AndyBees Samba Member
Joined: January 31, 2008 Posts: 2607 Location: Southeast Kentucky
Posted: Wed Feb 10, 2010 8:21 pm Post subject: Vanagon transmission vent and painting the tranny |
Two questions for opinions;
1. Has anyone done a mod to the vent hole on top of the Vanagon or Bus tranny, such as a pipe with an extension, cap, etc.? I'm finishing a rebuild/upgrade to my tranny and the vent hole sort of concerns me.
2. Lastly, after completing a rebuild, would you paint your tranny? If so, why and what color? What are the advantanges of painting, if any? Just looks or protection? _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Robw_z Samba Member
Posted: Thu Feb 11, 2010 4:33 am Post subject: |
Syncros have a hose coming from that hole in case you didn't know. You may want to emulate that setup if you are considering heavy offroading or something, though if you get in a situation that could compromise the tranny vent hole in a 2wd you might not get out!
I had my trans painted when it was rebuilt. Black or naked was the only option. I wish I would've just left it, it's an alloy that doesn't really rust and the paint, while not catastrophically raising temps, does make it harder for the transmission to vent heat, both the heat the gears generate and the heat it soaks in from the motor. I scratched off a bunch of the paint during the install anyway, while dragging it under the van.
-Rob |
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Thu Feb 11, 2010 7:36 am Post subject: |
I have done that here are some pics.
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10147 Location: Abiquiu, NM, USA
Posted: Thu Feb 11, 2010 8:44 am Post subject: |
Classic Ford red:
_________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
Posted: Thu Feb 11, 2010 9:57 am Post subject: Venting and painting of rebuilt tranny |
Well, I'm certainly going to do something about the Vent hole. Not only is it a place for debris, mainly water, to enter, it is also a place for the oil to come out. And, although the oil that comes out is minute, it allows for dust, etc., to accumulate.
I like the orange tranny! Is that off the shelf aersol paint or is it professional. Looks professional to me! _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
Posted: Thu Feb 11, 2010 10:34 am Post subject: |
Primed and painted with a rattlecan, Duplicolor engine enamel. It air-dries hard but is easy to chip until it heat sets. You can see some damage under the front diff where it got scraped off installing it. Once the casings heat up it fully sets and is pretty tough after that.
This van lived where they salt the roads so these casings were covered in scale. I wirewheeled it all off to prep. I like a gloss enamel because it looks better and lets me wash the grime off of at the car wash. Clean components are happy ones, and so is the guy who has to work on them. Lighter colors under the car also make things easier to work on, they bounce a little light around and it makes a big difference.
I think modding the air vent on a 2WD trans is a good idea, the tiny hole provided easily gets clogged when dirt hits the oily film there. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Muskrat Samba Member
Joined: July 20, 2006 Posts: 190 Location: sacramento, ca
Posted: Thu Feb 11, 2010 11:12 am Post subject: |
tencent...i wish i would've had your jack yesterday when i installed my trans.
is that your own creation or a commercial gizmo...
-k- |
rs4-380 Samba Member
Posted: Thu Feb 11, 2010 11:19 am Post subject: |
rattlecanned mine. ford gray engine enamel I believe.
_________________ Dave
87 EJ25 Syncro GL |
Posted: Thu Feb 11, 2010 11:49 am Post subject: |
grknvgn wrote: |
-k- |
I made this up just for vanagon trannies to make one-man installs easy. It has a fore/aft slide adjustment for balance; the CG of a 2WD is way different than a Syncro so that can be corrected. And it has a tilt adjustment that leaves some freeplay to wiggle the trans when it's being mated to an engine. The whole thing bolts to a spare floorjack. Works nice.
Posted: Thu Feb 11, 2010 6:56 pm Post subject: |
thats almost as beautiful as your engines.
you should be selling those as well.
nice work as always.
-k- |
Posted: Thu Feb 11, 2010 7:35 pm Post subject: Paint and moding the tranny vent |
Well, I'm convinced! I'll do a mod on the vent as well as paint the tranny.... baby blue! That should be light enough! _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
HeftySmurf Samba Member
Joined: June 15, 2008 Posts: 879 Location: Washington, USA
Posted: Fri Feb 12, 2010 8:38 am Post subject: |
_________________ -Lorenzo
90 GL w/ Bostig |
Posted: Fri Feb 12, 2010 9:13 am Post subject: |
Yow, love the yellow! That'll be like having floodlights underneath.
So how many of these pretty gearboxes are just come back from AA Daryl? Both of the ones I have shown were just reconditioned by him. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
jimf909 Samba Member
Posted: Thu Jan 17, 2019 12:08 am Post subject: Re: Vanagon transmission vent and painting the tranny |
Who knew that folks painted transmissions silver, red and yellow. Maybe I’ll go for purple. Purple tran, purple tran... _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
T3messie Samba Member
Joined: October 03, 2017 Posts: 214 Location: Germany
Posted: Thu Jan 17, 2019 12:39 am Post subject: Re: Vanagon transmission vent and painting the tranny |
Black gives the best heat passage.
Posted: Thu Jan 17, 2019 7:18 am Post subject: Re: Vanagon transmission vent and painting the tranny |
Wow!
I forgot about starting this Thread almost 9 years ago.
Well, I stuck with the bare OE metal, no paint.
I did modify the existing vent hole. I use a flexible hose and let it hang down like an Elephant trunk. It's been in service like this since 2012. I've had the transmission out and opened once but never saw any evidence of contamination.
metropoj Samba Member
Posted: Thu Jan 17, 2019 7:30 am Post subject: Re: Vanagon transmission vent and painting the tranny |
So, you just drilled out the hole a little bigger and JB Welded the copper piece in ? _________________ John.
86 TiiCo powered Westy. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15340 Location: Syracuse, NY
Posted: Thu Jan 17, 2019 7:49 am Post subject: Re: Vanagon transmission vent and painting the tranny |
NICE manual diff lock bracket.. though I doubt it would work with a WBX starter.
T3messie wrote: |
Abscate wrote: |
Posted: Thu Jan 17, 2019 8:24 am Post subject: Re: Vanagon transmission vent and painting the tranny |
metropoj wrote: |
So, you just drilled out the hole a little bigger and JB Welded the copper piece in ? |
Yep! That sums it up.
The end of the hose hangs in front of the tranny near the mount about a couple of inches higher than the bottom edge. (sorry, no pics) Seems to be working just fine. I've thought about installing one of those simple in-line fuel filters. The tranny does breathe with heat-up and cool-down cycles. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
Posted: Thu Jan 17, 2019 8:25 am Post subject: Re: Vanagon transmission vent and painting the tranny |
Thanks Andy. I may do this mod at some point when I drop the tranny and thought it would be good for clarity. _________________ John.
