danielzink Samba Member
Joined: August 03, 2004 Posts: 291 Location: Lansing Michigan
Posted: Thu Jul 19, 2018 7:53 am Post subject: Brazilian "1960" bus questions |
The owner of the company that I work for has asked me do some work on his bus.
He has admitted that it is (in his words) a "brazil" bus from 1960.
I'm no bus expert as far as production by any stretch of the imagination...but I have done quite a but of reading in this particular forum (especially the whine/discussion) and I know that these "brazilian" buses are trying to be passed as "older".
So I don't know...is this bus 10 years old ? is it a legit 1960 ?...
I think he said the title reads 1960
I'm asking because I need to order some parts...so I want to make sure I order the correct year.
It has a kM speedo - he wants an MPH speedo.
He wants to convert to front discs...
Should I just order parts as for a 1960 ?
Thanks for any help.
Dan
EDIT:
and yes - I have read through the "front disc brake conversion" thread https://www.thesamba.com/vw/forum/viewtopic.php?t=475194 quite thoroughly _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
www.danielzink.com |
Clara Samba Member
Posted: Thu Jul 19, 2018 8:05 am Post subject: Re: Brazilian "1960" bus questions |
Is it a legit 60? If it was made in 1960 then yes.
Is it the same as a German 1960 bus? Probably no. It seems that parts were used at different times in the Brazil buses, so it may have parts that were phased out earlier on German buses.
We are not experts on when the changes were made on the Brazilian buses.
AFAIK, split buses speedos are interchangeable from 56- through 67, and probably fit a Brazilian split bus. You want the one rated for the size tires it runs -- there is a 14" tire version and a 15" tire version. I would expect yours has the earlier (15") version.
For the front brakes... if it has a 3/4 ton suspension it should take the 60 style brakes. used 56-63. The one ton was an option as of 63, standard as of 1964, on German buses. I would expect it came new with a 3/4 ton suspension.
But it's not new now, is it?
It may have a 1 ton bolted in. My 61 had a 1 ton suspension in it when I bought it in the nineties.
what does the grease cap over the spindle nuts look like? |
easy e Samba Member
Joined: May 28, 2008 Posts: 3940 Location: 1 hr north of Santa Barbara
Posted: Thu Jul 19, 2018 9:03 am Post subject: Re: Brazilian "1960" bus questions |
You can pick up a speedo out of the classifieds.
This will help you decide which to aim for: Speedometer Changes
You can probably tell what spindle it is by the wheel bearing nut or grease cap.
Here's how German ones basically are:
-63 = 22mm x 1.5 pitch
Grease cap has tapered sides and not very tall.
Google this: 211405672
63-67 = 18mm x 1.0 pitch
Grease cap sticks out kinda far and doesn't have tapered sides.
Google this: 211405672A _________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
Posted: Fri Jul 20, 2018 5:14 am Post subject: Re: Brazilian "1960" bus questions |
Okay - he scanned the registration and sent it to me.
It's a series of 5 digits VW in the middle the 60 at the end ie:
12345VW60
Does that follow "conventional" VIN numbers for a 1960 bus ?
Thanks. _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 964 Location: Las Vegas, NV
Posted: Fri Jul 20, 2018 6:14 am Post subject: Re: Brazilian "1960" bus questions |
| danielzink wrote: |
12345VW60
Thanks. |
The VIN number you listed looks made up to me. 12345VW60
The VIN numbers for 1960 buses delivered to the US went from 484280-628443. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Fri Jul 20, 2018 8:05 am Post subject: Re: Brazilian "1960" bus questions |
| ronjonlasvegas wrote: |
| danielzink wrote: |
12345VW60
Thanks. |
The VIN numbers for 1960 buses delivered to the US went from 484280-628443. |
Well yes....
I made up the 12345....
How about this:
XXXXXVW60 (with the x's representing a series of 5 numbers).... _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
EverettB  Administrator
Joined: April 11, 2000 Posts: 71832 Location: Phoenix 602
Posted: Fri Jul 20, 2018 1:40 pm Post subject: Re: Brazilian "1960" bus questions |
| EverettB wrote: |
| It should be a 6 digit number like what ronjohn said |
Ok Thanks.
So. Not like I'm going to call my boss out or anything....
But for my own info...what is this thing ?
Is this the typical numbering convention for a "brazilian" bus ?
And how were these things built ?
The registration lists as a 1960....
Were these built recently with old NOS chassis so they could be registered as 1960's era buses ?
Thanks _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
Posted: Fri Jul 20, 2018 6:27 pm Post subject: Re: Brazilian "1960" bus questions |
I can't remember seeing any VIN # in that format or a Bus, Brazilian or otherwise.
I'm not familiar with the Brazilian Bus VIN #s though but I found this post in another thread with some info:
https://www.thesamba.com/vw/forum/viewtopic.php?p=2609428#2609428
It looks like a '60 would still be a straight VIN # with no special characters or year in the VIN #.
Possible wrong year on title:
I have seen Brazilian Buses listed as seemingly random years in the classifieds here.
I sort of assumed all of the ones that were listed as 1960 were BS and registered wrong since they look just like the 1970s Brazilian 15-Window Buses but obviously there are real 1960s Buses made in Brazil. _________________ How to Post Photos
EmpiGT Samba Member
Posted: Fri Jul 20, 2018 6:35 pm Post subject: Re: Brazilian "1960" bus questions |
| To me that sounds like a state issued vin for cars with vin problems. can you take a pic of the vin plate. Also pics of the bus. There is some knowledge about Brazilian built busses on here we can narrow down some on the Brazilian models, but alot harder than german built busses. |
Posted: Sat Jul 21, 2018 5:36 am Post subject: Re: Brazilian "1960" bus questions |
| EverettB wrote: |
I sort of assumed all of the ones that were listed as 1960 were BS and registered wrong since they look just like the 1970s Brazilian 15-Window Buses but obviously there are real 1960s Buses made in Brazil. |
| EmpiGT wrote: |
Thanks and Thanks.
It'll be in my barn a couple weeks...I'll snap some pics and post them.
Dan _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
