old_man Samba Member
Joined: June 19, 2018 Posts: 1414 Location: Newfoundland
Posted: Sat Aug 04, 2018 2:03 pm Post subject: My 67 Squareback |
So I bought a car. It will be a project to keep me busy now and during the winter.
Here is the engine. I am not sure what exact kind it is. It doesn't have a lot if miles on it since it's last rebuild. I'm new to carburettors so it will be a learning experience.
A bit of figureing out here.
There are 4 of the one on the right and two of the one on the left. The wife wants the one on the left. Anyone know what the one on the right is?
Over all it seems in decent enough shape. It's going to need a new windshield, all new rubber everywhere, new dash, 2 front seat covers, carpet, and probably the usual stuff on the engine. This car hasn't really moved in about 15 years. Paint is new. Most of the parts are inside the car, the only thing I can't find is the turn signals for the 2 front corners and some trim pieces.
This should be an adventure. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4760 Location: Pasadena CA/DTLA soon China
Posted: Sat Aug 04, 2018 3:08 pm Post subject: Re: My 67 Squareback |
Nice to see another squeraeback being brought back to life. You'll love the drive and the tons of space these little cars have. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
rustyfastback Samba Member
Posted: Sat Aug 04, 2018 3:15 pm Post subject: Re: My 67 Squareback |
| Looks like a good solid project. By the way that other hubcap is from a Studebaker. Looks like you have the correct '67 style hub cap in good shape. |
Posted: Sat Aug 04, 2018 3:25 pm Post subject: Re: My 67 Squareback |
| rustyfastback wrote: |
Good to know. I actually only have 2 of the VW ones. Looks like I need to look for another 2. I also need wipers. What kind of front turn signals do I need/will fit? |
Posted: Sat Aug 04, 2018 4:48 pm Post subject: Re: My 67 Squareback |
| old_man wrote: |
Look at my avatar _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Sun Aug 05, 2018 7:53 am Post subject: Re: My 67 Squareback |
So the wife and I did a bit of cleaning this morning on the car because she wasn't overly impressed with the smell in 'her garage'.
The seller said the floor boards were solid and didn't have any rust. I didn't really get a chance to do a thorough inspection before purchase.
True to the seller's word, they seem very solid and I can't find any rust.
Seller warned me the battery tray was rusted out.
It's got 3 or 4 small rust holes but overall I was expecting much worse. It still can hold a battery but some remediation is probably required. Still happy with it.
Cool.
Cleaned a lot, seats are too bad actually. Current plan is to save the rear and recover the fronts.
I found this alternator/generator. Anyone know what it would be? Was part of a plan to do an alternator conversion? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18056 Location: Eugene, OR
Posted: Sun Aug 05, 2018 8:40 am Post subject: Re: My 67 Squareback |
That Made in USA generator is not meant for a VW. A lot of chrome etc molded off your '67! Did you get any of it with the car? It would've looked like this '67 originally. You're missing the big black stock air cleaner on your engine. _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23604 Location: Kimball, Mi
Posted: Sun Aug 05, 2018 9:36 am Post subject: Re: My 67 Squareback |
Like Mike said, the Delco generator is from a mid 50'sto mid 60's GM (Chev, Pont, Buick, Olds).
I'm going to suggest you do like I mentioned to Temmet, go to the technical section (click on the link in the upper right, just below the banner), it defaults to type 2, so you'll have to click on type 3, then bring up the wiring diagram for your year (67), and download it to a memory stick. Take that to someone like Kinko's, and have them print it out (preferably larger), and have it laminated. This will make it easier to follow along for your wiring.
I'd also get a Haynes manual for type 3s, and a brown Bentley. I realize the brown Bentley is wrong for your year, but it contains everything you need for your 67 other than the carbs (what the Haynes is for). Or, you could spend a lot more, and buy the big Blue Bentley for 61-67 cars.
You might want to lay out what you got, so we can see if you're missing anything.
