Tcash Samba Member
Tcash Samba Member
Tcash Samba Member
Posted: Fri Jun 15, 2018 10:23 pm Post subject: Exhaust - Muffler & Heater 1972-1974 |
Muffler & Tailpipe
Ref. Part Number Description
A. 071-251-053E Muffler, Without EGR Port 1972
Note: 74 Models with EGR Port on Left Heater Box uses this Muffler as well
A. 071-251-053F Muffler, With EGR Port 73-74
B. 021-251-185F Tailpipe
C. 025-251-261 Gasket, Muffler to Heater Box Flange
D. 025-251-235 Gasket, Tailpipe
Manifold & Heater System
A. 021-256-091M Manifold/Heater Box, Left
Without EGR Port on Manifold/Heater Box
A. 021-256-091J Manifold/Heater Box, Left
1974 Models with EGR Port on Manifold/Heater Box
B. 021-256-092AC Manifold/Heater Box, Right 72-74
C. 021-256-251A Copper Gasket, Manifold to Head,1700 72-74
C. 039-256-251 Copper Gasket, Manifold to Head, 1800 1974
D. N 014 427 7 Stud, Exhaust Port, 1700 72-74
(D.) N 014 684 1 Stud, Exhaust Port 1800 1974 (Special 8x9x56)
E. 021-256-205K or L Heater Control/Flap Box, Left
E. 021-256-206K or L Heater Control/Flap Box, Right
F. 311-129-777 Swivel Pin/Clamp, Heater Cable |
Tcash Samba Member
Posted: Fri Jun 15, 2018 10:52 pm Post subject: Muffler, Exhaust and Heater 1975-1978 |
Some items shown in the next two pictures are becoming VERY difficult to obtain in good used, much less new. The manifolds and pipes are long ago discontinued items. Did you know that many Bus owners are now retro-fitting the 72-74 Bus exhaust system to their 75-78's? A very workable retro-fit. Just be sure to use the 039-256-251 Copper Exhaust Gaskets from the Head to the Heater Box Manifold Pipes for proper sealing. For more info, go to the Exhaust - Muffler & Heater 1972-1974 Section for all of the necessary parts listings. In addition, the Heater Control Flap/Boxes on the 72-74 are the same as your 75-78, so you don't have to replace these.
Note: This retro-fit is NOT legal for street use, especially in areas of the US that still have periodic emission-control (smog) checks, especially those requiring the installation of the Catalytic Converter. Check with Local Laws first before performing this retro-fit.
Muffler & Tailpipe
A. 071-251-053C Muffler
B. 021-251-521 Muffler Strap
C. 021-251-541 Connecting Pipe From Elbow To Muffler
Note: This pipe is only used on 75-78 models NOT originally
equipped with a Catalytic Converter.
Not Legal For Street Use On Models Originally Equipped
With Catalytic Converter.
Not Legal For Street Use On California Models 75-78.
D. 021-251-185F Tailpipe
E. 023-298-051 Exhaust Donut/Clamp Kit - Connects Pipe or Converter to Muffler
F. 025-251-235 Gasket Only, Tailpipe
Manifolds & Heater System
A. 021-251-551 Exhaust Manifold, Left
B. 021-251-552 Exhaust Manifold, Right
C. 039-256-251 Copper Gasket, Manifold to Head, 1800 1975, 2000 76-78
D. 043-251-509 Exhaust Triangle Gasket
E. 021-251-201 Exhaust "Afterburner" Pipe, Left or Right Side
F. 021-256-091T Heater Box, Left
G. 021-256-092T Heater Box, Right
H. 021-251-501 Exhaust Crossover Pipe With PreHeat Tube 75-Mid 76
To VIN 2x6 2070 000
J. 021-251-501A Exhaust Crossover Pipe Mid 76-78
From VIN 2x6 2070 001
K. 021-251-531 Exhaust Elbow
L. 070-251-235 Gasket, Elbow to Crossover Pipe
M. 021-256-205K or L Heater Control/Flap Box, Left
M. 021-256-206K or L Heater Control/Flap Box, Right
N. 311-129-777 Swivel Pin/Clamp, Heater Cable
P. N 014 684 1 Stud, Exhaust Port (Special 8x9x56) |
Tcash Samba Member
Posted: Fri Jun 15, 2018 10:58 pm Post subject: Muffler, Exhaust and Heater California 1979 Only |
Muffler & Tailpipe
C. See Note Not Applicable to California System
E. 023-298-051 Exhaust Donut/Clamp Kit - Connects Pipe to Muffler
Ref. Part Number Description Price
A. 039-251-551 Exhaust Manifold, Left
Becoming Very Rare! - Stainless Steel
B. 039-256-091D Heater Box, Left
C. 029-256-092C Heater Box, Right
D. 029-256-251A Exhaust Gasket, Manifold or Heater Box to Head
Cylinder 1 and 4
D. 029-256-252A Exhaust Gasket, Manifold or Heater Box to Head
Cylinder 2 and 3
E. 043-251-509 Exhaust Triangle Gasket
Connects Crossover Pipe to Left Manifold and both sides of Catalytic Converter
F. 025-251-261 Exhaust Gasket, Right Heater Box to Crossover Pipe
G. 039-251-497A Exhaust Crossover Pipe
H. 021-256-205K or L Heater Control/Flap Box, Left
