mike brind Samba Member
Posted: Wed Aug 15, 2018 11:44 am Post subject: cargo floor corrugation dimension |
| Hi , does anybody know the correct depth of the corrugations on the cargo floor panels , ive purchased a repair section and it appears to be too shallow ,and as I'm only patching it doesnt match up with the existing profile depth, thanks . |
easy e Samba Member
Joined: May 28, 2008 Posts: 3942 Location: 1 hr north of Santa Barbara
Posted: Wed Aug 15, 2018 1:58 pm Post subject: Re: cargo floor corrugation dimension |
| mike brind wrote: |
| ...it doesnt match up with the existing profile depth. |
Just so we get it straight... Are you saying you have an example portion of existing original cargo floor and you are unable to measure it? _________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
Posted: Wed Aug 15, 2018 3:14 pm Post subject: Re: cargo floor corrugation dimension |
| no ive bought a repair section that is newly manafactured claiming to be of the correct profile but it doesnt match the existing floor that im trying to patch repair ,im wondering what the correct dimensions are just to clarify that my splitty cargo floor is of original spec so i can sort out the issue with supplier, the replacement section seems to be too shallow by at least 1.5mm. the orig seem to me around 7.5mm from top of corrugation to the underside of the next if i measure end on |
hitest Samba Member
Joined: September 30, 2008 Posts: 10332 Location: Prime Meridian, ID
Posted: Wed Aug 15, 2018 4:17 pm Post subject: Re: cargo floor corrugation dimension |
You need someone with a cut out OG section then if you are measuring that way. I can measure the depth of the corrugates but only from one side- they're part of their host buses. _________________
| EverettB wrote: |
FU#5 |
easy e Samba Member
Posted: Wed Aug 15, 2018 5:45 pm Post subject: Re: cargo floor corrugation dimension |
I understand you have some new floor you aren’t sure about.
But unless your rusty old floor has previously been repaired ... then rusted out again (seems unlikely)... I don’t understand why you can’t rely on the validity of the “floor to be patched” dimensions. Maybe you want to verify your existing old ass floor is original. Seems like you could determine that though.
| mike brind wrote: |
| it doesnt match the existing floor that im trying to patch |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1380 Location: Yulee FL
Posted: Wed Aug 15, 2018 6:14 pm Post subject: Re: cargo floor corrugation dimension |
you may have received bay window floor sections, the profile and spacing is off on that floor when compared to a split
I'm looking for someone willing to sell me some scraps of split window floor to patch m my single cab but having no luck |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53265 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Aug 15, 2018 6:36 pm Post subject: Re: cargo floor corrugation dimension |
| ryans65 wrote: |
Huh?, bay floors have the same profile in the corrugated part, I often rob sections to repair splits.
I wonder where the OP bought these repair sections?, some sellers are quick to say "correct profile" or some similar statement when in fact they are nothing near. got a camera Mike? : https://www.thesamba.com/vw/forum/viewtopic.php?t=6 The sections you bought aren't reddish brown or black are they? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5660 Location: 1st Coast
Posted: Thu Aug 16, 2018 3:56 am Post subject: Re: cargo floor corrugation dimension |
| i just need the correct dimension of the original floor is all, just to verify what it should be , the replacement panel i have seem to be around 5.5mm in depth and when i measure my floor it varies a little as I'm taking measurement off pieces ive removed and the remaining original but appears to be around 7mm in depth. |
Posted: Thu Aug 16, 2018 4:11 am Post subject: Re: cargo floor corrugation dimension |
I'm lost on what floor repair sections I have then lol
The profile is *almost* right but the spacing is slightly wider and I blindly assumed it was bay window metal... maybe its vanagon stuff? I dunno.
LAGRunther-
Thanks for the ads, I'll message them!
| busdaddy wrote: |
| ryans65 wrote: |
I wonder where the OP bought these repair sections?, some sellers are quick to say "correct profile" or some similar statement when in fact they are nothing near. got a camera Mike? : https://www.thesamba.com/vw/forum/viewtopic.php?t=6 The sections you bought aren't reddish brown or black are they? |
Posted: Thu Aug 16, 2018 5:15 am Post subject: Re: cargo floor corrugation dimension |
ryan65 mines a 64 splitty from oz , just out of interest do u think you could take a measurment from yours from the top of one corrugation to the bottom of the next , thanx , original floor on left which comes in at 7mm replacement is around 5.5mm
the original floor is on the left on the first pic , u can see its quite a bit deeper
Posted: Thu Aug 16, 2018 5:17 am Post subject: Re: cargo floor corrugation dimension |
Yes, I will try and get out there tonight.
| mike brind wrote: |
the original floor is on the left , u can see it quite a bit deeper |
Posted: Thu Aug 16, 2018 5:27 am Post subject: Re: cargo floor corrugation dimension |
| to be fair ive rang the guy and he said if i send him a piece of floor that theyll make me a section , and claims he took the measurements from a 61 SC but the bit he sent is so far off i think it may be a dud, and i dont really want to cut out a decent section of floor , |
Posted: Thu Aug 16, 2018 3:18 pm Post subject: Re: cargo floor corrugation dimension |
| hitest wrote: |
| You need someone with a cut out OG section then if you are measuring that way. I can measure the depth of the corrugates but only from one side- they're part of their host buses. |
i just would like to find out what other og floors are coming out at, mine seems to be around 7mm in total depth |
Posted: Mon Aug 20, 2018 9:52 am Post subject: Re: cargo floor corrugation dimension |
| bump |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2613 Location: UK (South)
Posted: Mon Aug 20, 2018 10:45 am Post subject: Re: cargo floor corrugation dimension |
I've just measured an off-cut of original floor that I bought to make a repair patch from.
Each of the ridges is 7.4mm +/- 0.05mm
Are you the guy who asked the same question on the SSVC forum, or is that just a coincidence? If not, I'll remember to post this there too. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Mon Aug 20, 2018 12:18 pm Post subject: Re: cargo floor corrugation dimension |
| ye thats me , thanks fro reply , i bought the too shallow panel as it was advertised as the correct profile ,annoying to say the least its barely 6mm which the guy claims is what it should be and got quite shirty and ive ended up with money back , |
Posted: Mon Aug 20, 2018 1:13 pm Post subject: Re: cargo floor corrugation dimension |
Nah, that's too shallow.
I was surprised when I measured and it was only 7.4mm though. Looks deeper when it's in place. _________________ Andy
Posted: Tue Aug 21, 2018 9:19 am Post subject: Re: cargo floor corrugation dimension |
| your measurement seem to be pretty much the same as my orig floor , can i ask others to measure theres to get a definite average thanks people. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72036 Location: Phoenix 602
