2 gallon fuel tank (...a get outta jail card)
Butcher
Butcher is offline
PostPosted: Sun Sep 16, 2018 10:34 am    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
I know I certainly would not maintain the tank and if/when I ran out of gas, I would just be putting varnish in the tank. I have only ran out of gas once, 35 year ago. Not bad considering I drive a VW 20-30k a year with a broken gas gauge.
It's a great idea, but not for me.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Sun Sep 16, 2018 1:39 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Love your tank, Sodo!!
I've run out in my 2wd, got my GF to bring gas, she's such a sweetie Smile I'd agree running a tank dry was baaaaad, even 5 gal added took 15 minutes of swearing and images of silt having plugged up my intake or filter.. Blah!!! Finally sputtered to a start, took another 4 or 5 minutes of sputtering til I could power up onto the highway confidently. Last weekend, another super close call, had come out of the underground car park at her place in Minneapolis, it sputtered as I crested the ramp top. Made it 4 blocks to a gas station I'd never wanted to use before. Just scary. Sometimes running out of gas in a city is way worse than out on a trail.
Leaves me thinking again about our ridiculous gas tanks, and no warning lights. I'd seen it touch orange inbound to the city, but the 5 car crashes in 12 blocks of city traffic ( usual freeway exit was closed ) in unfamiliar area of city had completely wiped my thought of needing gas!
Sodo
Sodo is offline
PostPosted: Sun Sep 16, 2018 1:54 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Gruppe B wrote:
DanHoug wrote:
here's a question.... is 2 gallons enough fuel to have the pump re-prime when the tank is run dry? with the fuel pickup in the dead center, the van would have to be perfectly level.
No problem at all, I've been given a 5lt tank of fuel once when I ran out and it started right up
BobbyBlack, Gruppe B, was it level? It seems like for 2WD, if you're running out of gas, .....you should try to roll someplace level to make startup easier.
If you're still driving your van by the time the gas turns to varnish, isn't that a wonderful thing in it's own right?
....KTMs, GasGas, SPOT mtb
Gruppe B
Gruppe B is offline
PostPosted: Sun Sep 16, 2018 4:20 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
It was level, we were in Kansas Very Happy
Abscate Premium Member
Abscate is offline
PostPosted: Sun Sep 16, 2018 5:00 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Just a side bar. 12 psi doesn't sound high, but it is. At roughly 14.7 psi, that means the gas is boiling (loosely put)
If it is reaching 130 under the car (?) and the tank is vented, it is going to be emptying itself pretty quickly.
You guys in the desert might want this for range protection, back East where gas is everywhere, probably not.
The implementation and workmanship on the pictures is very good, top shelf.
Abscate is offline
PostPosted: Sun Sep 16, 2018 5:03 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
NOW, I have proof that she does this on purpose AND this technique must be in the secret β€œfemale instruction manual” that no male ever sees.
Ive got a copy but page two has an arrow and BEER! By the time I come back its gone.....
Gruppe B
Gruppe B is offline
PostPosted: Sun Sep 16, 2018 5:56 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Gruppe B wrote:
http://www.thesamba.com/vw/forum/viewtopic.php?t=580489&highlight=germany
Similar idea from another thread
Abscate is offline
PostPosted: Sun Sep 16, 2018 6:28 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Yikes.
No.
Sodo
Sodo is offline
PostPosted: Sun Sep 16, 2018 7:22 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
That's Diesel enroute to Ushuaia.
A completely different subject than "2 gallon fuel tank (...a get outta jail card)"
B.O.B.Wanders
B.O.B.Wanders is offline
PostPosted: Sun Sep 16, 2018 7:54 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
I am very jealous of your fabrication skills, Sodo. That looks like a very practical solution. I like it.
I went a simpler, more traditional route. Initially I tossed in a 2.5 gallon plastic gas can under the back seat for camping trips, but did NOT like the idea of gasoline inside the vehicle from a safety perspective - I think it's against DOT regs or something as well - and didn't like the idea of a plastic can in the hot sun if stored on top. The only time I've ever used it was to give some gas to a fuel-challenged traveler in a rest stop.
I found some 10L (2.64 Gal) NATO spec GELG Jerry cans online: https://www.ebay.com/itm/New-NATO-Jerry-Can-10-Liters-2-64-Gallons/221712223762. Note: these are sold as "not for fuel use" and marked as such. From the ad: "Due to US regulations these are sold for storing non-potable water and other non-fuel liquids. Not for fuel use. But outside of the US these cans would be perfectly acceptable for fuel storage.". Wavian sells one that is short and squatty, but these GELG brand cans are dimensionally just like the 20L/5Gal NATO cans but smaller all around.
Hypothetically, if one were to put someting other than non-fuel in them anyway, two cans (~5 Gal) will fit nicely in the luggage rack with a couple of folding camp chairs and a come-along (in an old heavy duty chair/tent bag). I like the low side-profile. They are only a half-inch or so taller than the depth of the luggage rack and can (hypothetically) be seen from the ground by tallish folks, but not obvious. Add a cable and lock to prevent any casual snatch & grabbery. I can (hypothetically) take one for shorter local trip where services are likely within 30 miles from anywhere, or both cans if we are heading out west (Next Services 4,234,000 Miles). Another benefit of the smaller can is that, even full, it is only around 10 lbs. and not too difficult to lift up to - or down from - the roof. I would (hypothetically) use a combination of nylon straps and bungees to keep them secure. Your mileage may (hypothetically) vary.
