IDK-1980 Samba Member
Posted: Sat Oct 06, 2018 6:31 pm Post subject: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
I've scourred the internet and scanned through my Chilton's manual, but have been unable to find an answer as to what the function or name of this mystery hole in the back-right of my engine bay is (this is on a 1973 bay window, which is totally new to me). Questions:
1) What is it?
2) Should there be something connected to or covering it?
3) (Most importantly) should there definitely not be a plastic bag shoved in it?
Thank you.
_________________ 1972 Super Beetle w/ Sunroof, Saturn Yellow
1973 Bay Window Bus, Wild Westerner 2-Tone Green
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10800 Location: the past
Posted: Sat Oct 06, 2018 7:19 pm Post subject: Re: Type 4 Engine mystery hole |
Original preheat tin for stock dual carbs.
If the other ducting is still in place (even if it isn't), and since you're running aftermarket dual carbs, you'll want to have it plugged. Otherwise you'll be pumping hot air into the engine compartment.
Posted: Sat Oct 06, 2018 8:42 pm Post subject: Re: Type 4 Engine mystery hole |
Air preheat stove, helpful if you want your engine to run its best in cold weather and if you want the best gas mileage possible. Easy to hook up if you have stock carbs and a stock aircleaner, but an awful lot of work to hook up if you are running non stock dual carbs. |
Posted: Sat Oct 06, 2018 11:41 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Thanks, much appreciated! I'm sure I'll have more questions in the future.
So the plastic bag was serving a purpose...  _________________ 1972 Super Beetle w/ Sunroof, Saturn Yellow
1973 Bay Window Bus, Wild Westerner 2-Tone Green |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5173 Location: California's Hot and Smoggy Central Valley
Posted: Sun Oct 07, 2018 9:17 am Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
I use it to pre-heat my Weber carburetor:
Posted: Sun Oct 07, 2018 9:31 am Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
IDK-1980 wrote: |
So the plastic bag was serving a purpose...  |
By wary of using a plastic bag or any large sheet of plastic or paper for anything in the engine compartment. Were it to move around and block the fan off overheating would happen almost instantly and you might not notice anything amiss until the engine locked up.
The piece in question is lovingly referred to as a commode, just like the ones that get hugged on Saturday morning in frat houses all around the country. The commode itself is easy to remove and can be replaced with a piece of sheet metal cut from the lid of a large tin can or a piece of plastic cut from an oil jug. Since some oil comes in a black gallon jug if you use thus for you next oil change you will have a matching patch to go over the opening. |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1809 Location: Cape Cod & District of Columbia
Posted: Sun Oct 07, 2018 5:13 pm Post subject: Re: Type 4 Engine mystery hole |
hazetguy wrote: |
Isn't the "technical term" of this referred to as the "toilet bowl" pre-heat tin?? _________________ 77 Westy - Cape Cod Sage
70 Beetle
71 Super Beetle
RIP TheWalrus (Big Jack) 1988-2024 |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3804 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sun Oct 07, 2018 7:52 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Wasted youth wrote: |
And how about a T-stat on the pre-heat when it's not needed any longer? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Sun Oct 07, 2018 9:08 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
udidwht wrote: |
And how about a T-stat on the pre-heat when it's not needed any longer? |
Without manifold heat I doubt that is ever a problem. |
Posted: Sun Oct 07, 2018 9:09 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Wildthings wrote: |
udidwht wrote: |
Unless it's 200F outside....LOL! _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Sun Oct 07, 2018 9:19 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
udidwht wrote: |
Wildthings wrote: |
udidwht wrote: |
Unless it's 200F outside....LOL! |
Give us a few more years we are getting there.  |
Posted: Sun Oct 07, 2018 9:42 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Wildthings wrote: |
udidwht wrote: |
Wildthings wrote: |
udidwht wrote: |
We go into one and come out of one. Science barelys understands how the planet fully works at this point. Barely. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
P24p1 Samba Member
Joined: August 20, 2020 Posts: 365 Location: Canada, Quebec
Posted: Wed Nov 11, 2020 7:43 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
I'm thinking of doing something like that. Do you have any more pictures? Also, what kind of gas mileage do you get with that setup? |
Posted: Wed Nov 11, 2020 7:59 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
P24p1 wrote: |
Read up on the cookie tin setup. You can also peruse the earlier pictures in my gallery to see my setup, it uses a Datsun air cleaner housing with a thermostatic valve for the preheat. I also run a heated manifold. Back in the good old days before ethanol ended up in out fuel I used to get 24-26 mpg, but with ethanol I get about average gas mileage anymore. |
Whaanga Samba Member
Joined: May 07, 2016 Posts: 642 Location: Rochester, NY
Posted: Wed Nov 11, 2020 9:00 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Does anyone know where one can source the rubber gasket that goes on the pre-heat duct? _________________ Late 1973 Bay w/a transplanted 914 Engine |
P24p1 Samba Member
Posted: Wed Nov 11, 2020 9:50 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Wildthings wrote: |
I also run a heated manifold. |
How did you set that up? On your pictures it looks like a type 1 manifold to type 4 heads, how did you do that? And then you have two of those heater things they sell for type 1 engines? |
Posted: Wed Nov 11, 2020 11:03 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
The "dual port" ends are just reworked fuel injection manifolds. Just a bit of cutting, twisting, and welding. They actually come out looking very close to what VW used on their T-127 industrial engines.
Yes I kind of have a two level system for the manifold heat. The one pipe heats the bottom of the center section of the manifold and the upper one supplies heat to near the base of the carb so is very good at preventing icing, the manifold is double walled at that point so intake air goes down through a center pipe and the exhaust gases flow through a chamber built around the center pipe. |
P24p1 Samba Member
Posted: Thu Nov 12, 2020 8:24 am Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Wildthings wrote: |
What kind of MPG do you get with your system? |
Posted: Fri Nov 13, 2020 5:06 am Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
P24p1 wrote: |
Wildthings wrote: |
I presently get the pretty standard 17-19 MPG but am considering going back and tuning the carb to run on ethanol free gas and see if I can get the gas mileage back up into the mid 20's where it used to run before ethanol lace fuel entered the scene. |
Posted: Fri Nov 13, 2020 6:13 pm Post subject: Re: Type 4 Engine mystery hole (SOLVED: It's the preheat duct) |
Thanks for the info on this thread. And thanks Wasted Youth for the method of heating your single carb. I hope you don’t mind but I borrowed your idea.
Am anxious to go for a drive tomorrow in the cool Western New York temps and hope to see improved conditions at stop lights.
