop
