dustymojave Samba Member
Joined: January 07, 2007 Posts: 5820 Location: Lake LA, Mojave Desert, SoCal
Posted: Sun Oct 08, 2017 11:46 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
I agree that Fox or King or other such rebuildable/revalvable shocks that cost 5X as much as KYBs will provide a better ride. They BETTER damned well work better.
Not all Bilsteins are rebuildable and the basic gas shocks intended to be installed on a VW bus tend to be harsh on a Bug.
The question of which shock works well for a given application tends to fit into the old hot rodder's saying - "Speed costs money, how fast can you afford to go?" _________________ Richard
SoCalBajas Member
75baja Samba Member
Joined: November 02, 2012 Posts: 19 Location: Tennessee
Posted: Mon Jul 02, 2018 6:56 pm Post subject: do i need these boots to go with my shocks? |
Working on my mild baja build and need to order some shocks for the the stock bj front end. Do I need these boots to go with the front shocks?
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3255 Location: Left of everywhere
Posted: Tue Jul 03, 2018 6:55 am Post subject: Re: do i need these boots to go with my shocks? |
| 75baja wrote: |
No. The shocks should come with the correct top rubber mounting.
Not sure but it looks like that boot is for a super beeetle with struts. Or it’s just for looks. |
Posted: Tue Jul 03, 2018 4:07 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
I agree that boot and bump stop are for McPherson strut Super Beetle, not for a beam suspended Bug. _________________ Richard
SoCalBajas Member
75baja Samba Member
Posted: Tue Jul 03, 2018 7:06 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
| Thanks, somebody along the line put them on front of my 75 standard. I thought it looked like it needed to be on a super. Gettin ready to order new shocks. |
Albertoprop17 Samba Member
Joined: March 15, 2016 Posts: 196 Location: Valencia (Spain)
Posted: Wed Mar 27, 2019 5:44 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
Does anybody used GAZ adjustable shocks? They have 20 positions of softest to hardest.
Maybe they would work well on a stocker... _________________ '54 vintage speed beetle slow project
Visit my workshop site and leave a like:
https://www.facebook.com/talleresalacreu/ |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue Apr 23, 2019 5:31 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
I just picked up a Baja project and I need some advice. I only get an hour or so every couple days on the computer so I have to get to the point. This Baja will be for street and moderate sand use.
This bug has a 6" wider beam with 1.5 wider X 3/4" longer arms, set up for coil overs. I'm looking for a moderately priced shock/coil over, any thoughts?
The rear has aftermarket 3 X 3 arms also set up for coil overs.,
This is my first time with anything other than stock VW suspension.
Any advice is welcome. Thanks for your time,
Jerry... _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
ringotuna Samba Member
Joined: March 03, 2019 Posts: 25 Location: Texas High Plains
Posted: Mon May 13, 2019 6:34 am Post subject: Re: SHOCKS SHOCKS SHOCKS |
I need advice on mounting coil over rear shocks on my rail.
Should I lift the rear end off the ground before mounting?
Should I mount the shocks fully extended or somewhat compressed?
Thanks
ringo. |
Posted: Thu Jul 04, 2019 2:18 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
I'm trying to determine which direction to go with my Baja build and naturally money plays into this decision.
The Bug has 3 x 3 arms on the rear and 1 1/2 x 3/4" front arms I need a ballpark price on King or Fox coilover shocks to fit this car.
Any help would be appreciated,
Jerry.... _________________ Jerry...
RIP Morgan
My photos
Posted: Sat Jul 06, 2019 9:42 am Post subject: Re: SHOCKS SHOCKS SHOCKS |
| lostinbaja wrote: |
Jerry.... |
Does it have existing shocks that you want to replace? Does the car have shock mounts built? Or are you looking to build mounts to fit?
If it has existing shocks, you will need to take those off and measure full extended length mounting bolt to mounting bolt.
If it doesn't have current shocks, but has mounts, you will need to measure the distance from upper to lower mount extended, and compressed (bottomed out against the stop).
If you don't have existing mounts...You need a fabricator to figure out where to mount the shocks and figure out what travel length shocks you want. If not capable of doing that yourself, and your question here suggests that you are not, then you need a professional to do it for you.
Shocks are available from many sources. Kartek is one. _________________ Richard
SoCalBajas Member
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Mon Sep 23, 2019 7:00 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
Is there a company that sells the springs on the coilover shocks in a higher lbs rating? I'm guessing they are not a very stiff spring right? I'm looking to be able to hold a lot more weight than a beetle was probably ever meant to. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
MotoMike Samba Member
Joined: June 13, 2013 Posts: 120 Location: Durango, CO
Posted: Fri Sep 27, 2019 11:56 am Post subject: Re: SHOCKS SHOCKS SHOCKS |
I just bought a set of Bilsteins for my 72 Baja, mail order deal, the rears are correct but the fronts are not even close. Part number 24-006200 is what it calls for in the catalog and pretty much any where else I look, but they are 3" shorter than what I have now and the stud on the top of the shock wouldn't work even if it was the right length. Good luck getting any one to talk to you where I bought them from (shockwarehouse.com, buyer beware)
Anybody out there have any suggestions? |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2286 Location: No. Idaho
Posted: Sat Sep 28, 2019 6:40 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
| MotoMike wrote: |
What specs do you have now? Do the shocks you have measure up to what they should? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Sun Sep 29, 2019 7:14 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
| MotoMike wrote: |
The front bilstein s. On mine are B46-0493VW |
Posted: Sun Oct 06, 2019 8:47 am Post subject: Re: SHOCKS SHOCKS SHOCKS |
| Mikedrevguy wrote: |
| MotoMike wrote: |
What specs do you have now? Do the shocks you have measure up to what they should? |
I got it figured out, just a lack of knowledge on my part with ball joint shocks. They are the correct shocks, I just had to order the mounting stuff that goes on the end of the shaft |
Posted: Sun Oct 13, 2019 6:08 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
| MotoMike wrote: |
| MotoMike wrote: |
Post pics. I’d be I ter3sted to see what the issue was. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Panzerschreck Samba Member
Joined: October 19, 2019 Posts: 16 Location: Pacific NW
Posted: Sun Oct 20, 2019 12:16 am Post subject: Re: SHOCKS SHOCKS SHOCKS |
| MotoMike wrote: |
| MotoMike wrote: |
What kit did you end up purchasing for the Bilsteins? |
Double-Double Samba Member
Posted: Sat Nov 02, 2019 8:05 pm Post subject: Re: SHOCKS SHOCKS SHOCKS |
| Is there a correlation between lift amount in the back and additional shock length needed or does it not work that way? I.e. 2” lift via preload and need 2” longer shocks? |
Posted: Sun Nov 03, 2019 8:59 am Post subject: Re: SHOCKS SHOCKS SHOCKS |
| Double-Double wrote: |
I would suggest that there is a correlation but not direct.
One Is the shock is not at the wheel location and because the wheel is farther out and there are angles involved the wheel travel is greater than the shock travel.
Two Until you start to notch the spring plates you do not need a longer than stock shock |
Posted: Sun Nov 03, 2019 11:47 am Post subject: Re: SHOCKS SHOCKS SHOCKS |
| dirtkeeper wrote: |
Thanks! I figured there is probably some Pythagorean theorem for figuring it out. I have the Atomwerk 2” raise plates so I will have to play it by ear and measure when I get them on and do the cycle up and down thing. |