H. 021-256-206K or L Heater Control/Flap Box, Right
J. 311-129-777 Swivel Pin/Clamp, Heater Cable
** N 014 684 1 Stud, Exhaust Port - Head to Manifold or Heater Box
(Special 8x9x56)(Not Shown) |
Tcash Samba Member
Posted: Fri Jun 15, 2018 11:02 pm Post subject: Muffler, Exhaust and Heater Federal 1979 Only |
Muffler & Tailpipe
Note: This pipe is only used on 1979 models NOT originally
Not Legal For Street Use On California 1979 Models
A. 039-256-091C Heater Box, Left
B. 029-256-092C Heater Box, Right
C. 039-251-497 Exhaust Crossover Pipe
Cylinder 1 and 4
Cylinder 2 and 3
E. 025-251-261 Gasket Only, Heater Box Flange to Crossover Pipe $3.75ea
F. 411-298-009 Gasket Set With Hardware, Heater Box Flange to Crossover Pipe (does both sides)
G. 043-251-509 Exhaust Triangle Gasket, Crossover Pipe to Catalytic Converter or Connecting Pipe
H. N 014 684 1 Stud, Exhaust Port - Head to Manifold or Heater Box
(Special 8x9x56)
J. 021-256-205K or L Heater Control/Flap Box, Left
J. 021-256-206K or L Heater Control/Flap Box, Right
K. 311-129-777 Swivel Pin/Clamp, Heater Cable |
Tcash Samba Member
Posted: Fri Jun 15, 2018 11:05 pm Post subject: Re: Exhaust Sytem Bay Window ID |
Heater Blower, Hoses & Air Channel Parts
Parts List
A. 411-963-007B Blower Motor Only
B. 261-261-195A Fan Housing
C. 211-261-269D Mounting Bracket Assembly
D. 021-256-331A Hot Air Tube, Left 72-78 & 1979 Federal Models
D. 039-256-331A Hot Air Tube, Left 1979 California Models
D. 021-256-332A Hot Air Tube, Right 72-74 & 1979 All Models
D. 021-256-332B Hot Air Tube, Right 75-78
E. 211-261-235 Fresh Air Hose, Left
F. 211-261-236A Fresh Air Hose, Right |
Tcash Samba Member
Posted: Sat Jun 16, 2018 10:30 am Post subject: NOS 211 251 051E T2a exhaust muffler Type I engine 1968-71 |
asiab3
"new Ernst and old factory Earnst from 1969. complete muffler kit from bus depot. muffler, damper, and tail pipe. for forums."
Tcash Samba Member
Posted: Sat Jun 16, 2018 10:47 am Post subject: NOS 211 251 051F T2 exhaust muffler 1600cc Type I engine 1972-79 |
NOS 211 251 051F T2a Exhaust muffler Type I engine 1972-79
211-298-055 - DAMPER PIPE & TAIL PIPE MOUNTING KIT - BUS 61-71.
000 071 331 Exhaust tip
NOS 211 251 051 L Leistritz exhaust 1600cc
1972-73 Type I 1600cc Exhaust pipe
Tcash Samba Member
Posted: Sat Jun 16, 2018 11:00 am Post subject: Exhaust - Muffler & Heater 1972-1974 Type IV engine |
Note: the Stainless steel Muffler is not stock, but who cares, it is a thing of beauty.
Notchboy
Tcash Samba Member
Posted: Sat Jun 16, 2018 11:02 am Post subject: Muffler, Exhaust and Heater 1975-1978 Type IV engine |
Our 76 Deluxe Westfalia ech_bus
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC
1975-78 NOS Exhaust Elbow 021 251 531
[url][/url]
Tcash Samba Member
Posted: Sat Jun 16, 2018 11:03 am Post subject: Muffler, Exhaust and Heater California 1979 Only Type IV engine |
1979 California Exhaust Left side parts
1979 Federal is the top little (inset) picture.
1979 California is the bottom little (inset) picture.
Tcash Samba Member
Posted: Sat Jun 16, 2018 11:05 am Post subject: Muffler, Exhaust and Heater Federal 1979 Only Type IV engine |
NOS 071 251 497 B Exhaust Crossover Pipe
Tcash Samba Member
Posted: Sat Jun 16, 2018 8:02 pm Post subject: 1979 Tourist Delivery |
Note the missing catalytic converter. I believe tourist buses such as mine were not equipped with it. This is a quote from VW documentation for '79 tourist buses, translated from German:
Quote: |
furgo
Changes to model year 1979
Due to the changes in emissions regulations, US vehicles will be equipped with a catalytic converter and California vehicles with an additional Lambda sensor. The catalytic converter and the Lambda sensor will not be built into tourist vehicles, so that these can be powered by leaded fuel.
furgo wrote: |
Excellent, thanks all. The DK 81-334-378 code might actually indicate a Dansk part number. I've found no information about it, other than another guy here at The Samba looking for info on it too.
I've looked more into this on the microfiches too. Good tip about the EGR, I can see where it was originally plugged now (marked with an arrow on the drawing below). The drawing shows the 72-74 muffler I've got (top) vs. the original '79 Federal setup (w/o catalytic converter in my case, bottom)
