Sliding door difference?
T25Joker
T25Joker is offline
PostPosted: Mon Jan 07, 2019 2:40 pm    Post subject: Sliding door difference? Reply with quote
Anyone who can tell me the difference between the early, and the later style sliding door? How can you recognise them? Question
VicVan
VicVan is offline
PostPosted: Mon Jan 07, 2019 2:57 pm    Post subject: Re: Sliding door difference? Reply with quote
I'm not aware of differences in the door itself. The mechanism is slightly different, for example on the rail on the outside of the rear panel, mid-height, earlier models have a plastic roller and later models have a metal roller.
Power lock was available on later models as well.
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Jan 07, 2019 3:10 pm    Post subject: Re: Sliding door difference? Reply with quote
On the outer skin, the early door has a much larger recessed area for the handle to move. This is because the handle was longer in early doors, 80-84 model year.
Inside, big differences. The early door had active latching mechanisms at both the front and rear edges.
The later door only has an active latch at the rear.
The latching differences are why the early door had a longer handle, it had more work to do operating 2 latches.
The window opening is slightly smaller front to back in the later door, so different windows are needed on the slider. (the window sizes on the other side of the van didn't change)
Mark
levi
levi is offline
PostPosted: Mon Jan 07, 2019 6:43 pm    Post subject: Re: Sliding door difference? Reply with quote
I thought the physical size was different also?
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
djkeev
djkeev is offline
PostPosted: Mon Jan 07, 2019 8:22 pm    Post subject: Re: Sliding door difference? Reply with quote
This thread should help you......
https://www.thesamba.com/vw/forum/viewtopic.php?t=650176
Dave
Ghia
Vanagon
Beetle
T25Joker
T25Joker is offline
PostPosted: Thu Jan 10, 2019 5:28 pm    Post subject: Re: Sliding door difference? Reply with quote
Thanks everyone!
