Diagnosing shifter issues
tthoms
tthoms is offline
PostPosted: Tue Jul 03, 2018 11:11 pm    Post subject: Diagnosing shifter issues Reply with quote
I've done a search on the issue, and I could find a post that exactly fit my case. I've been tooling around in my '71 bug, and I'm noticing that when I depress the clutch and move the shifter, it takes like a second or two for the shifter to allow itself to move into the desired gear. Upshifting, down shifting through any gear, it doesn't seem to matter as far as I can tell. Downshifting to second has enough resistance that I often find myself in fourth gear.
I have no problem getting into reverse.
There's not a lot of play in the clutch (again, as far as I can tell). I'm quite a novice at VW mechanics, and I'm in this late enough that I'm not 100% certain how it's supposed to feel.
Any tips as to where I should start looking to resolve this?
Thanks in advance.
Coyotemutt
Coyotemutt is offline
PostPosted: Tue Jul 03, 2018 11:18 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
Kinda sounds like you might not have the Bowden tube in place. My shifting gets imprecise like that when the cable starts to stretch or when (over a decade ago) I first got the car and the Bowden tube was missing.
tthoms
tthoms is offline
PostPosted: Thu Jul 05, 2018 5:07 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
I had a look. I found the Bowden tube (as well as a black widow nest, ugh), so that's not the issue. I gave the adjuster another full twist to see what difference that made. Unfortunately, it's raining now, and the car's not ready for rain.
I shifted through all of the gears with the engine off. Lots of noise coming from the shifter, and some resistance in the process of shifting. I don't know if that means anything.
modok
modok is offline
PostPosted: Thu Jul 05, 2018 6:19 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
If it's not grinding going into reverse, then the clutch is letting go just fine.
What about the oil in the transmission?
is it full of sludge? air? or oil of some known qualities?
Casting Timmy
Casting Timmy is offline
PostPosted: Thu Jul 05, 2018 7:15 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
If you make a lot of noise shifting through the gears with the engine off, I'd start there.
rs58rag
rs58rag is offline
PostPosted: Thu Jul 05, 2018 7:43 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
Easiest check is the coupler that connects the shift rod to the transmission, located under rear seat. Then there's a shift rod bushing just behind the shifter in the tunnel. Also shifter could be worn or defective, check ball end that connects to shift rod socket. Seen some dry, gouged up, unmaintained shifter ends.
tthoms
tthoms is offline
PostPosted: Fri Jul 06, 2018 2:19 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
I checked the oil a few months back. It was at the right level, and the sample I took from the top looked pretty good. However, it was from the PO, so I don't know the history. I'd better change it.
tthoms
tthoms is offline
PostPosted: Fri Jul 06, 2018 2:21 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
I'll poke around there, I've never really had a good look at these parts before. I'm hoping that if there is a problem. it will be obvious.
Thanks to all!
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Fri Jul 06, 2018 2:23 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
I agree that the coupler sounds bad. The rubber side pieces sometimes become gummy. That causes a strange shift into and out of gears. Quick check will let you know.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
tthoms
tthoms is offline
PostPosted: Thu Jul 12, 2018 6:49 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
Okay, I went in and examined the contact points in question.
The coupler needs a cleaning, and there's some play in it when the shifter is moved. There's also a piece of safety wire towards the back, securing the back screw. I don't know how it is supposed to look, so I can't see anything wrong with it.
The shifter itself. I can't see anything wrong with that either.
The shifter plate and socket. As far as I can tell, ok from this angle.
Here's where I get nervous. There's a plastic ring around the rod that leads to the back. It seems to be split, and slides freely on the shaft.
That's bad, isn't it?
67rustavenger
67rustavenger is offline
PostPosted: Thu Jul 12, 2018 7:21 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
It slides freely on the shaft. Or the shaft slides through the bushing freely?
Makes a difference.
All of the bushings I have ever looked at are split and and have a retaining ring around the forward end of the bushing.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
66brm
66brm is offline
PostPosted: Thu Jul 12, 2018 7:29 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
Wiggle the coupler back and forth, both shafts should move together, if they don't then there's a big part of the problem. Looks like the safety wire for the lock screw has broken
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
tthoms
tthoms is offline
PostPosted: Thu Jul 12, 2018 8:00 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
I'll check tomorrow.
tthoms
tthoms is offline
PostPosted: Thu Jul 12, 2018 8:01 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
Makes a difference.
I can spin bushing around and slide it up and down the shaft with a q-tip.
Cusser
Cusser is offline
PostPosted: Thu Jul 12, 2018 9:34 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
Sounds like the shift bushing is no longer seated in the hole in the bracket, like you need a new shift bushing.
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jul 12, 2018 11:48 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
New one looks like this:
Here is a diagram to help you:
There are threads on how to replace this. It's a greasy job but that, along with replacing or refurbishing the coupler under the seat, will make it shift much better. Don't take shortcuts, or you will be doing it again shortly.
Cusser
Cusser is offline
PostPosted: Fri Jul 13, 2018 8:25 am    Post subject: Re: Diagnosing shifter issues Reply with quote
I just replaced the factory shift bushing on my 1970 a few months ago, with photos on page 21 of my resurrection thread https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=400
I did this 2 decades ago on my 1971 Super, was a little easier because the shift rod on a 1971 Super can move forward enough so taking off front panels is not necessary.
Apparently German-made shift bushings are available, from advertisers like CB Performance.
tthoms
tthoms is offline
PostPosted: Mon Jul 16, 2018 3:01 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
Thanks everyone for the tips and links. I plan on replacing the bushing, and though its not obvious they need it, the rubber parts of the coupler. Ordering the parts today.
Thanks again!
mcmscott
mcmscott is offline
PostPosted: Mon Jul 16, 2018 3:33 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
If you replace the coupler, re-use the original cage, throw the new one in the trash and just use the new bushings.
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
KTPhil is offline
PostPosted: Mon Jul 16, 2018 3:43 pm    Post subject: Re: Diagnosing shifter issues Reply with quote
X2, all the metal parts of the kits I've seen are garbage. The rubber is what you are after; that's usually all that wears.
