sonoma_vw Samba Member
Joined: May 19, 2013 Posts: 475 Location: Sonoma County
Posted: Sat Dec 22, 2018 11:43 am Post subject: How to connect Vintage Speed muffler if no heater risers? |
Have dual carb setup now. (The grey horizontal running pre-heat tube is removed.) Where does the new muffler connect to with this configuration?
Any photos of a dual carb setup with this type of muffler showing how its mounted? Thanks.
I guess I might as well ask, how to identify what type of rear tin I need to get? (its a 1600 squished into a 1960 engine bay) Mine was butchered apparently to go around the heater riser mounting points. (see pics). How to folks get a better fit tin? Trial an error with the tin snips?
Thanks #2.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79670 Location: Sneaking up behind you
Posted: Sat Dec 22, 2018 12:14 pm Post subject: Re: How to connect Vintage Speed muffler if no heater risers? |
Since you now have dual carbs get the muffler that doesn't have heat riser bungs.
That way there's nothing to block off. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Sat Dec 22, 2018 6:35 pm Post subject: Re: How to connect Vintage Speed muffler if no heater risers? |
The Vintage Speed muffler in your picture doesn't have heat risers, so there's nothing to block off. And just by a new tin without holes for heat risers or heater hoses and you`ll be fine. _________________ If you`re going to do something, do it right. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33153 Location: Hot Arizona
Posted: Sun Dec 23, 2018 8:33 am Post subject: Re: How to connect Vintage Speed muffler if no heater risers? |
Back in 1976, when my intake manifold for my Weber 40DCNF had no heat risers, I made such block-off plates in the shop at work at lunchtime. I couldn't find these commercially made back then; and I still use them. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
