Stock Crank Pulley Difference?
Fifty-Eight Rag
Fifty-Eight Rag is offline
PostPosted: Sun Jan 27, 2019 9:50 am    Post subject: Stock Crank Pulley Difference? Reply with quote
Is there a difference between a stock crank pulley from a 40hp vs. 1600 or will they interchange?
1956 Oval
and a barn full of VW parts
1956 Oval build thread
1962 Single Cab Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?p=7959298#7959298
1967 Beetle Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=495269&highlight=larrys
FreeBug
FreeBug is offline
PostPosted: Sun Jan 27, 2019 12:09 pm    Post subject: Re: Stock Crank Pulley Difference? Reply with quote
1300 pulley is slightly smaller in diameter than the 1600's.
tpinthepack
tpinthepack is offline
PostPosted: Sun Jan 27, 2019 2:21 pm    Post subject: Re: Stock Crank Pulley Difference? Reply with quote
So I have just run into this, and have not sorted it out yet. I have the larger 7inch stock pulley on the bottom, and the Alternator has a normal looking Generator pulley on it. Both OE German. My Alternator Belt is too short to fit. I have the longer of the two belts with the 11mm wide section. I do have a smaller 6 3/4 OEM bottom pulley, am I supposed to have that small pulley when using an Alternator? I honestly have never used anything but a Generator ever, so this one has me baffled a little also. As for the 1300 smaller pulley, that I did not know either.
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne
FreeBug
FreeBug is offline
PostPosted: Sun Jan 27, 2019 11:43 pm    Post subject: Re: Stock Crank Pulley Difference? Reply with quote
I stubled on it by accident...and discovered no one i spoke to knew this, even my parts supplier. I wonder how many used 1300 pulleys they sold ended up mounted on 1600s...and how much does it rezlly affect temps?
But seeing as how VW rationalised production for max savings, if the y hadn't needed to design a new pulley, they wouldn't have.
