bwaz Samba Member
Posted: Wed Nov 21, 2018 11:56 am Post subject: Does anyone here own the last oval beetle? |
According to the tech section.... serial number 1600846 with 36hp motor 1937052? Anyone own it or have a close match to the end of the ovals? |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1333 Location: Norway
Posted: Sat Nov 24, 2018 3:06 pm Post subject: Re: does anyone here own the last oval beetle? |
I am quite sure that engine # 1934052 was not put into chassi# 160086, as the engines was produced days/weeks in advance. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
bwaz Samba Member
Posted: Sun Nov 25, 2018 6:56 pm Post subject: Re: does anyone here own the last oval beetle? |
Yes, but if a car was coming off the line, and they took down serial numbers and block numbers??? That’s why the question. |
SixVolt  Samba Member
Joined: January 04, 2004 Posts: 1143 Location: Cleveland, Ohio
Posted: Thu Dec 13, 2018 8:23 pm Post subject: Re: does anyone here own the last oval beetle? |
bwaz wrote: |
I've got 1513307. It's a '57, but there are plenty after this one.
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Fri Dec 14, 2018 4:21 am Post subject: Re: does anyone here own the last oval beetle? |
Mines 1400718, close but no cigar _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Gwdghiaguy Samba Member
Joined: December 06, 2013 Posts: 340 Location: Greenwood, SC
ultrarareparts Samba Member
Posted: Sat Dec 15, 2018 7:42 pm Post subject: Re: does anyone here own the last oval beetle? |
My 57 euro 1598986 very close to the end. |
bwaz Samba Member
Posted: Wed Dec 19, 2018 1:46 pm Post subject: Re: does anyone here own the last oval beetle? |
tekla wrote: |
Any chance you've got the original 36hp for it? |
bwaz Samba Member
Posted: Wed Dec 19, 2018 2:04 pm Post subject: Re: does anyone here own the last oval beetle? |
someone with a later euro confirmed to me with their car,
serial number #1599686
Engine #1926809
Body# 582287
that's pretty late!
In the engine section of Progressive refinements, it says a car with serial
1585100 built July 10 would have engine 1926145
also PR says
1601517 built Aug 2 would have engine 1939746
Samba says
1600846 built July 31 would have engine 1937052
So its possible 671 cars apart would have engines 2694 apart, although I know these motors went into buses and ghias too...
I'm trying to mate a close motor to my beetle, built July 15/57, has serial number 1601113... and is an early square window. Trying to guess on a close 36 hp block to build. So, so far, after 1926809 and before 1937052, but 10243 motors is still a pretty big gap.  |
h~moto Samba Member
Joined: November 19, 2008 Posts: 331 Location: Northern Virginia
Posted: Sat Dec 22, 2018 10:03 pm Post subject: Re: does anyone here own the last oval beetle? |
Quote: |
someone with a later euro confirmed to me with their car |
Is this an oval?
Are numbers confirmed with a birth certificate?
Is the date it was built known?
Quote: |
Progressive refinements says a car with serial 1585100 built July 10 would have engine 1926145 |
I think what PR is saying is that 10,000 engines had a change to the oil cooler and then it went back to how it was. Not sure that all these engines were built on July 10th. PR says that on July 9th (1 day earlier) there was a change at engine number 1934104 (a higher number).
I don't think that Progressive Refinements is an exact science. PR states that the square window started on August 1st at 1600440 but the month end figures lists the last July car as 1600846.
I don't think that engines were issued in a continuous order, but if you go by chassis number, your car falls between 1600846 (engine # 1937052) and 1601517 (engine # 1939746). That would put it at 2694 engines. |
bwaz Samba Member
Posted: Sun Dec 30, 2018 6:49 pm Post subject: Re: does anyone here own the last oval beetle? |
yes its an oval, not sure if birth certificate was in hand |
bwaz Samba Member
Posted: Tue Apr 02, 2019 9:40 am Post subject: Re: does anyone here own the last oval beetle? |
I found an old thread from 2008 that sheds some light on one of the earliest square windows...
There are some conflicting numbers... as the Samba shows the last car in July 1957 as serial number #1600846, but I've seen it elsewhere as the last car of July was #1600439.
On this site from 2002, https://web.archive.org/web/20050114173130/http://www.squarewindowregistry.org/featured/2002-08/
It shows a square window beetle with vin 1600831, which is before the 1600846 shown on the Samba?
According to the VW brochure "what year is this" it shows the last beetle in July 57 as being 1600439. That would make more sense if the first square window was VIN 1600440.
Posted: Sun Apr 07, 2019 12:14 am Post subject: Re: does anyone here own the last oval beetle? |
Read the progressive refinements in Technical section, thats probably closest to the VIN or production cars. But of course they normally built some prototypes before that. _________________ I got a historic car, every scratch got a history...
leowagen Samba Member
Joined: October 16, 2018 Posts: 171 Location: Argentina
Posted: Tue Apr 09, 2019 5:21 am Post subject: Re: Does anyone here own the last oval beetle? |
Mine is 1511544 and motor is 1819990 (both seem to be April '57).
I don't even bother in posting a picture since it has a later big window body on... |
Lind Samba Member
Joined: November 06, 2000 Posts: 10221 Location: idaho
Posted: Tue Apr 09, 2019 7:57 am Post subject: Re: Does anyone here own the last oval beetle? |
Back in the '90s, someone from Australia wrote a letter that was published in HotVWs where they claimed to have the last oval window produced.
Someone should send away for the birth certificate. _________________ .
Wanted:
bwaz Samba Member
Posted: Tue Apr 09, 2019 10:08 am Post subject: Re: does anyone here own the last oval beetle? |
Kjell Roar wrote: |
Read the progressive refinements in Technical section, thats probably closest to the VIN or production cars. But of course they normally built some prototypes before that. |
I hope that someone may eventually show up with a close vin # to my car.. to get me as close as I can. Between finding a number within maybe 100 cars, and finding that old block, I know it's not going to be easy. |
bwaz Samba Member
Posted: Tue Apr 09, 2019 10:09 am Post subject: Re: Does anyone here own the last oval beetle? |
Lind wrote: |
Someone should send away for the birth certificate. |
have to start digging through my old HotVW's  |
carnut63 Samba Member
Joined: May 14, 2009 Posts: 337 Location: Murrieta, CA & Everett, WA
Posted: Mon Apr 22, 2019 11:53 pm Post subject: Re: Does anyone here own the last oval beetle? |
I’ve got 1593819.
Doesn’t have the original engine though. _________________ Tyson
---> Mar 2 1955 Strato Silver Oval <---
---> July 1957 ragtop project <---
---> May 5 1966 Ghia <---
---> 1962 Ruby Red Deluxe (sold) |
bwaz Samba Member
Posted: Fri Aug 30, 2019 11:14 am Post subject: Re: Does anyone here own the last oval beetle? |
went through all my old hot vw's and couldn't find that article with what claims to be the last oval. Anyone ever see it? There's a late 57 for sale on old bug
http://www.oldbug.com/glab.htm which has a serial number of 1594590 with original engine 1932585. Getting pretty late if last is 1600439. Mine square window is a 1601113 serial number |
staale Samba Member
Posted: Sat Sep 14, 2019 5:39 pm Post subject: Re: Does anyone here own the last oval beetle? |
I dont own this car,but I found this in the sales records at the vw dealership where i work:
ch.nr 1598590. engine nr: 1937423.
Delivered August 2nd.1957. |
