bmlb929 Samba Member
Posted: Tue Jul 17, 2018 2:07 pm Post subject: Re: What did you do to your Bug Today? |
| Finished the valve covers. Cleaned the underneath. Adjusted the idle. |
Ron G Samba Member
Joined: September 05, 2013 Posts: 228 Location: Albuquerque, NM
Posted: Sat Jul 21, 2018 7:57 am Post subject: Re: What did you do to your Bug Today? |
Just got done with a 4 long year Restoration
1745cc 85.5 x 76mm
SiRJoZ Samba Member
Posted: Sat Jul 21, 2018 9:22 am Post subject: Re: What did you do to your Bug Today? |
Since I just signed up, I’m going to bend the rules of this thread and cover the last 72 hours.
Wednesday - bought my first bug - 1970 w/sunroof. Ordered new light switch.
Thursday - replaced distributor mount (because the distributor was loose) and took it for a spin. Decided that I might be running too rich because it runs nice and smooth at idle and under normal acceleration, but it gives me the occasional pop and stutter if I put the peddle to the floor. Still pulls pretty strong the entire time...it’s just making noises that I know it shouldn’t. I’ll check the plugs before I tamper with the carb though, and I’m open to any other recommendations.
Friday - looked at her longingly...
Today - started working on sunroof install. Had to stop to order missing/cracked pieces. I would drive over to JBugs but they aren’t open today.
So I’ll move on to installing door seals and a new blinker switch. Then I’ll center the bumpers and tighten the mounts. |
Hippie1303 Samba Member
Joined: April 22, 2008 Posts: 174 Location: Albuquerque New Mexico
Posted: Sat Jul 21, 2018 2:54 pm Post subject: Re: What did you do to your Bug Today? |
Got it back from the mechanic two days ago, all new brakes and new tires, registered it today, drove it all around. Two or three months of working on it / having work done now its road worthy. _________________ How is my Beetle any less of a car? If anything, it's more of a car, since there's no computers intervening for every little function. |
Jazzfess  Samba Member
Joined: November 27, 2013 Posts: 67 Location: Woodstock, NY (where the festival wasn’t held)
Posted: Sun Jul 22, 2018 5:40 am Post subject: Re: What did you do to your Bug Today? |
Nothing so far. I have a ’68 and a ’72 convertible bug standing by, waiting for the thunder storms to roll through. Hanging garlic to dry instead.
One of three bushels, about 175 plants, need to be hung to dry.
[/img] |
ctknecht Samba Member
Joined: March 14, 2018 Posts: 46 Location: San Antonio, TX
Posted: Sun Jul 22, 2018 4:50 pm Post subject: Re: What did you do to your Bug Today? |
Installed rebuilt carburetor from VolkzBitz (Thanks, Tim! You rock!).
Old vs Rebuilt pic:
Engine bay with new carb, distributor, fuel pump, vacuum lines, fuel lines, a cleaned generator and a "clean" air filter (soon-to-be-project is to make it look pretty too):
Runs great!
Next major task is to find the oil leak and repair it.
Fahrvergnügen _________________ Chris & Chris
San Antonio, TX
1964 Beetle (still 1200cc) |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6635 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Sun Jul 22, 2018 5:45 pm Post subject: Re: What did you do to your Bug Today? |
Finally got around to cutting my pushrods to length. I'll put a video together of it later, but I used a $35 2" cutoff saw to keep them square and with a stop block they're the same length.
Saw: https://www.amazon.com/gp/product/B077G8ZKX3/
Installed them and the valve train looks great. The fatter heads on these Mantons made them a bit too long compared to my adjustable pushrod. But I had enough room in the geometry to stick another shim under the Scat 1.25 rocker assembly to keep things in line. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Sun Jul 22, 2018 5:57 pm Post subject: Re: What did you do to your Bug Today? |
| Ron G wrote: |
1745cc 85.5 x 76mm
Looking good! Congrats! For me, I went to Advance Auto yesterday to pick up a fan belt, and there were kids running a carwash. Most of the kids said "I like your bug" or similar. The last kid said "Gee, that car's seen better days." I said "so has your mom." Ok, I didn't really say that, but I thought it. Needless to say, your car is making mine jealous. The seats and steering wheel are great! Congratulations on the restoration. _________________ Daily driven....Slowly. |
Ron G Samba Member
Posted: Sun Jul 22, 2018 6:20 pm Post subject: Re: What did you do to your Bug Today? |
| Thank you slow bug for the nice comments, it was a fun project |
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Mon Jul 23, 2018 9:32 am Post subject: Re: What did you do to your Bug Today? |
Not exactly something I have done yet, but more of prepping for work. Picked up an entire early 944NA rear end, front brakes and spindles, and a miss matched phone dials (15x6 and 16x8 both late offset) all for $300 and a bunch of driving yesterday. Think ima need new front rotors, pads, then I need to get my spindles and front hubs machined by Vdub engr and get proper swans for the e-brake, but all in all, not bad for a 4 wheel high performance disk conversion
_________________ '74 - front disks/lots more work to do |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1143 Location: North East Pennsylvania
Posted: Thu Jul 26, 2018 4:27 pm Post subject: Re: What did you do to your Bug Today? |
I cleaned and painted the wheels for my 1973 project Bug. Massey Fergusson Gray tractor paint for the back and Rustoleum Wheel Steel for the front.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Posted: Sat Jul 28, 2018 9:15 pm Post subject: Re: What did you do to your Bug Today? |
| Changed the oil. Tightened bolts. Took a drive. |
Posted: Sun Jul 29, 2018 8:35 pm Post subject: Re: What did you do to your Bug Today? |
| Began steering system rebuild. Possible disc brake conversion. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33416 Location: Hot Arizona
Posted: Mon Jul 30, 2018 8:06 pm Post subject: Re: What did you do to your Bug Today? |
I drove my 1971 Convertible top down to WalMart 2.5 miles away to pick up some groceries. During the 15 minutes I was in there, a huge "haboob" or monsoon dust storm developed, I jumped in and raced home in the dust storm and severe winds, but got home before the rain started.
