What's wrong with this picture?
lorse
lorse is offline
PostPosted: Thu Jun 30, 2005 9:54 am    Post subject: What's wrong with this picture? Reply with quote
My Friend's '57 SC has got a problem... is it the wrong hub or what?
rizzag
Now Wut?
rizzag is offline
PostPosted: Thu Jun 30, 2005 9:56 am    Post subject: Reply with quote
what is he doing? history? just putting together a straight axle kit or reduction boxes?
flossin, tossin, dippin, and trippin
lorse
lorse is offline
PostPosted: Thu Jun 30, 2005 10:00 am    Post subject: Reply with quote
He towed this from Oregon a year ago, rebuilt the engine, did some body work and now it's on the road... till He saw this.
He's got reduction boxes... looks stock, but it's not quite workin' out, as you can see.
60freak
60freak is offline
PostPosted: Thu Jun 30, 2005 10:01 am    Post subject: Re: What's wrong with this picture? Reply with quote
Just slap some washers in there to take up the extra space and it will be fine. Shocked
Just Kidding! Wink
It looks like the wrong hub/drum maybe, or like Rizzag asked, is he going straight axle or ????
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Jun 30, 2005 11:24 am    Post subject: Reply with quote
Either the drum is not correct or the stub is coming out of the RBs! Shocked
No a safe situation, to say the least! Confused
ROADKILL
ROADKILL is offline
PostPosted: Thu Jun 30, 2005 1:35 pm    Post subject: Reply with quote
there is supposed to be a spacer in there, between the drum and the axel cover.
rizzag
Now Wut?
rizzag is offline
PostPosted: Thu Jun 30, 2005 1:48 pm    Post subject: Reply with quote
its not the spacer. if the spacer was not there, the drum would hit the backing plate way before it could float that far back. my guess is that that drum snout has been cut down for a straight axle kit before.
if thats the case then i would get another drum, and to get by in the time being, you could use another under drum bearing spacer under the axle nut, crank it down and throw a cotter pin in it.
lorse
lorse is offline
PostPosted: Thu Jun 30, 2005 1:57 pm    Post subject: Reply with quote
I measured the snout on the drum and it's the same length as the other side, which has no space.
I'm wonderin'.... if somebody drove around with a loose nut, could they wear away the drum on the back side... thus causing this problem?
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Jun 30, 2005 1:59 pm    Post subject: Reply with quote
"...and to get by in the time being, you could use another under drum bearing spacer under the axle nut, crank it down and throw a cotter pin in it."
... and say your prayers! Pray
60freak
60freak is offline
PostPosted: Thu Jun 30, 2005 2:13 pm    Post subject: Reply with quote
No, I don't think so, but never seen that happen before so I'm not 100% sure! I would think the axle would tear/strip it's way out or strip inside the drum before anything like that could happen, and then the bus woudn't drive at all......you did say he was driving/on the road before right? Too strange Lorse, I dunno man? Confused
lorse
lorse is offline
PostPosted: Thu Jun 30, 2005 2:21 pm    Post subject: Reply with quote
Yep, he drove it over to my house... slow and not too far.
rizzag
Now Wut?
rizzag is offline
PostPosted: Thu Jun 30, 2005 2:45 pm    Post subject: Reply with quote
conveniently, you left out the part where i say "if thats the case" meaning that would be ok ONLY if the snout had been milled down. and if that was the case, it would be ok. it would be nothing more then a large washer. totally fine if the nut took torque and there was a cotterpin installed as i also said.
lorse
lorse is offline
PostPosted: Thu Jun 30, 2005 2:49 pm    Post subject: Reply with quote
But I don't think that is the case... the snout does not appear to be milled. Confused
rizzag
Now Wut?
rizzag is offline
PostPosted: Thu Jun 30, 2005 2:55 pm    Post subject: Reply with quote
pretty weird, i guess you just need to pull that pig apart and investigate. it may very well be a reduction box problem. if it is a reduction box problem then its something VERY wrong with the reduction box!!!
and as to you thinking the back of the drum could be worn down, thats highly unlikely because as i said before the drum would hit the backing plate and the brake shoes would bottom out in the drum way before it could float that far inward. if the drum is legit in all its dimensions then its time to look at the reduction box i would say.
lorse
lorse is offline
PostPosted: Thu Jun 30, 2005 2:59 pm    Post subject: Reply with quote
I appreciate the responses....
We'll have a closer look and let ya'll know what we find.
One more question... I know his '57 has a small nut, as compared to my '67, but would the snout of the drum vary in length between the two?
Andrew
Andrew is offline
PostPosted: Thu Jun 30, 2005 3:20 pm    Post subject: Reply with quote
If I recall, the snout of the drum wouldn't be very different, but the depth of the drum would be. So maybe it's 1 ton reduction boxes with the earlier brakes installed? Will that even all bolt together?
-Andrew
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Jun 30, 2005 3:38 pm    Post subject: Reply with quote
Tear it apart and figure out just what the hell is going on in there! Shocked
Do take pictures of what you find and post them too! Wink
60freak
60freak is offline
PostPosted: Thu Jun 30, 2005 3:42 pm    Post subject: Reply with quote
I think Andrew is onto something there.......hmmmmm.....that has me thinking now too. Idea
Fish
Fish is offline
PostPosted: Thu Jun 30, 2005 6:29 pm    Post subject: Reply with quote
It looks like he has a straight swing axle (68 long axle) in the bus and 5 lug 66 and earlier bug/ghia drums. You can run this by putting a extra axle seal spacer over the splines then the axle nut. I've done this before with out problems on a Haha bug (Street Baja) so I could run 5 lug drums. I would not take it off road though.
Prosit!
# 303 and #156
Fish
Fish is offline
PostPosted: Thu Jun 30, 2005 6:33 pm    Post subject: Reply with quote
Snout is the same, but axle diameter is different so the early one will not fit on the later one. The later one would fit over the earlier one, but would be all sloppy on the splines.
Prosit!
# 303 and #156
