Trans-Awn 2000 - Case sags into door when open?
yew
yew is offline
PostPosted: Tue Sep 11, 2018 7:47 pm    Post subject: Trans-Awn 2000 - Case sags into door when open? Reply with quote
When the awning is open, the bottom half of the metal container the awning stores in rubs the top of the sliding door. Is this a normal issue? I'm wondering if the gutter brackets holding it on have bent over time.
Full disclosure, I'm asking primarily because I'd like to sell it and don't want to represent it inaccurately if the bracket or the awning is bent.
"Panda": '85 Adventurewagen - 2.1L WBX
metropoj
metropoj is offline
PostPosted: Wed Sep 12, 2018 6:09 am    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Hmmm, I still use my Transawn2000 and although it gets close to the door ( evenly across the whole length ) it never sags or touches.
If you can post up a pic or 2 that would be helpful to see whats up.
When you close up the owning to secure it shut, does it give you a hard time closing up evenly ? Maybe the outer case that hangs down is bent or something ...
Does your transawn have the mounts to attach the poles to the van itself ? Those I have been looking for, for a while. Most people don't use them I gather but I'd like to have them attached to my van.
John.
86 TiiCo powered Westy.
kamzcab86
kamzcab86 is offline
PostPosted: Wed Sep 12, 2018 9:20 am    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Normal if the awning was mounted using Dometic's 45° brackets, or different brand brackets. My solution, posted in the master TA2000 topic: https://www.thesamba.com/vw/forum/viewtopic.php?p=7315930#7315930 .
2016 Golf GTI S
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Sep 12, 2018 1:32 pm    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
If you have the OEM TransAwn mounts, a couple of washers between the faces in the front raises the gutter quite a bit.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
dhaavers
dhaavers is offline
PostPosted: Wed Sep 12, 2018 5:18 pm    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
...and d@mn, where were you when I was shopping for an awning last spring...???
Rolling Eyes Wink Laughing
- Dave
"The WonderVan"
rmcd
rmcd is offline
PostPosted: Wed Sep 12, 2018 5:51 pm    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Mine does the same.
I’m not getting this. I’m a boneheaded. Where? Picture please?
VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight=
CanStan
CanStan is offline
PostPosted: Wed Sep 12, 2018 8:14 pm    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
I had the same issue. The case just barely rubbed on the top of the sliding door. I had a couple of short cam lock tie down straps that I used as extra insurance to keep the case from popping open on the highway. 1 near the front and 1 near the back. I didn't trust those stock closure clamps to stay shut.
I wish I had a picture, but when I deployed the awning, I would put the straps back on, and tighten them just enough to pull the case up slightly towards the closed position. This kept it from touching the door. I guess I probably could have solved the issue by adding washers to the mounting brackets as mentioned previously, but since I had the straps there anyway, and it took 10 seconds to do, it never bothered me.
kamzcab86
PostPosted: Wed Sep 12, 2018 11:18 pm    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Mine, at the aforementioned link:
Replaced with:
But I also still use the cam straps, like you, for double-security duty for the case when the awning is not deployed.
2016 Golf GTI S
Jake de Villiers
PostPosted: Thu Sep 13, 2018 7:23 am    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Mine does the same.
I put a biggish washer in between the two pieces of the gutter clamp as shown in your photo - right in front of where the bolt head and washer is.
I'll get you a photo when I can.
www.thebassspa.com
yew
yew is offline
PostPosted: Thu Sep 13, 2018 8:26 pm    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Thanks! Yeah, I think those are my brackets. This thread is super helpful.
dobryan Premium Member
dobryan is offline
PostPosted: Thu Sep 13, 2018 9:19 pm    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Wish you were
on the east coast. I’d buy it.
Dave O
The Western Syncro build
metropoj
metropoj is offline
PostPosted: Fri Sep 14, 2018 6:56 am    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
Replaced with:
Were there supposed to be straps on these units form the factory like you show ? Good Lord, I don't have naything like that, I've just been opening the shell and using it as is with the awning tension pulling on it.
John.
kamzcab86
PostPosted: Fri Sep 14, 2018 9:49 am    Post subject: Re: Trans-Awn 2000 - Case sags into door when open? Reply with quote
metropoj wrote:
Were there supposed to be straps on these units form the factory like you show?
No.
The second owners used their own method, drilling small holes at each end of the tray and running small ropes from the tray to the plastic tabs at each end of the case. The ropes dry-rotted and at the same time, I had a clip pop loose while driving (turned out it was bent out of shape & since repaired), so I killed two birds by using the cam straps. After a few years, the straps became too worn to hold the tray, so I made chains. Next iteration will be a semi-permanent chain inside the case at each end... or perhaps swap the whole thing out for an ARB.😂 (Update 2019: Next iteration was installing Fiamma awning mounting brackets from RMW: https://www.thesamba.com/vw/forum/viewtopic.php?p=9150588#9150588 Very Happy )
The straps/chains are utilised simply because the tray rubs when open. If your tray doesn't rub on the sliding door when you deploy the awning, you're all set.
2016 Golf GTI S