So a first for everything... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
alex857 Samba Member
Joined: December 26, 2010 Posts: 780 Location: Stuttgart/Germany
Posted: Mon Jul 30, 2018 11:07 pm Post subject: Re: What did you do to your Bug Today? |
Installed a new Mexican Bosch Generator on my 1983 Mexican Beetle (because the old one had really loud bearings after 200.000 Kilometers and yes I will rebuild the old one) with the engine in, after removing the deck lid it is all accessible. I disassembled everything a couple of weeks ago, cleaned it all up, fought rust on the engine tins, and reassembled it today.
Runs again. |
seiyaTokyo Samba Member
Posted: Wed Aug 01, 2018 3:12 am Post subject: What did you do to your Bug Today? |
Hello from Tokyo Japan.
I am a beginner of air cooled beetle. I drove my lovely 74beetle 1200 STD along the shore!! Happy!!
Thanks
Seiya @seiyajapan.com |
Posted: Thu Aug 02, 2018 9:07 am Post subject: Re: What did you do to your Bug Today? |
I got a ton done yesterday. Got literally the entire front end out minus the gas tank and steering box (but those may come out soon, we will see). Found a few problems while I was at it. Turns out my front sway bar is flat out cracked (didn’t know that was possible tbh), my shocks are shot, couple of tie rod ends need to be replaced (just doing all of them though) and I have one perfectly fine ball joint while the rest are shot for some reason. Bit of a fun discovery was that the bottom of one of my front shocks was literally only held on by being seized to the mount as the nut and washer were long gone and I have one ball joint I can’t seem to loosen at all (though I did get a tip at how to get the nut off). The gunk built up was just nuts (about an hour was just cleaning off the nuts and bolts to even get at them), but over all it was some good work.
My initial plan was to go out yesterday and get new ball joints pressed in and buy tie rod ends, but needing new front shocks anyways, I decided to move up part of the project and drove up to Pasadena and picked up KYB soft ride gas shocks, front and rear 3/4" sway bars, and the ball joints and tie rod ends I needed.
Also, Im thinking about getting a build thread started since this is just kind of the beginning of my journey _________________ '74 - front disks/lots more work to do |
kpf Samba Member
Joined: March 01, 2017 Posts: 1061 Location: California, US
Posted: Thu Aug 02, 2018 5:59 pm Post subject: Re: What did you do to your Bug Today? |
| seiyaTokyo wrote: |
Thanks
Hi Seiya,
I always enjoy your movies. Nice camera angle on this one. Thank you for sharing!
Kris _________________ 1971 Super Beetle |
ShaneS2992 Samba Member
Posted: Sun Aug 05, 2018 10:30 pm Post subject: Re: What did you do to your Bug Today? |
In the last couple days I've installed a Retrosound Long Beach running 6.5" speakers in kick panels with tweeters on the dash and a single 10" sub behind the back seat powered by a JBL amp in the batter tray.
Took me a while to get the wiring correct but, sounds way better than the stock 4 inch speaker.
This has inspired me to work through the wiring and clean up the rats nest in the trunk from previous owners as my next project...
I also did a valve adjustment and an oil change today just to give some love to the motor amidst the realisation of the electrical work to come... |
Posted: Tue Aug 07, 2018 7:46 pm Post subject: Re: What did you do to your Bug Today? |
I went to the automatic carwash. And got soaked. My door seals and quarter glass seals need replaced. This never happens in the rain, but the high pressure wash is a different story I guess. The bug came out nice and clean though. I let the interior air dry in the garage. I have no carpet, so no big deal. _________________ Daily driven....Slowly. |