Rick
83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown
Sodo
Sodo is offline
PostPosted: Tue Jun 04, 2019 10:48 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
I've finally mounted the 2-gallon tank.
Tank is not bolted to the mounts. It just 'slips in' and nests tightly. And lifts out, no tools. I'll probably add more security when I think of a good way.
Here's the mounts. 1 x 1/8" angle steel with adhesive EPDM rubber pads.
I used rivnuts, wetted first with Permatex Ultra-gray
Here's the forward mount.
Now all that's left to do is run outta gas....
SyncroButter
SyncroButter is offline
PostPosted: Wed Jun 05, 2019 1:03 am    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Sodo, your fabrication skills are truly impressive! Nice solution!
Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle
tjet
tjet is offline
PostPosted: Wed Jun 05, 2019 10:11 am    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
I like it. Want.
I did the noganav idea (link below). I bought a Mercedes gas can from uk ebay
https://www.thesamba.com/vw/forum/viewtopic.php?t=651253&highlight=
Here's mine installed. I also adapted a spare tire lock to secure it.
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1902644
BTW, if you're going to keep fuel in it, see if you can get some avgas at your local small airport. It has much longer shelf life then automotive gas (years vs months)
E1
E1 is offline
PostPosted: Wed Jun 05, 2019 11:19 am    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Great job! 👍🏼👍🏼👍🏼
Has "new product" written all over it. If "tooled," Ahem, as a tool carrier, I'd be all over it as first-priority in the Now.
Yeah, the plastic jugs on the roof spook me. A gas shower in a rollover would be really bad -- not that anyone rolls over and stuff. Wink
Goodonya!
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
β€” Colin Chapman
Sodo
Sodo is offline
PostPosted: Wed Jun 05, 2019 12:08 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Heres a pic I found somewhere of the classic 'red cans ontop'. Westy VW buses often had the red-can.
My 2-gallon aluminum tank hides better in the westy cargo rack.
My snowmobiles always start "the next year" and it's usually been 9 months. I've been using/over-summer-storing "Safeway gas" for 10 years now, and it's been reliable. I thought Safeway might be the "no-name" gas and worried a bit, then I had BIG trouble with an actual "no-name gas". The station with the hand-lettered "non-ethanol" signs and the 'merkin flags etc. Which I'd normally be more inclined to support than the "corporate". But I ain't buyin' there anymore and am leery of "non-ethanol" stations. Just where can they get the stuff (in this corporate world?)? Engines seem to run a little "crisper" with the non-ethanol but I'll drain any carburetors that have no-name gas - ain't storing it with 'non-ethanol' anymore.
After all that trouble (green corrosion and stuff in a generators, chainsaws, dirtikes)..... I went back to Safeway (E10) and it's been 4 years of no problems..
Agreed it's proper to dump it in the van and burn it every few months.
dobryan
dobryan is offline
PostPosted: Wed Jun 05, 2019 12:11 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
10% ethanol gas stays in my home generator for many months, sometimes a year or more. I add Stabil to every fill and have never had an issue... knocks on wood.
Dave O
The Western Syncro build
Sodo
Sodo is offline
PostPosted: Tue Jul 23, 2019 9:30 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
Something to be said for allowing them to fling off.
Well I got 4 tanks done.
Here's what they look like inside.
They are extruded aluminum tubing.
Testing them for leaks, I could never get them to weld tight, there was always a pinhole.
So I sealed them with "fuel tank sealer".
Then looking at the pic sitting in the cargo area I had a thought.
These things are effin' strong.
If I made them like wedges they could be my leveling ramps, with adhesive "sanded" grip tape on them.
Actually I can use the one as a 3" leveling block.
michaelbteam Premium Member
michaelbteam is offline
PostPosted: Tue Jul 23, 2019 11:10 pm    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
I found out the hard way that when the gas gauge on my Syncro finally hit the bottom of empty, it was accurate and the van died. Incidentally, and luckily, my tank must have been pretty clean, since the van started right up with a gas transfusion.
I carry a two gallon Rotopax, wrapped heavily in reflective foil bubblewrap, bungeed in my luggage rack. I use it up every six months.
I understand this is questionable, but the Rotopax has been solid and leakproof so far. Thoughts or opinions, anyone?
Abscate is offline
PostPosted: Wed Jul 24, 2019 2:02 am    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
They also could be steps into the van at the slider door
Two blocks of C4 on the side would make a nice slider door step
The same two blocks of C4 on end , and the tank across them, would make a nice two person seat at the campfire. Very cozy
dobryan
dobryan is offline
PostPosted: Wed Jul 24, 2019 4:53 am    Post subject: Re: 2 gallon fuel tank (...a get outta jail card) Reply with quote
The C4 and tank could also be used in camp as a base for wood chopping to feed the fire pit.
(Awesome tank design btw.)
Dave O
Page 2 of 5