Looks like a nice project. And I hope this helps. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Sun Aug 05, 2018 10:05 am Post subject: Re: My 67 Squareback |
| Mike Fisher wrote: |
| That Made in USA generator is not meant for a VW. A lot of chrome etc molded off your '67! Did you get any of it with the car? It would've looked like this '67 originally. You're missing the big black stock air cleaner on your engine. |
I've got the big black stock air cleaner. I have the bumbers, head lights, tail lights, and what I think are all the door grabs, latches, and keyholes..etc. What I do know I am missing are the lower turn signals on all 4 corners. I can't seem to find them. I will have to scourer the classifieds for a set.
As well, I am missing the chroming running strips that run down the sides, I'm assuming they got damaged when there were removed for the paint job. I'm going to have to get new ones, are the ones I see available for sale good or not? I also see they have SS ones and Al ones. Any recommendations?
I have the chrome/Al trim pieces for around the windows but they are not in good shape, is it simpler to just order new ones or should I try to massages them back into shape? On my P-car it is common practice to just get new ones because once they are bent they will never fit right.
| bobnotch wrote: |
I'm going to suggest you do like I mentioned to Temmet, go to the technical section (click on the link in the upper right, just below the banner), it defaults to type 2, so you'll have to click on type 3, then bring up the wiring diagram for your year (67), and download it to a memory stick. Take that to someone like Kinko's, and have them print it out (preferably larger), and have it laminated. This will make it easier to follow along for your wiring. |
Already on that. I love that the wiring diagram can fit on one page.
| bobnotch wrote: |
I'd also get a Haynes manual for type 3s, and a brown Bentley. I realize the brown Bentley is wrong for your year, but it contains everything you need for your 67 other than the carbs (what the Haynes is for). Or, you could spend a lot more, and buy the big Blue Bentley for 61-67 cars. |
I already got the big blue one. I've never worked on carbs in my life so I need all the help I can get there.
Thanks for the help identifying the spare generator. The car was located with a lot of other cars so maybe it came from one of them. I'll try to remember to bring it back to the guy if he wants it.
I did a bit more cleaning to try to size things up and see if get ride of any mustyness.
This is the back. It's got some rust but I think I can salvage it all without having to weld in new metal. It seems to be mostly just surface rust. I think I will just clean it up and use something like rust bullet. After that I am going to give everything a good dose of fluid film. Overall I am still quite pleased with the condition of this car.
I also noticed that there are holes on the roof. I can only assume that these were for a roof rack. So I guess at this point I either have to patch the holes (I really don't want to) or find me a roof rack that fits. Any of you fine people have any idea what roof rack would line up with these holes? |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1900 Location: Feeling, Minnesota
Posted: Sun Aug 05, 2018 5:19 pm Post subject: Re: My 67 Squareback |
| old_man wrote: |
It looks like those holes would line up with a VWOA dealer accessory roof rack.
_________________ 1968 Regatta Blue Squareback
1967 Granada Red Squareback
1971 Rattle-Can Red Westfalia Camper |
Posted: Mon Aug 06, 2018 4:47 am Post subject: Re: My 67 Squareback |
| BSQUARE wrote: |
I was looking at those earlier and it did sort of look like it could match. So now I either have to find one or plug the holes. |
Posted: Mon Aug 06, 2018 8:50 am Post subject: Re: My 67 Squareback |
So I finally got it up on the hoist. Underneath looks decent to my untrained eyes. I am just going to post a bunch of pictures of the underside and wheel wells. Please tell me if any of you spot something that needs addressing.
To me it looks like the rubber bushing 'cold flowed' and needs to be replaced. This is common on porsches after a few decades. Is this the case here?
Can someone tell me exactly what engine I have in here?
I have had these sitting in my garage for years not being used. Bolt pattern is wrong and I am not sure the bore is big enough. What do you think?
Also here is a video of the muffler that came separate. Is this normal or how is it exactly suppose to fit/tighten?
.....still happy. |
Posted: Mon Aug 06, 2018 2:02 pm Post subject: Re: My 67 Squareback |
| old_man wrote: |
Tthis looks like the rubber bushing 'cold flowed' and needs to be replaced. This is common on porsches after a few decades. Is this the case here?
.....still happy. |
The bottom looks pretty good for a 51 year old car.
