BigWhiteVan Samba Member
Posted: Tue Jul 24, 2018 7:37 pm Post subject: Shifting into reverse question |
I have an 85 Vanagon, I am pretty sure it's 1.9L, and water cooled. It's been driving like a charm (after getting a new engine). However, the shifter is pretty wobbly and sometimes I have a hard time putting into first.
I plan to install some GoWesty shifter tabs, thinking that should help this. Sounds right?
While doing some research, I found that some people have to push down the shifter to get the van into Reverse. This is not the case for us. Is this normal... Or does this tell us something else?
Any tips would help. And thanks for all the help this community has already provided. |
Borg Samba Member
Joined: October 18, 2012 Posts: 131 Location: Western Washington
Posted: Tue Jul 24, 2018 8:00 pm Post subject: Re: Shifting into reverse question |
There are a bunch of plastic parts that make up the shifter linkage. The past 33 years of shifting will have worn down at least some of them. Your linkage sounds pretty sloppy, take a good look in there and just plan on fitting new bits. _________________ Steve |
elizer Samba Member
Joined: May 02, 2016 Posts: 1501 Location: Northern Virginia
Posted: Tue Jul 24, 2018 8:10 pm Post subject: Re: Shifting into reverse question |
| Shifter tabs may solve your problem. If you can just go all the way left and up without pressing down that may be the issue. Crawl under the van. drop your spare and you can see if they are worn down. |
Boas Samba Member
Posted: Wed Jul 25, 2018 12:04 pm Post subject: Re: Shifting into reverse question |
OP seems to have been asking if the default action for shifting into reverse is to push down on the shifter before moving it into place. The answer is yes, you engage the clutch, push the shifter down towards the floor, and move it from neutral (center) to reverse (left and up). _________________ 1987 Vanagon Weekender
2450 cc GoWesty engine
GoWesty EFI |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10322 Location: Mt Lemmon, AZ
Posted: Wed Jul 25, 2018 1:12 pm Post subject: Re: Shifting into reverse question |
You should certainly inspect the tabs as a lot of wear on them (or completely missing) would make for sloppy shifting and allow you to easily get past the reverse lock-out.
As a reference - Mine are worn (270K miles) but still shift well:
You can get a look at them by just crawling under the van - easiest way is to just point a digital camera in their general direction and snap a bunch of pix - then examine those. That is how I got that shot. |
