TomWesty Samba Member
Joined: November 23, 2007 Posts: 3529 Location: Wyoming,USA
Posted: Thu Jun 21, 2018 3:58 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
jack-o-van wrote: |
TomWesty wrote: |
tommu wrote: |
I fitted the WW servo in the end. Adjusted the connecting rod and bled everything thoroughly. I immediately felt the same lack of brake modulation kreemoweet noted in his review. Brakes are very sharp indeed. It's unpleasant.
Anyone else tried this servo and had different results? Is there any adjustment I can do other than connecting rod? |
I don't know if it is the same brand as the WW one, but I bought mine for my '71 at EIS and it is branded Airtec. I set the pushrod the same protrusion as the one I removed and bolted everything up and it works great. |
So I've got the same question. Is the WW booster the same as Airtec? One thing that spooks me is the photos on the Airtec sold by Jbugs and the "WW brand" both show the same blue attach point on the front end. That's not conclusive but suggests they're the same.
- Jack |
Don’t know for sure, but common sense tells me that 2 manufacturers wouldn’t start building these at roughly the same time with a similar look for such a small market. I suspect the WW is an Airtec. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
jack-o-van Samba Member
Joined: April 27, 2017 Posts: 109 Location: Milwaukee
Posted: Thu Jun 21, 2018 10:22 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
Just realized that's you twice in there! You said "EIS" - what is that? _________________
If he meant it of me, he would have been "spot on" when AeroMech wrote: |
in my opinion you don't know shit |
And I love what raygreenwood wrote: |
I will probably be seen as an asshole for this comment.....but thats fine because I am an asshole. |
tommu  Samba Member
Posted: Thu Jun 21, 2018 10:23 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
jack-o-van wrote: |
You said "EIS" - what is that? |
https://www.eisparts.com _________________
Posted: Thu Jun 21, 2018 10:27 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
I'm confusing the hell out of myself by following two different threads on this topic!
Thanks, EIS is a new one for me!
- Jack. _________________
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42731 Location: at the beach
Posted: Fri Jun 22, 2018 7:00 am Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
I am confused by the EIS vacuum statement regarding the warranty. There is no vacuum limiter on these buses and most build more vacuum than the warranty allows. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Fri Jun 22, 2018 1:45 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
SGKent wrote: |
I am confused by the EIS vacuum statement regarding the warranty. There is no vacuum limiter on these buses and most build more vacuum than the warranty allows. |
I wondered about that statement too, but had no idea how much vacuum is usually generated (just now realizing I could have measured it easily...). Do many other cars have vacuum limiters?
Perhaps that's why the poster's on the original thread had problems with the Airtec booster - too much vacuum for it. If so, is there an aftermarket vacuum regulator you could put in-line, like the fuel pressure-regulator I have between my fuel pump and my 34Pict, that might make it work better?
Obviously they should have designed it for the working pressure in the bus, but given our limitations, might that be a workable solution? Maybe that's why that booster works for some and not others - variation in vacuum developed in their intake manifolds.
Anybody tried that or have any thought on whether it would work?
Joined: January 01, 2007 Posts: 17869 Location: sticksville, ct.
Posted: Fri Jun 22, 2018 1:52 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
holy crap dude....
I haven't followed every brake booster thread you've resurrected but why not send your booster out to be rebuilt?
I posted somewhere that these fit like ass, the mounts aren't right. I would rather have a german one rebuilt than use this pile of disappointment _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jun 22, 2018 5:25 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
skills@eurocarsplus wrote: |
holy crap dude....
I posted somewhere that these fit like ass, the mounts aren't right. I would rather have a german one rebuilt than use this pile of disappointment |
Guess I drank the koolaid, got sucked in by the hype. It'd be nice to have a new one, but you're right - it looks like a sendout rebuild will be the way to go. Thanks for your input.
Posted: Fri Jun 22, 2018 5:36 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
that will be your best bet really. I used one for a client when they were first out to market. it was horrible. I don't think you'll be let down by a rebuild _________________
Jake Raby wrote: |
Brian wrote: |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1640 Location: New Brunswick,Canada
Posted: Fri Jun 22, 2018 8:06 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
So the Bentley stresses the importance of that clearance, but doesn't say how to measure it. Once you put the pieces together you can't see those parts. Do you go by feel from the other end of the booster?
You can see the piston through the ports for the resoirvior, set the clearance before putting the resoirvior on. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Fri Jun 22, 2018 8:26 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
holy crap dude....
Skills, I think you are thinking of the Brazilian booster. These Airtec ones fit just fine, work just fine. Any marginally competent shade tree mechanic such as myself can replace one in a few hours. ( Time Includes M/C replacement and brake bleeding) _________________ If you haven't bled on them, you haven't worked on them.
Posted: Fri Jun 22, 2018 8:35 pm Post subject: Re: Wolfsburg West Brake Booster Vacuum Nipple |
lil-jinx wrote: |
You can see the piston through the ports for the resoirvior, set the clearance before putting the resoirvior on. |
Again I say: If you replace the old one with a new Airtec, which bolts right up and works fine by the way, simply measure how much your old push rod protrudes from the face of the booster, grab your 7mm and 8mm wrenches and adjust the new one to that length and you are off to the races. _________________ If you haven't bled on them, you haven't worked on them.
