EVfun  Samba Member
Posted: Sun Dec 30, 2018 5:07 pm Post subject: Best Lubricants for an Engine Install |
I don't see many posts on this, and what I see don't all agree. There are several surfaces that could be lubed before the engine goes in.
Pilot bearing
Clutch splines
Face of the throwout bearing
Flywheel ring gear
Other?
I've never read up on this or thought about it, it was hand-me-down knowledge to grease the pilot bearing, graphite the clutch splines and very lightly the face of the throwout bearing. I've been the Electric Vehicle guy so long I can't even remember what I did with the flywheel ring teeth. I'm ready for the "final" install (final before first drive) and was wondering, what is the current best practice? It isn't electric now so the flywheel ring gear teeth is in question too. _________________
Wildthings wrote: |
timvw7476 Samba Member
Posted: Sun Dec 30, 2018 6:18 pm Post subject: Re: Best Lubricants for an Engine Install |
There is a pink grease Exedy includes with their clutch kits.(tiny 5cc pack)
It's my fave for clutch spline/hub lube.
One day I will find a jumbo tube of it & then be very happy.
Bel Ray salt water proof grease for the pilot bearing / tube surface.
I put nothing on the pilot bearing surface to clutch fingers. Dry. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33111 Location: Hot Arizona
Posted: Sun Dec 30, 2018 7:42 pm Post subject: Re: Best Lubricants for an Engine Install |
EVfun wrote: |
Pilot bearing
Clutch splines
Flywheel ring gear
What I use:
Pilot bearing
Clutch splines
Flywheel ring gear
Lithum wheel bearing grease on above, and on starter bushing and starter teeth and transmission shaft
And nothing on the throwout bearing _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1790 Location: Cleveland, Ohio
trevs70 Samba Member
Posted: Sun Jan 27, 2019 12:29 pm Post subject: Re: Best Lubricants for an Engine Install |
I am guessing based on some of these answers that I can use a good moly on my flywheel and the center of my gland nut? _________________ .....
70 Convertible....in bad shape but coming along |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20816 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jan 27, 2019 2:26 pm Post subject: Re: Best Lubricants for an Engine Install |
Any good quality moly grease!
Dale _________________ “Fear The Government That Wants To Take Your Guns"
