raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23155 Location: Oklahoma City
Posted: Sat Jan 20, 2018 6:25 pm Post subject: Re: 1976 914 2.0- |
Very nice!
Ray |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2282 Location: No. Idaho
Posted: Sat Jan 20, 2018 9:32 pm Post subject: Re: 1976 914 2.0- |
Thanks, Ray. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Thu Feb 15, 2018 7:31 pm Post subject: Re: 1976 914 2.0- |
Next step on motor.
44/38 heads ordered with a web 163/86b
Heads will have 60cc chamber volume with plans of hitting 9.4-5
Will come with AA’s Stage 1 porting. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Tue Mar 20, 2018 5:25 pm Post subject: Re: 1976 914 2.0- |
Heads arrived, Yee haw. It’s about to get real.
Though am having sec d thoughts about uso g the 163/86b with the 44/38 heads. Wondering if the SLR XR 284 would be better. Save the webcam to use with the 42/36 heads.
78 x 96
44hpmx.
Thoughts?
Thanks in advance. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Tue Oct 02, 2018 6:13 pm Post subject: Re: 1976 914 2.0- |
It’s starting to come together.
Little por-15 in, around, under the hell hole. And in the engine hanger.
Motor done assembled by strictly foreign in Murphy, Or. 2260 did go with the SLR and 44/38 heads.
Rebuilt transmission
Redoing shift rod bushes
New braided brake hoses
little more prep. Darned little more prep and she rolling under own power
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Wed Oct 03, 2018 5:53 pm Post subject: Re: 1976 914 2.0- |
We’ve got the firewall insulation set up there.
What’s your preferred method for attaching it so it doesn’t co e loose and fall into the fan?
Also not the new RIX shift bushing. Slick thing.
Thanks in advance
Mike. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Sun Oct 28, 2018 5:05 pm Post subject: Re: 1976 914 2.0- |
Motor is in
76 914 with 2260
79 VW Iltis
69 Bwajaja
Joined: December 28, 2016 Posts: 310 Location: atlanta ga
Posted: Mon Oct 29, 2018 10:37 am Post subject: Re: 1976 914 2.0- |
3m weatherstrip adhesive and the factory push in plastic clips
Mikedrevguy wrote: |
Thanks in advance
Mike. |
Posted: Mon Oct 29, 2018 10:38 am Post subject: Re: 1976 914 2.0- |
I am sure that you will make sure that the transmission ground strap is cleanly and firmly connected. I made the mistake of forgetting it one time and the engine used the accelerator cable as the ground and melted it in the tube
Motor is in
Posted: Mon Oct 29, 2018 7:49 pm Post subject: Re: 1976 914 2.0- |
Haha. I was hooking the electrical up this evening and this came to my attentions. Thanks for reinforcing. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Sat Jan 05, 2019 10:14 pm Post subject: Re: 1976 914 2.0- |
Motor is in, and fired this evening. Smiles . . . Everyone smiles.
#LacyRacy
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Tue Jan 08, 2019 7:27 pm Post subject: Re: 1976 914 2.0- |
Then this?. . . . . .
Things considered.
Timing
Hardstart relay
New starter
Ground issues
High torque starter.
Retarded timing a bunch. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
upon3pr Samba Member
Posted: Thu Apr 04, 2019 5:01 pm Post subject: |
Ray,
you mention the CHT plugs in near the #3 intake - - could you be a bit more specific in location? does it connect under the tin? or beside the intake port?
I've got a wire plugged into the harness that routes under the intake and beneath the engine tin. is that the wire for the CHT? (connects into harness beneath the MPS)
is it possible to get at the CHT without dropping the motor?
wondering before I go all crazy on it.
Rev. |
I’m working on a ‘74 2.0 and it won’t stay running after a warm up. I see the the wire next to cylinder #3 is disconnected. Where should it be connected to?
Posted: Fri Apr 05, 2019 8:56 am Post subject: |
It sure will not with that disconnected! That is the cylinder head temp sensor wire which goes through a hole in the sheetmetal right in front of the right rear pass spark plug hole and connects to the control unit harness
upon3pr wrote: |
Ray,
Rev. |
Posted: Fri Apr 05, 2019 8:57 am Post subject: |
looks like I can see it in the picture, but the broken end you are showing is where it attaches to the control unit harness, look at the harness you should find the other side of the broken wire
[email protected] wrote: |
upon3pr wrote: |
Ray,
Rev. |
Posted: Fri Apr 05, 2019 9:05 am Post subject: Re: 1976 914 2.0- |
Aha! Ok thanks. I’ll check it out. It fired up quickly yesterday and started to idle, then shut itself down after a minute or so. |
Posted: Sat Apr 06, 2019 8:38 am Post subject: Re: 1976 914 2.0- |
****UPDATE****
Found the cut wire from the harness peeking out of the sheath!!
Reconnected and fired right up. Still a rough idle and need to dial it in. Bigger problem now is that gas/oil dripping on to headers around #3 or #4 cylinders. I’ll have to jack back up to get a better look tomorrow. Gotta let the heavy smoke clear for now!! Progress I suppose  |
Posted: Tue May 07, 2019 7:38 pm Post subject: Re: 1976 914 2.0- |
fantastic. glad to hear you got it running. the rest will come. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Tue May 07, 2019 7:43 pm Post subject: Re: 1976 914 2.0- |
in other news -
2260 is all she ever thought it'd be and more.
been to Seattle. been down to the The Bay.
still having issues with blowing oil by the rings. , though it's gotten better.
had I to do over, I'd not have used the Keith Black rings, but would have substituted. some say they will eventually break in - - we'll see. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2180 Location: Gardnerville, NV
Posted: Wed May 22, 2019 11:41 am Post subject: Re: 1976 914 2.0- |
in other news -
had I to do over, I'd not have used the Keith Black rings, but would have substituted. some say they will eventually break in - - we'll see. |
Those rings are Hastings rings, couple of questions , what oil did you use for break in , what are your ring gaps , what method did you use for break in, did the second compression ring have a chamfer on the inside and how did you place them as well as your top ring. Personally I see a lot of engines build by folks for daily driving that never get driven hard enough to seat the rings. just curious. _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