Yes, those bushings probably need replacement. Since you're familiar with Porsche's, most of the same stuff applies on VW's.
It looks like someone forgot to install the under cylinder/above the push rod tubes on that engine (at least the 3-4 side). Don't know about the other (1-2) side.
As far as what size engine it is, there's no way of knowing without pulling a cylinder head.
The "Cookie cutter" rims do look good on a type 3, and others have used them before. You'll have to get the drums and hubs re-drilled for the Porsche pattern, and either drill the fronts or buy new rotors to use them. Pay attention to the offsets IF you decide to lower the car!!
As for that muffler nut, you'll want to replace the copper gasket inside, and then use a thin 46mm wrench to tighten it (preferably on the engine for alignment).
| Tram wrote: |
| Tram wrote: |
Posted: Mon Aug 06, 2018 3:27 pm Post subject: Re: My 67 Squareback |
| Bobnotch wrote: |
Sorry, what did they forget to install? |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36455 Location: Conejo Valley, CA
Posted: Mon Aug 06, 2018 3:40 pm Post subject: Re: My 67 Squareback |
The little air deflectors that fit the underside of each cylinder pair. Really bad for engine cooling to not have them! You have to loosen the heads and remove pushrods/tubes in order to install them (bummer).
https://www.thesamba.com/vw/forum/viewtopic.php?t=687067
Either these (like on the bug or early cars):
...or better yet, these (aka, "cool tins"):
Posted: Mon Aug 06, 2018 4:28 pm Post subject: Re: My 67 Squareback |
| KTPhil wrote: |
These things?
Am I missing anything else?
I found these three pieces of metal. I think the two on the right are for near the rear wheel but I don't know what the one on the left is for.
KTPhil  Samba Member
Posted: Mon Aug 06, 2018 5:21 pm Post subject: Re: My 67 Squareback |
https://www.vwispwest.com/pg90
You are looking for items 25 (preferred over 7 on a Type 3), and also check for others like 3, 4, 11, 12, 22, 23 which may also be missing. All are vital to cooling!
I don't think any of those 3 pieces in your last photo belong. The leftmost is a pulley tin for a Type 1 or 2. I don't recognize the right two; part of broken mudflap, maybe? |
Posted: Mon Aug 06, 2018 5:38 pm Post subject: Re: My 67 Squareback |
| old_man wrote: |
| BSQUARE wrote: |
Hard to tell from the photo angles - but, it looks like the front holes don't line up with the door gap. There's a roof support piece (above the headliner) that's centered with the door gap which should take the weight of the rack and cargo, instead of the sheet metal roof; while the hatch hinge support takes the weight of the rear. If the front mount holes aren't in line with the door gap, I'd patch them up; otherwise you'd be risking denting the roof if you carry any cargo on the rack. _________________ 1968 Regatta Blue Squareback
Posted: Mon Aug 06, 2018 6:39 pm Post subject: Re: My 67 Squareback |
| KTPhil wrote: |
I definitely do not have 22 or 23, those are called the lower or sled cooling tin correct? I will look at 3, 4, 11, and 12, tomorrow.
I also started researching the whole thermostat thing. Best I can tell is I have the linkage and flaps, you can even see the rod dangling down in one of the photos, but I do no have the actual thermostat or what it sits in. It's a novel thing to me as my aircooled 911 doesn't anything like that. It doesn't have any lower tins either.
Thanks again for the help. |
Posted: Mon Aug 06, 2018 6:41 pm Post subject: Re: My 67 Squareback |
[quote="BSQUARE"]
| old_man wrote: |
Hard to tell from the photo angles - but, it looks like the front holes don't line up with the door gap. There's a roof support piece (above the headliner) that's centered with the door gap which should take the weight of the rack and cargo, instead of the sheet metal roof; while the hatch hinge support takes the weight of the rear. If the front mount holes aren't in line with the door gap, I'd patch them up; otherwise you'd be risking denting the roof if you carry any cargo on the rack. |
I'll take a look tomorrow. I have the headliner completely out so it should be easy to see where the holes go. It could have also been installed incorrectly. |
